Maybe your perception of vibrant was just an indication of how much there is to learn when you are first exposed to all the options for 10' interfaces
I have mixed feelings about the amount of "slapped together" WMC addons that were pay options, which seemed to get a lot of "worth $X" approvals. While some were good polished solutions, others don't appear to have lived up to there value
Time Warner's online channels and Netflix are ruined by the abomination that is Silverlight. Massive stuttering on all 3 of my PCs no matter what I do.
I bought a $40 MK808 and it functions much better than my quad core PC for online streaming. It does not bitstream audio right now but the trade off is worth it.
The HTPCs are too simple now that the iGPU already handles HD audio and 3D video.
As was mentioned earlier, we've moved on to building multi-TB storage servers to feed our HTPC.
My first HTPC had an Intel C2D E8400 and didn't support HD audio without an add-in card, no HDMI 1.3, and there was only one cablecard tuner to choose from (ATi single tuner card). Plus everyone was using something like a WD Green HDD. Instead of shoehorning all those missing bits into my HTPC, I just retired its guts into a media server and build a Sandy Bridge with a Ceton tuner and SSD OS drive. Now there is very little reason to do anything else to the HTPC I have since it does what it is supposed to do and there really is no need to tweak or upgrade it. Maybe when 4k HD hits then I'll have an excuse.
Now with a storage server there is plenty to tweak...
Sure beats the days of old. My first DVR was on XP, used GB-PVR and an external guide we ended up having to pay for, an ATI Theater Pro 650 Hybrid tuner and two Hauppauge PVR-150s, I don't remember what all processor and hard drive it used, I do remember it had an ATI HD video card, don't recall the model. And getting that ATI remote to work with GB-PVR was a serious pain. Getting a system like that back in the day to have any sort of WAF took a ton of effort. You really had to know what you were doing, or had to have the support of a lot of patient people back then.
I can remember the ATI video drivers getting hosed back then and having to start all over from scratch. It took several hours to get everything working right again. Now I can set up a complete system in no time at all, starting from a bare hard drive to finished system.
My first HTPC was PIII with Pinnacle TV tuner and Pinnacle Studio TV "DVR software", which back then wasn't even called DVR, running off Windows 98.
One thing I liked about Pinnacle Studio TV, is that you could have 6 or 8 little screens in one screen showing what was on on all those channels at the same time. CPU useage woudl spike to a solid 100%, but it worked if you had as many tuners. I only had 2, so I could only do 2, and if you did more, it would scan, and freeze frame different channels.
Connecting TV was a nightmare, but worked.
Win XP MCE was a major headache remover in terms of HTPC, at least for me.
I am pretty sure I chose Pinnacle over ATI, because Pinnacle supported remote control, while ATI I didn't think did. Because. then and still I firmly believe if you are not using a remoteand just connecting a PC to a TV , it is nothing more than a PC connected to a TV. But a PC connected to a TV with a remote (no keyboards, no mice) is an HTPC.
I'm a computer person, built many, watched TV on my Mac IIx without issue about 20 years ago, but I can't say I am real pleased with my HTPC experience over the last 5 years. I have cable TV and internet (TimeWarner) with a DVR included. Approaching the ease of use of that DVR has yet to occur, and seems a constantly moving target, so I continue to pay each month for a DVR I assumed I would be rid of two years ago. The potential for playback of a wide variety of media files has been what has kept me going with the HTPC.
When HTPC works, its really very nice. I have hundreds of movies ripped, many thousands of music files, but its like owning an old sports car, constant tinkering, poor reliability, but again great when it works.
I would not recommend it to anybody normal, and doubt I would repeat it knowing what I know now if starting over. I would build a straight up PC for fun and games, a network storage device, and use something like one of the DLNA BluRay players to feed the TV and AVR.
I had DirecTV and then got a Ceton cablecard tuner for my HTPC. The plan was to use it with Comcast during both the 30 day return period and free cancellation period. After just a few days of using the cablecard tuner I called an cancelled DirecTV. Maybe it is different with TimeWarner, but I have no issues with WMC's DVR experience with cable.
I do not have a problem playing back Cable TV with my HTPC. I do it every single day and rarely, if ever, have issues. The WMC DVR is very good and is not a moving target.
My ATI came with a remote. A big, clunky RF unit with very rubbery buttons. It worked, it was just a gigantic PITA to get it there. The DVR software it came with was horrible, therefore I made the switch to GB-PVR. Then I found out GB-PVR does not work with the AiW because it doesn't have hardware decoders. So then I purchased the ATI 600, which worked great. Then some PVR-150s to add more tuners, then the HDHR Dual, and now I've added an HDHR Prime...
My issues are mostly my own fault, but none the less still issues. I am REAL close, but not ready for a new TV, so I need to support Svideo for the old one. Likewise my AVR is the last model prior to HDMI, and requires SPdif for digital input. Svideo output requires cards with questionable Win7 drivers, but SPdif is more of a problem.
There are lots of ways around my issues, but it was a LONG learning process to get to this point as so many things it seemed logical to work, didn't.
HDMI all the way, everything new and current version, should all work, but for how long? I see HTPC as a passing thing, not that future PC's won't have the same functions, but it would be like talking about a car "with a automatic transmission" nothing novel and fully integrated, it won't be HTPC, just PC with functions all expected.
I actually can see the HTPC going away in place of something like a PS4 or Xbox 720, but not as the "central media hub". For the center I see a media server and then these units accessing that media at each location in addition to whatever online streaming they offer. All I really need is a dumb and pretty front-end with access to a cablecard tuner.
IDK about that. I can build a PC for not much more than what those cost and can do so much more with it, especially since I do not play video games. Gamers might have a different concept than I do though.
PC was a good 10 years behind the early Mac in video. As I recall my card was a Radius of some kind with a resizeable window I could place anywhere on the screen and watch live video from a camera or VCR etc. The trick was the video never left the card except for spooling or capture, which was limited with no compression at the time.
Microsoft isn't the moving target, its the cable industry with cable cards, then the demand video stuff that requires a box to go with the card. I bought a HomeRun Prime, got the cable card, got too busy to hook it up OR watch TV if I did. Hopefully that will change soon and I will be updating and watching again.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
