gts450 hdmi output 24bit/9600ohz 2 channel audio problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-16-2013, 01:17 PM - Thread Starter
Lex vs Kingpin's Avatar
Hello,
I am having a problem with FOOBAR + WASAPI output.
Simply put, I am getting an "Unsupported stream format: 96000 Hz / 24-bit / 2 channels" error.
Connection is gts450 hdmi output > denon 987 receiver (hdmi1 - pure direct) > foobar 1.1.18 > wasapi (event or push doesn't matter) > stereo speakers
Could it be the hdmi version issue (OTOH denon 987 is only 1.1 or 1.2), but tech specs mentions 24bit/96000hz input.
I really appreciate any help on the matter.
Best regards and thanks in advance...
Lex vs Kingpin is offline
post #2 of 3 Old 04-16-2013, 02:10 PM
N3W813's Avatar
Quoted: 23 Post(s)
Liked: 70
If you check your HDMI audio connection properties, you can see what bit depths, frequencies, and formats the connection supports.
My ArgyllCMS/MadVR 3DLUT Creation Workflow
My Sharp Elite Movie THX AV Mode Settings
--Aug 2011 Set, 2.2 gamma [ link ]
--Nov 2012 Set, 2.2 gamma [ link ]
N3W813 is offline
post #3 of 3 Old 04-16-2013, 02:23 PM - Thread Starter
thanks for the reply.
it seems 96000hz is not supported (please see the attachment) by denon.
is there a way to remedy this problem? hdmi cable or anything else?
denon.jpg 45k .jpg file
Reply Home Theater Computers
