Need help with my HTPC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-27-2013, 08:15 PM - Thread Starter
Liamnguyen's Avatar
I have a HTPC with a HD 7970
My question is: can I use HDMI to connect my PC to my Receiver for sound, and another HDMI from my PC to connect to my TV?
Because my receiver does not support 3D but my TV does.
Liamnguyen is offline
post #2 of 4 Old 03-27-2013, 09:14 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Might work, just make sure to set the receiver as the default audio device in the sound control panel.
Liamnguyen likes this.
Mrkazador is offline
post #3 of 4 Old 03-28-2013, 01:35 AM
ikkuranus's Avatar
Quoted: 86 Post(s)
Liked: 53
Not likely, will probably not even be detected without a display active on the receiver. Might be able to get around this by hooking a hdmi splitter between the htpc and the 2 devices though honestly I have no idea if that would work.
ikkuranus is offline
post #4 of 4 Old 03-28-2013, 07:54 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
The answer is yes. A lot of people do this to fix handshake and EDID problems. You need to set up windows to extend your displays.
Every once in a while you will loose the mouse or an icon on the phantom display, but it doesn't happen too often.
Your also more susceptible to ground loops.
Andy_Steb is offline
Reply Home Theater Computers
