MPC-HC MadVR jumpy playback after switching to new GPU. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-09-2013, 10:51 PM - Thread Starter
Shinyav's Avatar
I am currently using
MPC-HC
MadVR
LAV filters
I previously had a GTS450. Everything was fine. I have switched to a 7850 for significantly better gaming performance.
However, now the video in MPC jumps around a bit every 5-10 seconds. It just repeats a couple frames and then goes back to normal.
Any thoughts about what could be something I simply overlooked before I uninstall everything and start fresh?
Shinyav is offline
post #2 of 6 Old 04-10-2013, 08:53 AM
gtgray's Avatar
Quoted: 226 Post(s)
Liked: 146
MPC-HC
MadVR
LAV filters
Are you running Smooth Video on the Radeon?
The 7850 is nearly triple the performance of the GTS450.
Are you running 13.1 drivers?
Samsung 78" JS8600, Mits WD-92840 43" Samsung 43ku7000 - Lumagen Radiance XS, Martin Logan Motion 40s, Ascend Sierra 2s
58" Panny Plasma -DVDO DUO, Usher S520, JBL HLS-610, Definitive SM45, MusicHall Marimba
gtgray is offline
post #3 of 6 Old 04-10-2013, 01:56 PM - Thread Starter
Shinyav's Avatar
No I disabled smooth video.
yes latest drivers.
Shinyav is offline
post #4 of 6 Old 04-10-2013, 06:58 PM
gtgray's Avatar
Quoted: 226 Post(s)
Liked: 146
I don't have a 7850 but I did buy both an HD 7770 and an HD 7790. One of those cards will go into my workstation to replace a GTS-450 to run JRiver ROHQ... MadVR. I will see what happens. My main HTPC is currently running the 7770. I have cycled through the intel iGPU and a GTX 545. That box was used almost exclusively for ATSC and Ceton Cable under WMC. Intel looked okay but there were times it struggled performance wise. The Nvidia GTX has an audio bug with certain cable channels either playing commericals or any content from the specific channel. I really like the Nvidia and if JRvier MC was production ready to replace WMC for all my Live TV needs I would have switched over to JRiver instead of buying the Radeons.
It looks like JRiver is developing TV playback usability faster than I expected. MadVR for live TV is the bonus... but I will be quite unhappy if I find that MadVR just doesn't perfom as it should on the Radeon platform.
An overclocked HD 7850 is a stout GPU and should support a very high quality setting and playback with madVR.
gtgray is offline
post #5 of 6 Old 04-10-2013, 09:09 PM - Thread Starter
Shinyav's Avatar
yea even with jinc 4tab its only about 20% utilization. So I don't necessarily think that that is the problem. More most likely some setting in LAV or MPC
Shinyav is offline
post #6 of 6 Old 04-10-2013, 11:37 PM
Tong Chia's Avatar
Bring up the diag screen in MadVR (Control-J) when the video is running and see if any of the queues (decoding,render,presentation) drop to zero during the hiccup.
If any of the queues drop to zero try increasing the size of the affected queues
Tong Chia is offline
Reply Home Theater Computers
