FlexRAID server build and some questions - AVS Forum | Home Theater Discussions And Reviews
Old 04-01-2013, 03:57 AM - Thread Starter
DavidT99's Avatar
Quoted: 13 Post(s)
I am about to buy the parts for my FlexRAID server and want to ensure I am on the right track. I already have an Intel Celeron G540 CPU so have decided to utilise that in an ASRock B75M R2.0 motherboard with 4gb of RAM and 6 1TB HDD's. apart from FlexRAID the server will run Sick beard, SABnzbd and MySQL for an XBMC database shared between 4 HTPC's.
Will the CPU be enough for my requirements and what do you think of the motherboard?
Also what size PSU will I need, l have a spare 300watt but I could also get my hands on a 400watt if necessary.
I also want to evenly share all data across all the data HDD's, is this possible with FlexRAID?
EDIT: I have been reading up on WHS 2011, is this a better option than Windows 7 as the OS?
David
DavidT99 is offline
Old 04-01-2013, 06:58 AM
bryansj's Avatar
Quoted: 1130 Post(s)
Liked: 560
To split the data across the drives in FlexRAID you need to "seed" the drives with folders prior to making the pool. Once pooled, FlexRAID will fill the drives by adding to the drive that already includes the folder.
Drive1: Movies
Drive2: TV
Drive3: Music
Drive4: Pictures
Drive5: Downloads
Drive6: Parity
Anything added to the Movies folder will be added to Drive1. Anything added to Downloads will be added to Drive5. This happens until a drive is full and then it will automatically create another folder on a different drive and begin filling it up.
This behavior is the default setting and is called Auto-Folder-Priority. The other option is Auto-Space-Priority and is located under the Storage Pool Merge Configuration, how you get there depends on if you used Cruise Control or not.
bryansj is online now
Old 04-01-2013, 08:18 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Drive1: Movies
Drive2: TV
Drive3: Music
Drive4: Pictures
Drive5: Downloads
Drive6: Parity
Very good post. Yes. This is correct.
Your stuff stays together until your drive fills up.
Then it puts the same folder on another drive with space and begins filling that. Having stuff inside folders helps.
Mfusick is offline
Old 04-01-2013, 09:25 AM
bryansj's Avatar
Liked: 560
Also, I'm not sure what the definition is of "filled up". I have a 3TB drive in the pool that has about 400GB free and FlexRAID has started writing the folder contents to another drive.
Old 04-01-2013, 09:32 AM - Thread Starter
DavidT99's Avatar
Quoted: 13 Post(s)
Thanks for the replies.........if I had a movie folder on all five drives will FlexRAID populate each drive/folder equally?
David
DavidT99 is offline
Old 04-01-2013, 09:39 AM - Thread Starter
DavidT99's Avatar
Quoted: 13 Post(s)
Thinking about this a bit more I dont think it will be feasable. My movies are all stored in indivdual folders with a single media file and their respective metadata. Each folder will have at least 5 files within it, I dont want them spread across multiple drives.
David
DavidT99 is offline
Old 04-01-2013, 09:40 AM
bryansj's Avatar
Liked: 560
I doubt it. It'll probably fill what it considers the first drive first and then move on to the next one. The other side of the balancing is the power use/savings. Having all your data fill one drive means the other drive(s) don't have to power up as often.
Old 04-01-2013, 12:03 PM - Thread Starter
DavidT99's Avatar
Quoted: 13 Post(s)
Thanks, I thought as much. My reasoning was to share the load across all drives rather than having the first few loaded up and the next few nearly empty.
Anyone got any thoughts on my proposed motherboard/CPU combo?
I have read some more on WHS 2011 and it looks like a cheap way of getting a Windows OS that will run FlexRAID at less than half the cost of Windows7
David.
DavidT99 is offline
Old 04-01-2013, 12:18 PM
bryansj's Avatar
Liked: 560
The cheapest OS to run FlexRAID as well as some of your other programs would be Linux...
Old 04-01-2013, 03:42 PM - Thread Starter
DavidT99's Avatar
Quoted: 13 Post(s)
I know nothing about Linux apart from a very brief play with Ubuntu, I prefer Windows as that's what I know.
David
DavidT99 is offline
