Time to "tweak" the HTPC - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 05-17-2013, 12:21 AM
tahn's Avatar
Originally Posted by gonzo90017 View Post
They used to sell it a while ago in the Zinc.tv website.
I haven't the slightest clue. Is there any way to find out?
Never mind. It most probably uses 2.4GHz.
If it is capable of sending 315-433MHz, I think I can tweak this "god-awful homemade switch" to work with your ZV.
tahn is offline
Old 10-15-2013, 04:17 PM - Thread Starter
PrinzII's Avatar
Since the last time I posted in this thread, I am considering a different direction. I am going with one of the Richland APUs with a better mATX board. I am also going to look at a different cooler to mitigate heat issues.
As for the desktop, let's just say it will have an FX 9590 in it.
Originally Posted by Mfusick
Cheap is cheap and nice is expensive. It's how life works.
PrinzII is offline
Old 10-16-2013, 03:13 AM
ikkuranus's Avatar
Quoted: 86 Post(s)
Liked: 53
If you want a different direction you should consider an Intel 4670k or a 4770k if video editing/livestreaming. Spending almost 400$ on the one you listed is just silly considering it has worse ipc, uses over 2x power, and produces more heat.
It is possible Amd will make a solid product in the future but for now there really is no substitute especially when building a gaming rig.
ikkuranus is offline
Old 11-08-2013, 04:37 PM - Thread Starter
PrinzII's Avatar
As for the desktop, I am considering water cooling to mitigate the heat issue.
For the HTPC, I'll stick with AMD as it has served me well.
PrinzII is offline
Old 01-15-2014, 03:53 PM - Thread Starter
PrinzII's Avatar
This past weekend, I had to crack open the HTPC and found one of the rear fans going out. I replaced the fan but am thinking about the issue of cable management inside this Silverstone case. Anyone got some pointers on that?
PrinzII is offline
