NO SOUND PC coax to receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-03-2013, 01:07 PM - Thread Starter
Kaspar1985's Avatar
Hey out there.. I have a problem... I jsut bought a yamaha rx.v359, because my old denon avr2105 had a little fire in it.. I then hooked up the yamaha to my pc with a coax cable, which worked fine with the denon. But with the yamaha no sounds comes out..
on the yamaha where the coax input is. It says DVD. So i choose the DVD source on the display.. and set it to DTS.. no sound
I have tried changning the 192kHz/24-Bit on the computer but no sound..
I have tried to see if the DTS would play on any of the other sources. no sound.
I have tried and tried to push every button but no f........... sound..
Kaspar1985 is offline
post #2 of 6 Old 04-03-2013, 01:18 PM
Sammy2's Avatar
Quoted: 151 Post(s)
Liked: 202
Where did you acquire this receiver? It seems to be an older model. Was it used? Maybe it is broken. What output on the PC are you using?
Sammy2 is offline
post #3 of 6 Old 04-03-2013, 01:20 PM
erickotz's Avatar
Liked: 30
If you set it to PCM and 44.1/16, does that work? Also on some receivers (like my Onkyo) you have to assign the digital inputs to sources - did you do that if required?
Quality Assurance Manager, Ceton Corporation
erickotz is offline
post #4 of 6 Old 04-03-2013, 01:33 PM - Thread Starter
Kaspar1985's Avatar
Erhm pcm.. Is that on the receiver?
When you say 44.1/16 you mean the khz and bit?
The KHZ i have tried to change on the PC... 44, 96 192.. The receiver should support 192...
post #5 of 6 Old 04-03-2013, 01:34 PM - Thread Starter
Kaspar1985's Avatar
well i bought is used for 100 dollars.. im using the same as i id with the denon.. if thats what you are asking.. or are you asking about the khz
post #6 of 6 Old 04-03-2013, 01:44 PM
Mrkazador's Avatar
Quoted: 187 Post(s)
Liked: 341
If you bought it used then do a factory reset. The digital input may have been reassigned (or disabled?) to a different input so a reset will revert it back to its default settings. In the audio decoder you are using for your media player, make sure bitstream is enabled. If you have a dvd or bluray player, have you tried using that?
Mrkazador is online now
Reply Home Theater Computers
