What do you do with your WTV/DVRMS recordings? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 04-06-2013, 06:14 PM - Thread Starter
MrZoid's Avatar
Quoted: 43 Post(s)
Liked: 46
I'm talking about non-flagged/encrypted recordings of course.
As of Thursday I have two HTPCs that can record OTA stations, which is fine for us. I set a scheduled task to convert the WTV files to DVR-MS and dump the files to my file server.
I'd love to be able to stream them to my phones/tablets, but Plex doesn't seem to support DVR-MS.
Has anyone found a way to auto convert either file type to another container? Even if it means compression.
Mr Zoid
A GF that bought me a PS3 and a HD-A2? I'm a lucky man!
MrZoid is offline
post #2 of 11 Old 04-06-2013, 06:19 PM
lockdown571's Avatar
Quoted: 66 Post(s)
Liked: 93
Mr Zoid
Why do you convert them to DVR-MS files? Plex does work with WTV files. I don't know about DVR-MS. What Plex doesn't support is Microsoft's wonky metadata. Have you tried adding the recordings at home videos?
lockdown571 is offline
post #3 of 11 Old 04-07-2013, 11:34 AM - Thread Starter
MrZoid's Avatar
Quoted: 43 Post(s)
Liked: 46
I'm running 0.9.9.13 and it doesn't see either file type.
Is there something I just don't have turned on?
The reason I convert them is most programs I've tried for transcoding can work with DVR-MS but not WTV.
Mr Zoid
MrZoid is offline
post #4 of 11 Old 04-07-2013, 05:17 PM
Quoted: 66 Post(s)
Liked: 93
How did you add them to Plex? You can't add them as TV shows. You have to add them as home videos and then choose the personal media agent or something like that.
post #5 of 11 Old 04-08-2013, 08:01 AM - Thread Starter
MrZoid's Avatar
Quoted: 43 Post(s)
Liked: 46
I'll give that a shot.
I didn't find that info when I was searching around.
Mr Zoid
MrZoid is offline
post #6 of 11 Old 04-08-2013, 09:19 AM
JDLIVE's Avatar
Quoted: 99 Post(s)
Liked: 57
Send a message via Yahoo to JDLIVE
I usually just watch them and delete them afterwards. smile.gif I do archive some college sports and movies, in that case I edit out the commercials with VideoRedo and then re-encode to H264. VRD does have some kind of batch processing included with it, though I've never used it myself.
JDLIVE is offline
post #7 of 11 Old 04-08-2013, 10:03 AM
pittsoccer33's Avatar
Quoted: 650 Post(s)
Liked: 432
video redo all the way. i record a lot of movies on Encore, MGM, TCM, and The Movie Channel and I use it to clip the beginning and end of the files. TCM tends to windowbox everything as a way to deal with overscan, so I usually have to reencode those (and use h264 while I'm at it) to fix those.
for interesting documentaries and concerts i cut out ads and usually just mux them back into wtv.
every once in a while I'll run a bunch of stuff through handbrake overnight to shrink them and turn them into h264 mkvs.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #8 of 11 Old 04-08-2013, 10:48 AM
user4avsforum's Avatar
I delete >99% of the recorded files.
For the few things I want to keep I have used videoredo to edit the start/stop time. I have re-encoded to reduce the size.
user4avsforum is offline
post #9 of 11 Old 04-08-2013, 11:38 AM
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
Record - watch - delete.
On the rare occasions I save a program I too use VideoReDo to trim the beginning & ends and also edit commercials.
Mike99 is offline
post #10 of 11 Old 04-08-2013, 11:55 AM
captain_video's Avatar
Quoted: 524 Post(s)
Liked: 341
Same here. Record, watch, delete. I rarely have time to watch a show twice, nor do I have a desire to most of the time. I also never watch anything on a screen smaller than 36" if I can help it. HDTV was meant to be enjoyed on a big screen. Watching HD on a small screen just doesn't make sense to me.
There is a free app to convert WTV files to DVR-MS. Run a search over at the Green Button and I'm sure you'll find a link to it. I believe it's called WTV Converter or something to that effect. The latest VideoReDo version works with WTV files directly and lets you convert them to DVR-MS or just about any other mpeg format.
captain_video is offline
post #11 of 11 Old 04-08-2013, 12:53 PM
cburbs's Avatar
Quoted: 94 Post(s)
Liked: 29
Have you looked at MCEbuddy? It has alot of nice features. I use it to rip shows to my server so that my wd tv live can play them. The nice thing now is there is a setting in mcebuddy that if you delete it off of your main box it will remove the file from the server as well.
"You’re KILLIN’ ME Smalls! "
Sony 55EX500 Settings
cburbs is offline
Reply Home Theater Computers
