Would Re-ripping help me? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 28 Old 04-02-2013, 08:46 PM - Thread Starter
stamina1914's Avatar
Quoted: 106 Post(s)
A few weeks ago I posted that all of a sudden 3 movies in my MKV Ripped library of movies are all of a sudden giving me a Window can not play video error. While a few folks have tried to help, nothing has worked thus far. Folks seem to believe it might be a codec issue, but again , the movies used to play well and they still play on using VLC, but I want the movies to play in Media Browser
The bottom line if I were to delete the movies and re ripp them, would this solve my problem or is there some larger underlying problem I need to fix first before I can get this to work.
stamina1914 is offline
post #2 of 28 Old 04-02-2013, 08:51 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
If they work in vlc then its a decoder problem.
Mrkazador is offline
post #3 of 28 Old 04-02-2013, 09:30 PM - Thread Starter
Quoted: 106 Post(s)
any thoughts as to why I would have Decoder problem now and why didn't have 1 before. Lastly how can I fix this problem. Thanks
post #4 of 28 Old 04-02-2013, 09:44 PM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
Not necessarily your issue but many people have found that a recent Microsoft Update, KB2670838 can cause playback issues.
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
post #5 of 28 Old 04-02-2013, 09:56 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
You have other movies that are in mkv and work fine? If so, download media info and see what differences are between the working mkv and the other 3 that don't work.
post #6 of 28 Old 04-03-2013, 08:11 AM - Thread Starter
Quoted: 106 Post(s)
I download media info, so exactly what am I looking for in the file and where can identify this? Thanks
post #7 of 28 Old 04-03-2013, 08:48 AM
sitlet's Avatar
The most important thing you are looking for is resolution, codec, and bitrate. Compare these three to the ones where they are working.
sitlet is offline
post #8 of 28 Old 04-03-2013, 08:49 AM
staknhalo's Avatar
Quoted: 383 Post(s)
Liked: 241
You can try a demux and remux of the files first - see if that solves the issue.
staknhalo is offline
post #9 of 28 Old 04-03-2013, 12:42 PM
Vlad Theimpaler's Avatar
Liked: 33
Originally Posted by stamina1914 View Post
A few weeks ago I posted that all of a sudden 3 movies in my MKV Ripped library of movies are all of a sudden giving me a Window can not play video error... the movies used to play well...
I've made a couple of highlights from the original post as a prelude to my $0.02.
When a system that "used to play well" mysteriously degrades to an "all of a sudden" it now doesn't work situation, I always say: hopefully you had a backup image of the system partition made while it was still working. Because restoring back to the good state from a backup image is much easier than trying to debug a problem that appears out of nowhere.
If you don't have a backup, do you at least have a system restore point in Windows that you can revert back to? I'd try that first.
Vlad Theimpaler is offline
post #10 of 28 Old 04-03-2013, 07:34 PM - Thread Starter
Quoted: 106 Post(s)
SO I am a newbie to all of this. I followed Assassins Guide so I do have a system restore disk, but alas I just made the restore disk so it would have the problem. So back to my original question. Would re ripping help? I will take sharks advice and see if I indeed have that new windows update, If I do i will try to unistall it.
post #11 of 28 Old 04-03-2013, 07:36 PM - Thread Starter
Quoted: 106 Post(s)
So walk me through this, there were tons of options in media info. i add the file to it and then what, is there a scan button or something. Let's say that I did find an issue with the resolution or the codec etc, how do I go about fixing it.
Best
post #12 of 28 Old 04-03-2013, 08:13 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Once you drag/drop the mkv into media info all the info should be there. The two main things you want to compare is the video and audio stream. Post a screenshot or list what media info shows, this will help us determine what decoders you need.
post #13 of 28 Old 04-03-2013, 10:10 PM - Thread Starter
Quoted: 106 Post(s)
Here is what I got back for what I got back:
Thoughts?
General
UniqueID/String : 281491944730356121237885748615964012465 (0xD3C56065518EFCAE2DD2433004082FB1)
CompleteName : N:\MEDIA\HD MOVIES\300 (2006) [Unknown] [R] [voted 7.8] [Fantasy]\300 (2006) [Unknown] [R] [voted 7.8] [Fantasy].mkv
Format : Matroska
Format_Version : Version 2
FileSize/String : 15.1 GiB
Duration/String : 1h 56mn
OverallBitRate_Mode/String : Variable
OverallBitRate/String : 18.6 Mbps
Encoded_Date : UTC 2013-01-03 05:59:33
Encoded_Application : MakeMKV v1.7.9 win(x64-release)
Encoded_Library/String : libmakemkv v1.7.9 (1.2.0/1.1.0) win(x64-release)
Video
ID/String : 1
Format : VC-1
Format_Profile : Advanced@L3
CodecID : V_MS/VFW/FOURCC / WVC1
CodecID/Hint : Microsoft
Width/String : 1 920 pixels
Height/String : 1 080 pixels
DisplayAspectRatio/String : 16:9
FrameRate_Mode/String : Constant
FrameRate/String : 23.976 fps
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
ScanType/String : Progressive
Compression_Mode/String : Lossy
Language/String : English
Default/String : No
Forced/String : No
Audio
ID/String : 2
Format : TrueHD
CodecID : A_TRUEHD
BitRate_Maximum/String : 3 267 Kbps
Channel(s)/String : 6 channels
ChannelPositions : Front: L C R, Side: L R, LFE
SamplingRate/String : 48.0 KHz
BitDepth/String : 24 bits
Compression_Mode/String : Lossless
Title : 5.1
Default/String : Yes
Forced/String : No
post #14 of 28 Old 04-03-2013, 10:19 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Any of your other movies have truehd audio?
post #15 of 28 Old 04-03-2013, 11:21 PM
Dodgexander's Avatar
Also interesting it's vc1. Any of the working rips have vc1 or do they all have h264?
Natalya Simonova: Do you destroy every vehicle you get into?
James Bond: Standard operating procedure. Boys with toys.
Goldeneye
Dodgexander is offline
post #16 of 28 Old 04-04-2013, 08:12 AM - Thread Starter
Quoted: 106 Post(s)
Yes Several
300*
Batman Begins*
Dark Knight*
Bourne Supremacy
Inception
Hangover*
Pitch Black
Chronicles of Riddick
Terminator Salvation
These are the movies that I have that were ripped with the VC-1. The ones with the " * " denote the ones where I get the Windows can not play message, Please note that all movies played after I ripped them and subsequents months later.
post #17 of 28 Old 04-04-2013, 12:59 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Yes Several
300*
Batman Begins*
Dark Knight*
Bourne Supremacy
Inception
Hangover*
Pitch Black
The 4 movies with the asterisks use TrueHD audio while the rest of those movies use DTS-HD MA according to the Bluray discs. Do you have a codec pack installed like Shark007?
post #18 of 28 Old 04-04-2013, 07:23 PM - Thread Starter
Quoted: 106 Post(s)
I currently have LAV installed and the videos did play before.
post #19 of 28 Old 04-04-2013, 07:47 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Have you recently installed any other decoders?  You can reinstall LAV but I don't think it will fix anything. Doesn't hurt to try, you never know...
post #20 of 28 Old 04-04-2013, 08:17 PM - Thread Starter
Quoted: 106 Post(s)
Ok i'll try that as a matter of fact I was going to add some extenders to my build and I believe the Shark Codecs are suppose to be better for this, So I'll try that option. Having said this, I do not think I added any new decoders, atleast not on purpose. The last thing that I added was my ceton infinitv 4 to my build. I don't know if this could have affected anything.
post #21 of 28 Old 04-05-2013, 06:50 AM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
Have you tried uninstalling this update yet?
If it is not the cause of your issue, no harm done. Windows Update will offer it to you for installation next time you go to WU.
Shark007 is offline
post #22 of 28 Old 04-05-2013, 03:09 PM - Thread Starter
Quoted: 106 Post(s)
I did, but unfortunately nothing.
post #23 of 28 Old 04-07-2013, 03:57 AM
zagnutty's Avatar
Hmmm. It could also be a sign something is wrong with the drive. Mine recently started acting up and not wanting to play files that used to play just fine a couple months ago. As it turns out, my suspicions were confirmed and the drive is dying.
Have you run chkdsk to rule this out as the problem?
zagnutty is offline
post #24 of 28 Old 04-07-2013, 01:55 PM - Thread Starter
Quoted: 106 Post(s)
Thanks for your help folks. I go it to work. After uninstalling the windows up along with LAV codecs, I down loaded the Shark Codecs and now my movies are playing. If someone could give me a break down as to why this happen and why Shark Codecs worked and LAV stopped working, it would be great.
post #25 of 28 Old 04-07-2013, 02:17 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Did you ever reinstall the LAV filters?
post #26 of 28 Old 04-07-2013, 05:02 PM - Thread Starter
Quoted: 106 Post(s)
No because I got the XBOX 360 extender and I knew I needed the shark codecs.
post #27 of 28 Old 04-07-2013, 05:23 PM
zagnutty's Avatar
This is why I don't mess with codec packs. The only things I have installed are CoreAVC and AC3Filter.
zagnutty is offline
post #28 of 28 Old 04-08-2013, 03:47 PM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
Your inability to read before posting is the only thing that matches your knowledge concerning the Shark007 codecs. Your posted codec solution would not have solved the problem. Had you read about what the problem actually was, you may have been able to figure that out on your own before posting.
Thanks for your help folks. I go it to work....
Installing the codecpack solved the issue.
There are so many 'fixes' incorporated into the installer and Settings Application that it would be impossible to tell which actually fixed your issue. FYI, the uninstaller does not remove any of the fixes because the fixes simple set the registry back to Microsoft defaults where other softwares MAY have modified them.
Shark007 is offline
Reply Home Theater Computers
