Best xbox for extender and games? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-30-2013, 01:09 PM - Thread Starter
doozer12's Avatar
I was thinking about getting the Ceton Echo as an extender but the kids said they want an xbox so I thought I would kill 2 birds... I might just buy a new one but didnt know if any of them were more suited as an extender. I have never had an xbox (ps3 only), so Im not sure if it matters which one I get. Is size the only difference?
doozer12 is offline
post #2 of 6 Old 03-30-2013, 01:35 PM
stamina1914's Avatar
Quoted: 112 Post(s)
If you are buy brand new, then any XBOX 360 will do. The only difference would me the memory size. Which would not matter in terms of an extender.
Now you still have the option buying the older version of the xbox 360 say off of craigslist or a pawn shop, but those versions are pretty loud and would ruin your viewing expeierence. I hope this helps.
stamina1914 is offline
post #3 of 6 Old 03-30-2013, 02:13 PM - Thread Starter
doozer12's Avatar
Thank you, that is helpful. I was planning on a new one. Im just not sure if the 4gb one will be enough for gaming. Not serious gaming, just for my kids. I just want it for the extender. Are the new ones fairly quiet?
doozer12 is offline
post #4 of 6 Old 03-30-2013, 03:04 PM
mdavej's Avatar
Quoted: 2273 Post(s)
Liked: 992
I added an old Xbox hard drive to mine for about $20 plus a cheap caddy for it.
mdavej is offline
post #5 of 6 Old 03-30-2013, 04:00 PM
Quoted: 112 Post(s)
It all depends on how much downloading your kids will be doing. I have a 11 year old myself and he downloads just about every demo game that is out there.
Another thing about the XBOX that makes it a great extender, is all the apps that are available. Apps such as Netflix, HBO Go, ESPN3 etc, If you are using an HTPC chances are you will no longer have the On-Demand features of cable therefore apps like HBO go can fulfill that void say if you somehow miss Game of Thrones Premiere tomorrow night on HBO, you can recover watch in on the xbox 360.
Having said this I would go with the 250gb version. It kind of sucks that there is nothing in between th 4g and the 250g.
post #6 of 6 Old 03-30-2013, 07:24 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 416
4GB will be ok for casual gaming but if you game a lot, it will not be enough because most games now sells DLC (basically map packs) that will need a lot of space to store). And install games to HDD will make game launch faster and quieter as well as extend the life span of the DVD drive.
You can use a USB stick to extend the storage. But it needs to be fast enough (most cheaper USB sticks won't work) and MS capped it at 16GB max.
Foxbat121 is offline
Reply Home Theater Computers
