Smallest (and Quietest) Micro-ATX Case - AVS Forum | Home Theater Discussions And Reviews
post #1 of 24 Old 04-18-2013, 07:17 AM - Thread Starter
AnthonyB's Avatar
I've been trying to search on google for a while to no avail...
I would like the absolute smallest case possible with a Micro-ATX form factor.
Any ideas?
I checked on assassins blog and that's just not small enough.
AnthonyB is offline
post #2 of 24 Old 04-18-2013, 09:02 AM
user4avsforum's Avatar
If you want a truely small case you may have to be willing to make some minor case mods such as removing the PSU and replacing it with a Pico PSU.
I built a system using the Cooler Master Elite 100 Mini-ITX, this case actually holds a mATX board once you remove the provided PSU.
I built another system using a Raidmax mini-ITX/mATX case that also required removing the PSU and replacing it with a PicoPSU. This case also required flipping it from vertical to horizontal and adding some stick on feet.
user4avsforum is offline
post #3 of 24 Old 04-18-2013, 11:46 AM
rickcfer's Avatar
Quoted: 56 Post(s)
Liked: 29
rickcfer is offline
post #4 of 24 Old 04-19-2013, 06:57 AM - Thread Starter
AnthonyB's Avatar
I'd like a case the size of an Xbox.. These are too wide
AnthonyB is offline
post #5 of 24 Old 04-19-2013, 07:16 AM
chucky08016's Avatar
I too was shopping around for months looking at every possible mATX case trying to find the smallest possible. I settled on the the Silverstone ML03B (Same case that rickcfer posted a link for). This was quite honestly the BEST decision I could have made and have now replaced all of the HTPC's in the house using this case.
When coupled with a low profile CPU cooler ( I have one from Cooler Master) and a SSD hard drive, this PC is nearly dead silent!!
chucky08016 is offline
post #6 of 24 Old 04-20-2013, 02:40 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
I'd start by looking at Silverstone - small and high quality. I suppose there could be other smaller options, but quality is something too.
lespurgeon is offline
post #7 of 24 Old 04-21-2013, 12:59 AM
DavidT99's Avatar
Quoted: 13 Post(s)
In that case you should be looking at miniITX case's and motherboards.
David
DavidT99 is offline
post #8 of 24 Old 04-21-2013, 07:39 AM
assassin's Avatar
Quoted: 155 Post(s)
Liked: 261
Mini itx or nuc. Micro atx is going to be too big for what you want.
assassin is offline
post #9 of 24 Old 04-21-2013, 09:15 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
Have a look at the Realan mini-ITX cases at the end of Assassin's hardware guide. They are high-quality and the size you're looking for.
StardogChampion is offline
post #10 of 24 Old 04-21-2013, 05:45 PM
Chronoptimist's Avatar
Liked: 543
What are your requirements? Because you mention an Xbox, I am wondering if this is going to be a dual-purpose HTPC/gaming rig? Unfortunately, there are not great m-ITX cases like we have in some pre-built machines.
Currently, I don't think there is anything smaller than the Falcon Northwest Tiki, or the DigitalStorm Bolt as far as high-end gaming is concerned. At the mid-range, there is also the Alienware X51.
If you are just looking for an all-in-one HTPC, I don't think there are any better options than the Mac Mini, unfortunately. Everything else seems to have a huge power brick rather than an integrated power supply - though the Mini now lacks an optical drive, which can be a nuisance depending on your needs.
It's too bad that a lot of manufacturers are stuck thinking about the traditional PC tower/desktop form factors, when there could be much better use of the space if they considered using a "non-standard" layout.
Chronoptimist is offline
post #11 of 24 Old 04-21-2013, 06:16 PM - Thread Starter
AnthonyB's Avatar
It'll be just for movies and other video. no gaming. Entirely sick of my Xbox, it sounds like a jet engine. If I didn't have a spare mobo and chip, I'd think about the echo....
Don't really care about a power brick (pico psu) as long as it's small.
AnthonyB is offline
post #12 of 24 Old 04-21-2013, 08:32 PM
Quoted: 93 Post(s)
Liked: 160
So you already have a motherboard and CPU and you're trying to find a case for it? That would be helpful info to divulge when asking for suggestions. Which motherboard and CPU?
post #13 of 24 Old 04-21-2013, 10:15 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
renethx is offline
post #14 of 24 Old 04-22-2013, 05:39 AM - Thread Starter
AnthonyB's Avatar
I thought that was implied in the original post.
ASRock B75M-DGS
Intel Celeron G1610
AnthonyB is offline
post #15 of 24 Old 04-22-2013, 06:26 AM - Thread Starter
AnthonyB's Avatar
I like those "In wins"!
AnthonyB is offline
post #16 of 24 Old 04-22-2013, 06:45 AM
Quoted: 93 Post(s)
Liked: 160
Haven't used either of these Apex micro-ATX HTPC cases but they're about as small as it gets and get decent reviews.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811154062
http://www.newegg.com/Product/Product.aspx?Item=N82E16811154087
post #17 of 24 Old 04-23-2013, 03:22 PM
Ducati 1098's Avatar
If you can wait a better solution the NUC is in the pipe from Gigabyte. Features USB 3 and models with core i3, i5, and i7. Plus it comes with a power cord.
http://www.tomshardware.com/news/Gigabyte-Brix-ZBOX-nano-mini-PC-HTPC,22017.html
Ducati 1098 is offline
post #18 of 24 Old 04-24-2013, 01:32 AM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 217
Dell has sales all the time on Refurb X51. Check their outlet store and look for coupons on Slickdeals. I have seen it as low as $400 with an i7, 1TB HDD, Blu-ray, and a discrete GPU. I don't think you could even build a machine with those parts for that cheap. About the same size as a 360. They were overpriced when they first came out but the Outlet models are a steal IMO.
http://www.theverge.com/2012/2/3/2768359/alienware-x51-review
StinDaWg is offline
post #19 of 24 Old 05-06-2013, 07:36 AM - Thread Starter
AnthonyB's Avatar
Originally Posted by renethx View Post
There are several In Win BL-Series microATX cases of 365mm width.
BL040
BL672
BL631
BL641
BL647
Where do you get the iR sensors for those cases? I haven't seen one for sale, been scouring the internet for DAYS. Particularly the BL040.
AnthonyB is offline
post #20 of 24 Old 05-06-2013, 07:52 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
inteset.com has an IR receiver specifically designed for ASRock CIR motherboards (that supports power on from S5; case mode required, of course).
Or ASRock Smart Remote, easy to attach.
renethx is offline
post #21 of 24 Old 05-06-2013, 08:31 AM - Thread Starter
AnthonyB's Avatar
Hmm...
The In Wins say that they actually have a iR sensor for their case, or at least the BL040.
I'm calling. Will post results back.
I just want a small adapter, I don't even care if it sticks out the USB port, but not something that has a 20' cord attached to it like the one from MS..
I have a harmony remote already programmed, so I don't even care about the remote control.
AnthonyB is offline
post #22 of 24 Old 05-06-2013, 09:33 AM
Dark_Slayer's Avatar
Quoted: 721 Post(s)
Liked: 449
Are you sure that wasn't an un-honored price mistake? I'd be on that like white on rice
Dark_Slayer is offline
post #23 of 24 Old 05-06-2013, 02:21 PM - Thread Starter
AnthonyB's Avatar
I snagged a genuine MS USB iR adapter that I know works with my Harmony for $1.04 on ebay
AnthonyB is offline
post #24 of 24 Old 05-09-2013, 07:29 PM - Thread Starter
AnthonyB's Avatar
A huge THANK YOU again to renethx. That inwin case was perfect..
I figured I'd thank you publicly this time.
AnthonyB is offline
Reply Home Theater Computers
