Small/ Smallest Box to drive 30" 2560 x 1600 LCD via Dual link DVI-D / DisplayPort? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-30-2013, 03:43 AM - Thread Starter
crashnburn_in's Avatar
REQUIRED:
a - VIDEO:
- Barebones Box/ Ready Box / Motherboard/ Case:
I'd like find the smallest box/ machine / Barebones or HTPC Media Streamer Box that has
the Video Hardware to support & Drive 30" 2560 x 1600 LCD at Native Resolution
- On board or added Video Card:
Integrated or Dedicated GPU to support this resolution (Intel, AMD or NVidia - No preferences here, any of them will do)
b - PORTS:
- Dual link DVI-D
AND / OR
- DisplayPort
ADDITIONAL BONUS:
- eSATA/ USB 3.0
- LAN/ Gigabit LAN
- WiFi (Optional)
USAGE:
XBMC and More -
crashnburn_in is offline
post #2 of 3 Old 04-01-2013, 05:44 AM - Thread Starter
Cant seem to find any Mini iTX with BOTH built in Dual Link DVI and DP.
Are there?
If not..
- Should I account for a Videocard that will support both?
- Should I increase the search size to Micro ATX?
Is NewEgg the best place to search for different MoBo with parameters or is there some Comparison/ Tabular Search and Filter engine where I can filter through various Mobos?
post #3 of 3 Old 04-01-2013, 07:00 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
No.
ASRock Z77E-ITX has a DP supporting 2560x1600 @60Hz.
renethx is offline
Reply Home Theater Computers
