This is a tricky one, care to help me figure it out? Getting HDMI audio to pass through to receiver (Windows 7) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-24-2013, 01:17 PM - Thread Starter
WeApOn's Avatar
Quoted: 35 Post(s)
Ok, so here's my setup first:
PC--->HDMI Out on video card---> Yamaha RX-V573
I also have...
PS3-->HDMI Out--> Yamaha RX-V573
My problem is this:
If I start my computer with the PS3 as the active HDMI input, and THEN switch over to my PC(on my receiver) after it has booted up, my receiver will not appear in the list of "playback devices" for Sound until I reboot. I believe I found a way one time to accidentally get it to repopulate WITHOUT having to reboot. Otherwise, rebooting will always fix this issue. There has to be some way that I can detect the receiver without having to reboot my PC.
For the record, everything works fine when I boot up with PC as the active input on my receiver. Sound passes through to the receiver and works great. I'm really looking for a 'trick' to redetect sound devices.
I will likely need to provide some more information, but wanted to get the general gist of my problem down so I could see it for myself and see if anyone has some helpful tips on how to fix the issue.
Thanks! I hope this is the correct sub-forum to post in.
WeApOn is offline
post #2 of 6 Old 03-24-2013, 01:49 PM
Sammy2's Avatar
Quoted: 515 Post(s)
Liked: 250
Try switching the HDMI inputs on the receiver. You may need to use an EDID override.. there's threads on that subject here. Also, you may need to use a proper sequence to get things right. Try shutting off the TV and AVR then turning on the TV then AVR with a couple seconds between.
Sammy2 is offline
post #3 of 6 Old 03-24-2013, 01:57 PM - Thread Starter
WeApOn's Avatar
Quoted: 35 Post(s)
I've heard about an EDID override to achieve 120Hz on my TV, the problem is my PC connects to my receiver first, and then an HDMI 1x2 splitter, and then into two separate TVs. This allows me to clone the image to both, but there's not one single TV it's connected to.. so the EDID override might not work.
I've tried swapping between the two inputs a few times, but the PC still thinks there is no HDMI audio on the PC side. Something happens at startup that makes it happen.
WeApOn is offline
post #4 of 6 Old 03-25-2013, 05:52 AM
Sammy2's Avatar
Quoted: 515 Post(s)
Liked: 250
You never said there was an HDMI splitter with two TV's in the system in your original post. That is important information and requires a whole different approach to things. My thoughts are that the EDID is not being sent from properly through the splitter. Take it out of the chain and test then report back your results. Can you post specs on the splitter? Where did you get it? Link?
Sammy2 is offline
post #5 of 6 Old 03-25-2013, 05:59 AM - Thread Starter
WeApOn's Avatar
Quoted: 35 Post(s)
Well I kind of thought that would be irrelevant as this ONLY happens when the PC is not the output on the receiver while the PC is starting up. I'm moreso looking for a way to have Windows 're-detect' my audio devices. Technically if the Receiver is appearing in 'audio devices' in that scenario, then wouldn't that mean this isn't about the EDID passing properly? Granted it could be seeing a different device -- it doesn't explicitly say YAMAHA RX-V573.
Here is the splitter in any case:
http://www.amazon.com/gp/product/B008B7ARRK/ref=wms_ohs_product?ie=UTF8&psc=1
WeApOn is offline
post #6 of 6 Old 03-25-2013, 06:03 AM
Sammy2's Avatar
Quoted: 515 Post(s)
Liked: 250
When dealing with HDMI/EDID/HDCP,everything in the playback chain is important when you are having issues.
Sammy2 is offline
Reply Home Theater Computers
