For motherboard with CIR header - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-08-2013, 12:25 PM - Thread Starter
TornadoTJ's Avatar
Quoted: 1722 Post(s)
Liked: 539
Where do I get the receiver portion of it?
TornadoTJ is offline
post #2 of 6 Old 04-08-2013, 12:31 PM
jhoff80's Avatar
Quoted: 398 Post(s)
Liked: 362
The only place I know of is shop.inteset.com, but which one you need does also depend on your motherboard brand.
XBL/Steam: JHoff80
jhoff80 is offline
post #3 of 6 Old 04-08-2013, 03:14 PM
Dark_Slayer's Avatar
Quoted: 729 Post(s)
Liked: 452
For Asrock link
For Intel link Edit: kind of similar, but not what you were looking for
Dark_Slayer is offline
post #4 of 6 Old 04-08-2013, 03:26 PM
jhoff80's Avatar
Quoted: 398 Post(s)
Liked: 362
That Intel link is actually something different, I believe. That's for the HTPC header, which enables HDMI-CEC and gives you the option of a recording LED.
XBL/Steam: JHoff80
jhoff80 is offline
post #5 of 6 Old 04-08-2013, 03:38 PM
Quoted: 729 Post(s)
Liked: 452
You are right, that would only work if the TV remote successfully passes the right controls to WMC
There's also this http://compare.ebay.com/like/330743850721?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar
post #6 of 6 Old 04-08-2013, 03:55 PM - Thread Starter
TornadoTJ's Avatar
Liked: 539
Interesting, I was thinking they would be a lot cheaper than the MCE USB solutions.
Reply Home Theater Computers
