Intel Pentium G860 for htpc? Or g2020? - AVS Forum | Home Theater Discussions And Reviews
Old 03-28-2013, 08:31 AM - Thread Starter
pd veeps's Avatar
How is the Pentium G860 cpu for an htpc? I'm really using it for recording/playback ota channels with a hdhomerun dual. I would also like to stream shows/movies online if possible,
I can get it for $60 which seems like a good deal.
pd veeps is offline
Old 03-28-2013, 09:14 AM
staknhalo's Avatar
Quoted: 383 Post(s)
Liked: 241
It's fine. I have a G620 and was doing all the above as well as playing BR's fine on the IGP (now have a discreet card). It was an Intel HD Graphics IGP; same as that chip.
staknhalo is offline
Old 03-28-2013, 11:57 AM - Thread Starter
pd veeps's Avatar
or should I go with g2020 which is an ivy bridge for $65
pd veeps is offline
Old 03-28-2013, 10:25 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
IVB is better in both CPU and GPU. For your purposes perhaps Celeron G1610 (IVB), ~$45, is enough.
renethx is offline
Old 03-29-2013, 07:28 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
^ +1
If you look at the specs, a G860 is nearly a i3-2100 with some features disabled in the GPU (QuickSync, 3D) and a couple in the CPU that aren't really interesting for HTPC anyway.
http://www.cpu-world.com/Compare/245/Intel_Core_i3_i3-2100_vs_Intel_Pentium_Dual-Core_G860.html
For what you are doing even one of the mobile Celeron 847 boards would suffice so either G860 or G1610 is more than enough.
StardogChampion is offline
Old 03-29-2013, 03:00 PM
jeffkro's Avatar
Originally Posted by StardogChampion View Post
^ +1
Yeah, I'm thinking the celeron 847 boards are a cool idea for HTPC. I'm hoping the concept survives for Haswell equivalents.
If you go this route make sure you get the one with the big heasink.
http://www.amazon.com/Gigabyte-Intel-Celeron-Motherboard-GA-C847N-D/dp/B00AUH3BRW/ref=wl_it_dp_o_pdT1_S_nC?ie=UTF8&colid=44X7ASTT9ZYB&coliid=I24IFAU25NYDBO
jeffkro is offline
Old 03-29-2013, 03:03 PM
jeffkro's Avatar
$80 with free shipping and low energy costs. You wont beat it on a cost basis.
jeffkro is offline
