server in hot environment 100F+ degrees - garage - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 04-01-2013, 11:15 AM - Thread Starter
mo0sic's Avatar
Think it would be possible to build a server that could operate safely in a 100+ degree environment. I'd like to build a 20 drive server solution and put it in my garage. Possible? There are days in the summer where it gets very hot where I live. It doesn't need to be fast, just reliable with no data loss.
mo0sic is offline
post #2 of 11 Old 04-01-2013, 11:18 AM
TornadoTJ's Avatar
Quoted: 1612 Post(s)
Liked: 510
IMO, your bigger problem is the temperature fluctuation.
TornadoTJ is offline
post #3 of 11 Old 04-01-2013, 11:30 AM
bryansj's Avatar
Quoted: 1123 Post(s)
Liked: 555
I wouldn't do that. You are going to be over 20 F above room temperature during those days. Your system will not be able to cool itself down to typical temperatures. It might work, but I wouldn't trust it with my data.
I just went through a server cooling project a week ago. http://www.avsforum.com/t/1465130/server-closet-cooling
bryansj is offline
post #4 of 11 Old 04-01-2013, 11:53 AM
erickotz's Avatar
Liked: 30
The only way I see this as feasible is having an insane amount of fans blowing air through the server, essentially keeping everything inside at ambient temperature
Quality Assurance Manager, Ceton Corporation
erickotz is offline
post #5 of 11 Old 04-01-2013, 12:24 PM
macks's Avatar
Liked: 31
GEOTHERMAL WATERCOOLING
It will be cheaper to just put it in the house where it belongs.
macks is offline
post #6 of 11 Old 04-01-2013, 12:50 PM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
Placing it in the garage not only exposes it to extreme temperatures but also more dirt and dust than it would see indoors. That is simply too hostile of an environment for a server. You'll probably end up replacing a lot of drives on a regular basis.
captain_video is online now
post #7 of 11 Old 04-01-2013, 01:05 PM
Dark_Slayer's Avatar
Quoted: 655 Post(s)
Liked: 434
Not a reliable idea unless everything was exchanging heat to somewhere cooler than the garage http://www.extremetech.com/extreme/124677-how-to-cool-a-pc-with-toilet-water
Dark_Slayer is offline
post #8 of 11 Old 04-01-2013, 02:32 PM
WonHung's Avatar
Just focusing on temperature, you may want to look at Dell's 12th Gen servers and their Fresh Air Cooling initiative.
http://en.community.dell.com/dell-groups/small-business/b/smb/archive/2012/05/08/fresh-air-technology-with-dell-poweredge-12th-generation-servers-infographic.aspx
The servers are certified to operate up to a max temperature of 113 degrees F. Personally, I have experience pushing their much older PowerEdge 1750 and 1850 servers with much hotter temperature in a former work situation. I took a temperature measurement at the back of the racks and got a reading of around 130+ degrees F. The servers were running 24/7/365 and only one server developed a failure in one of its power supplies. Other than that, everything kept running.
WonHung is offline
post #9 of 11 Old 04-01-2013, 10:50 PM
Tong Chia's Avatar
Keeping the drives cool enough is going to be the problem, with 20 spindles active you have to consider how to get rid of all this waste heat.
Consumer desktop and most enterprise nearline drives are validated/tested to 60C ambient only (140F).
I suggest starting with a smaller array of 3-4 drives and see how hot it gets in the garage and how much effort it would be to cool it to below 60C
Tong Chia is offline
post #10 of 11 Old 04-02-2013, 03:53 AM
WonHung's Avatar
It's not going to be as bad as you think. I have three servers running in my server room along with a bunch of network equipment. I would guess that I have about 30 hard drives running and the heat output isn't too bad.
WonHung is offline
post #11 of 11 Old 04-02-2013, 06:12 AM
cybrsage's Avatar
Liked: 154
I think his 100 degrees is F, meaning he still has 20F headroom. I would still caution against it...hard drives can get hot if they are used a lot.
cybrsage is offline
Reply Home Theater Computers
