HD 4000 Overscan - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-30-2013, 10:02 PM - Thread Starter
Fix Me's Avatar
So, I just built a HTPC with an i3-3225 and I can't seem to get the Overscan settings to work. I have it connected to a Samsung HLS6187 60" DLP TV. It doesn't have a 1:1 setting that I've been able to find. I've had other PC's connected to this TV with AMD and Nvidia cards and their overscan adjustments work fine. When I adjust the Overscan Percentage in the Intel control panel, I can see a little more of the desktop, but it never gets any better or worse regardless of what I set the percentage to. I've got it connected via HDMI and am using Widows 7 Ultimate 32-bit. I've tried both the display driver from Gigabyte and Intel's current driver, there's no difference. Does anyone have any thoughts?
Fix Me is offline
post #2 of 6 Old 03-31-2013, 09:45 AM
xreyuk's Avatar
1:1 settings on Samsung TV's is called Screen Fit.
Are you sure it's not there?
xreyuk is offline
post #3 of 6 Old 03-31-2013, 10:44 AM - Thread Starter
Fix Me's Avatar
Yes, I'm sure. I did find a way to turn Overscan off in the Service Menu, but that didn't fix it. It helped the Overscan a little, but the desktop was still cut off.
Fix Me is offline
post #4 of 6 Old 03-31-2013, 10:54 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Make sure you choose the option to 'center the image', not other options if you use customized resolution. Otherwise, I found using the standard resolution but adjust aspect ratio works better.
Foxbat121 is online now
post #5 of 6 Old 03-31-2013, 12:06 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
I had the same problem with the same setup as you so I hope this helps you out. In the Intel Graphics properties I had to set the refresh rate to 24p, then the custom aspect ratio adjustments appeared. Now you can adjust the pic size to fit. 75 horiz, 75 vert worked for me. On all Samsung TV's "16:9" is overscanned, and "Screen-Fit" is Full pixel.
Fix Me likes this.
Dropkick Murphy is offline
post #6 of 6 Old 03-31-2013, 05:19 PM - Thread Starter
Fix Me's Avatar
Thank you Dropkick Murphy, that fixed it! That's weird that 24p would make those settings appear, but whatever. cool.gif
Fix Me is offline
Reply Home Theater Computers
