Do you need more than 1 hdhomerun with CC? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 04-01-2013, 04:43 PM - Thread Starter
tpoynton's Avatar
Greetings! Let me start by saying I am wicked cheap.
I would LOVE to ditch premium cable if wife would let me...not sure she will. Slowly, I have been making inroads - she likes xbmc if I am there to control it.
I would like to try ditching a cable box I have in the basement; xbmc effectively replaces on demand programming, and the box does not have a DVR - working on getting hdhomerun as a tuner so I can ditch my cable box.
My question, specifically, is this: if I buy the hdhomerun now (not prime), and decide later that I need one with a cablecard, will the non-prime hdhomerun tuner be useless? OR, can I connect the prime to the non-prime?
I am working on 'proof of concept' stuff here, so I'd rather not buy the prime just yet - but will if needing a CC in the future would render it useless.
I searched around here and the silicondust forum, came up empty - apologies if this answer exist somewhere!
tpoynton is offline
post #2 of 11 Old 04-01-2013, 05:03 PM
lockdown571's Avatar
Quoted: 36 Post(s)
Liked: 87
Well it won't be useless. You could still use the non-prime version for OTA. You can certainly use the prime and non-prime version at the same time. The non-prime version will never tune cable card channels though.
lockdown571 is offline
post #3 of 11 Old 04-01-2013, 05:12 PM - Thread Starter
tpoynton's Avatar
thanks for the speedy, informative reply! I will start with a non-prime
tpoynton is offline
post #4 of 11 Old 04-01-2013, 05:40 PM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
It won't decode encrypted cable channels, but it will tune and receive in-the-clear QAM channels from your provider. These are usually limited to your local channels.
captain_video is offline
post #5 of 11 Old 04-01-2013, 06:08 PM
TornadoTJ's Avatar
Quoted: 1612 Post(s)
Liked: 510
I have a non-prime for antenna/OTA and a Prime for cable channels. They work completely seamlessly for the most part.
I think you might have a problem with xbmc though. No support of copy-once channels when you get the Prime. It's a cable industry limitation. You'll have to go to Windows Media Center.
TornadoTJ is offline
post #6 of 11 Old 04-02-2013, 05:19 AM
Quoted: 510 Post(s)
Liked: 336
What do you want to do with the HDHR? Are you planning on setting up a DVR to record programs or are you just watching live TV? The latest beta firmware and HDHR software allow you to stream live TV from the HDHR Prime to any device that's DLNA compliant, such as a PS3 or the WDTV Live media player. There's a thread dedicated to the topic as well as a special forum area discussing it over at the SiliconDust forums.
post #7 of 11 Old 04-02-2013, 11:39 AM - Thread Starter
tpoynton's Avatar
thanks captain, plan on initially using to DVR with htpc, but may use to replace cable boxes in the future. sounds like the dlna bit is only on prime? will investigate on silicondust forums.
htpc runs win8 as with xbmc, so not problem here but good information!
tpoynton is offline
post #8 of 11 Old 04-02-2013, 11:47 AM
TornadoTJ's Avatar
Liked: 510
DLNA is Prime only.
post #9 of 11 Old 04-02-2013, 11:49 AM - Thread Starter
tpoynton's Avatar
saved me a trip, thanks tornado!
tpoynton is offline
post #10 of 11 Old 04-02-2013, 11:52 AM
TornadoTJ's Avatar
Liked: 510
post #11 of 11 Old 04-03-2013, 09:01 AM - Thread Starter
tpoynton's Avatar
Thanks for that, will do!
tpoynton is offline
Reply Home Theater Computers
