Plasma Flicker? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-06-2013, 10:41 PM - Thread Starter
gonzo90017's Avatar
Quoted: 43 Post(s)
I recently purchased a LG 50PM9700 plasma that replace and old Toshiba LCD. One thing I noticed is whenever I have my HTPC set at 60hz I can see it flicker (I guess that's what it's called?) But if I set it to 24hz I don't see any flicker at all. 24hz is fine when watching my bluray rips but 98% of the time the HTPC is used to playback Live and Recorded OTA using Mediaportal. Is this just one of the drawbacks of using a plasma instead of and LCD or is there something i'm missing? The HTPC is connected through HDMI.
gonzo90017 is offline
post #2 of 5 Old 04-06-2013, 11:49 PM
Chronoptimist's Avatar
Liked: 543
From doing a quick search, this Plasma seems to display 24p signals at 72Hz (24x3) and it will be showing 60Hz at 60Hz. (no plasma will be refreshing at 120Hz - as the refresh rate is increased, image quality decreases)
Flicker is one of the reasons I won't use a Plasma - even at 72Hz I see them flickering.
Chronoptimist is offline
post #3 of 5 Old 04-07-2013, 07:01 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 418
Plasma flickers because it has much faster pixel response time than any LCD. It is like the CRT tv. LCDs, even at 240hz, have noticeable slow pixel response time that you will never notice flickering even st 30hz. The trade off is smearing.
Unfortunately, the static content of a PC will make the flickering of a plasma very noticeable although it is less noticeable when displaying whole screen video.
Sent from my RM-820_nam_canada_246 using Board Express
Foxbat121 is offline
post #4 of 5 Old 04-07-2013, 11:25 AM
Liked: 543
That's not right at all. OLEDs don't flicker, and they have faster response times than Plasma by an order of magnitude. Plasmas flicker just because of the way they work. They create shades by pulsing the pixels on/off, they don't have variable brightness levels for each pixel. Most are now doing this at least 10 times per frame. (hence the "600Hz" marketing numbers when they are actually only displaying 60Hz)
post #5 of 5 Old 04-09-2013, 01:50 AM
Sean Hoyt's Avatar
Sample and hold (OLED/LCD) versus PWM plasma on/off.
Sean Hoyt is offline
Reply Home Theater Computers
