Need Help - refresh rates or resolution maybe? - AVS Forum | Home Theater Discussions And Reviews
Old 03-26-2013, 06:40 PM - Thread Starter
jweatherbie's Avatar
Hi Everyone,
I need some help. My HTPC picture was great with my old TV and with my newer one, its not. Perhaps I notice it more as the new one is larger?
When watching from a distance the picture is ok, but when moving closer to the TV, the edges of objects seem pixelated. Watching hockey close to the TV is terrible!
Here is the equipment
TV: Panasonic TC-P55GT30
STB: Motorola DSR 505
OS: Windows Vista Ultimate
CPU: Intel Q6600 quadcore
6GB of RAM
Capture: Haupagge HVR1600
Video: ATI 5700 series (512mb or 1Gb, I forget)
It must be my settings. BluRays look amazing. Are there any good walkthroughs for this? I can post my resolution and refresh settings if that helps!
Thanks in advance!
John
jweatherbie is offline
Old 03-26-2013, 06:56 PM
lockdown571's Avatar
Quoted: 37 Post(s)
Liked: 87
It's hard to know what you're seeing. If your new TV is larger, you may just be noticing now the abysmal video quality that your cable company provides. This is especially noticeable when things move quickly across the screen like in sports. This is the same for everyone. Cable quality is just miserable compared to blu-ray.
lockdown571 is online now
Old 03-26-2013, 07:59 PM - Thread Starter
I should mention that the connection between the STB and the HTPC is S-Video. I think 720x480 is the max svideo can handle. Would that mean the PC is getting a low quality signal, and the htpc is bumping that up to my 1080 resolution, perhaps causing the issue?
The Happauge HVR1600 won't take anything better than svideo in. If a new capture card is a good idea, I am open to ideas smile.gif
Old 03-26-2013, 08:32 PM
Quoted: 37 Post(s)
Liked: 87
Yes, that is definitely part of the problem. Either get one of those Hauppauge Colossus capture cards with component/HDMI or get a CableCard device like the Ceton InfiniTV or the SiliconDust HDHomerun Prime.
Old 03-26-2013, 08:35 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Yup, you will want a new capture card with component video or HDCP-compliant HDMI in (with a DVI-HDMI adapter).
- Component video: Hauppauge HD PVR, Hauppauge Colossus
- HDMI: Timeleak HD72A (can be found at ebay)
- HDMI & component video: Timeleak HD75A (can be found at ebay), Skydigital SKYHD CaptureX HDMI, Skydigital SKYHD CaptureX HDMI 1080p (supporting 1080p24) (have to import from Japan)
Timeleak supports only stereo PCM over HDMI, while Skydigital supports AC3/DTS/AAC over HDMI. (You will have to find an appropriate driver for Timeleak / modifiy registry for Skydigital.)
renethx is offline
Old 03-26-2013, 08:42 PM - Thread Starter
I was forgetting the fact then when I built this, the HVR1600 was the best I could get. Then remembered the SVideo when I went to hook direct to TV to troubleshoot.
I will look at the Hauppauge stuff. What about the acre media HD Capture Pro?
Old 03-26-2013, 09:49 PM - Thread Starter
Anyway to know if the STB puts out encrypted signal? I'd hate to buy this, and have the box encrypt
Old 03-26-2013, 10:02 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Component video (analog) is not encrypted. Only DVI/HDMI could be encrypted.
renethx is offline
