Help...WMC "Cannot play video error" - AVS Forum | Home Theater Discussions And Reviews
Old 03-26-2013, 11:31 AM - Thread Starter
stamina1914's Avatar
Quoted: 106 Post(s)
I created a DNK Trilogy folder couple of months ago. Everything used to work fine. I have watch all three movies since. However today I tried to watch one of the 1st movie and I got the message that states
"WMC can not find the specified file. Be sure the path is typed correctly. If it is the file the file does not exist at the specified location or the cpu where the file is stored is offline"
I got the same message when I tried to play DNK. The good news is that the DNKR played.
Any thoughts on how I can fix this?
stamina1914 is offline
Old 03-26-2013, 01:08 PM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
are you using something like media browser?
what video codec?
what audio codec?
what container?
anything like Shark007 installed?
ive seen that error before when I didn't have something set up in shark to play the container type
youre talking about Batman blurays right?
don't ask me how i remember this, but the first two movies use VC1 video and (I think) Dolby audio. The newest one has (I think) h264 video and DTS audio. Chances are something isn't set up correctly for VC1 in whatever container you are using.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is online now
Old 03-26-2013, 01:15 PM
BillBragg's Avatar
I had the same issue yesterday. I went in with the file explorer and noticed that somehow the directory had become read-only. I changed that and let the change cascade and brought WMC back up. At that point it worked fine.
BillBragg is offline
Old 03-26-2013, 06:10 PM - Thread Starter
Quoted: 106 Post(s)
what video codec?
what audio codec?
what container?
The name of the video codec escapes me, it wasn't shark, but it was one that Assassins guide recommended. The video codec is MKV. And yes I was trying to watching Batman. Again I have watched the movies before and I don't much has changed.
Old 03-26-2013, 07:32 PM
Quoted: 648 Post(s)
Liked: 426
mkv is a container, not a codec. h264, mpeg2, xvid, are codecs.
i dont know exactly how to fix your problem without knowing what you have installed, but i just looked and im positive that batman begins and the dark knight both use VC1 video and Dolby audio. Dark Knight Rises used h264 video and DTS audio.
your problem has to do with the interaction of mkv, vc1, and dolby. most likely VC1
Old 03-27-2013, 07:57 AM - Thread Starter
Quoted: 106 Post(s)
Apologies for turning that around. At the moment, I do not have access to assassin's guides, but I know I did not intstall the shark codecs yet. Could it have been LAV? Does that make sense? Btw my setup is tv, htpc and receiver. Again as little as 1 month ago, everything played well. Something had to have change in my setup, it wasn't intentional and therefor should be minor, perhaps a setting in my receiver?
Old 03-27-2013, 08:41 AM
Quoted: 648 Post(s)
Liked: 426
I've never moved on to LAV, but look in the video filter settings and see what is checked off for VC1. Also look at see what is ticked off at the bottom of the image.
Many Warner Bros/Legendary Pictures titles have used VC1 over the last few years, as did most movies originally released exclusively on HD-DVD. I bet if you have another MKV with VC1 video that it will give you a similar error.
Old 03-27-2013, 11:28 AM - Thread Starter
Quoted: 106 Post(s)
I have know doubt your hypohypothesis may be right, if true what will puzzle me is what triggered the changed. Like I said, it used to work.
Old 03-27-2013, 03:34 PM - Thread Starter
Quoted: 106 Post(s)
Well while the only movies that are not playing are indeed VC-1 movies, a few vc-1 movies did play, such as pitch black, chronicles or Riddick and the Bourne Supremacy, Another movie that did not play to go along with the first two batman movies was 300.
Does this mean anything.
Old 03-28-2013, 09:15 AM - Thread Starter
Quoted: 106 Post(s)
Anyone? Thanks
Old 03-28-2013, 09:36 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Did you install anything recently?
Has Windows automatically updated itself?
Maybe roll back to a point when things were working well and then change Windows Update to allow you to choose which updates to install.
Sammy2 is offline
Old 03-28-2013, 02:14 PM - Thread Starter
Quoted: 106 Post(s)
Ok, How do I roll back. I do remember install a time sync to the PC. But I can not recall installing anything that wouldn't only 3 of my movies not to show.
Regardless, how do I roll back? Thanks
Old 03-28-2013, 02:46 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Control Panel > Recovery
Sammy2 is offline
