Broke my HDMI port. Any options? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 29 Old 04-19-2013, 07:57 AM - Thread Starter
hollatbk's Avatar
So I was moving my HTPC around the other day and the HDMI cable got caught and bent/cracked the HDMI port on the MoBo. Do I have any options other than replacing the MoBo? Right now I'm running DVI > HDMI and Optical.
CPU - Sandy Bridge LGA1155 (3D) Intel i3-2100
MoBo - GIGABYTE GA-Z68MA-D2H-B3
Newegg isn't carrying the MoBo anymore so If I have to replace the MoBo all together what should I get?
hollatbk is offline
post #2 of 29 Old 04-19-2013, 08:02 AM
AnthonyB's Avatar
Just get a gt430
AnthonyB is offline
post #3 of 29 Old 04-19-2013, 08:02 AM
Toys7505's Avatar
Quoted: 69 Post(s)
Liked: 26
Can you post a pic of the damaged HDMI port?
Toys
Denon AVR-3311CI, Denon DVP-602CI, B&K Reference 200.7 S2, Belkin PF60
Sony BDP-S5000ES, Silverstone HTPC (6 Tuner DVR & 10 TB Media)
PSB Stratus Minis, PSB Stratus C6, PSB Alpha S surround, James Subwoofer EMB-1200
Sharp LC-70LE755U, Harmony 880 Remote
Toys7505 is offline
post #4 of 29 Old 04-19-2013, 08:26 AM - Thread Starter
hollatbk's Avatar
Yeah. I'll get a picture tonight when I get home.
hollatbk is offline
post #5 of 29 Old 04-19-2013, 08:26 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Buy a cheap $15 Radeon 6450 silent video card.
Profit.
Mfusick is offline
post #6 of 29 Old 04-19-2013, 08:27 AM - Thread Starter
hollatbk's Avatar
Originally Posted by AnthonyB View Post
Just get a gt430
Tell me more about this. Does it support 3D?
hollatbk is offline
post #7 of 29 Old 04-19-2013, 08:37 AM - Thread Starter
hollatbk's Avatar
Profit.
If I just bought a cheap video card with HDMI would I still be able to playback 3D?
hollatbk is offline
post #8 of 29 Old 04-19-2013, 08:46 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Provided the card supports 3D then yes of coarse .
Mfusick is offline
post #9 of 29 Old 04-19-2013, 08:51 AM - Thread Starter
hollatbk's Avatar
hollatbk is offline
post #10 of 29 Old 04-19-2013, 08:56 AM
AnthonyB's Avatar
The gt430 supports 3d. I use it for my 3d viewing
AnthonyB is offline
post #11 of 29 Old 04-19-2013, 08:57 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
What Player do you use?
Sammy2 is offline
post #12 of 29 Old 04-19-2013, 09:00 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Don't most video cards support 3d
Mfusick is offline
post #13 of 29 Old 04-19-2013, 12:27 PM
erickotz's Avatar
Liked: 30
Just replace the HDMI port on the board. Shouldn't be too bad to solder
Quality Assurance Manager, Ceton Corporation
erickotz is offline
post #14 of 29 Old 04-19-2013, 04:11 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
If its just bent then you can have someone buy a new port and solder it to the board. If it was ripped off then the traces/pads could be damaged and will be a nightmare to repair.
Mrkazador is offline
post #15 of 29 Old 04-22-2013, 06:37 AM
AnthonyB's Avatar
PowerDVD 12
AnthonyB is offline
post #16 of 29 Old 04-22-2013, 07:04 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
PowerDVD 12
Thank you. I guess you play from disc rather than ripped to a HDD then?
Sammy2 is offline
post #17 of 29 Old 04-22-2013, 09:58 AM
AnthonyB's Avatar
Well.. You can get AnyDVD to play Cinevia protected discs with PowerDVD
AnthonyB is offline
post #18 of 29 Old 04-22-2013, 11:28 AM
Symbios's Avatar
What's wrong with your current DVI to HDMI solution? That's how I have my HTPC hooked up since the DVI port is much more durable. Does your board not output audio over DVI?
Symbios is offline
post #19 of 29 Old 04-22-2013, 01:06 PM
AnthonyB's Avatar
DVI is Video only.
AnthonyB is offline
post #20 of 29 Old 04-22-2013, 01:33 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
DVI is Video only.
On some video card, DVI port carries audio as well.
Foxbat121 is offline
post #21 of 29 Old 04-23-2013, 01:02 AM
AnthonyB's Avatar
what is the point if it's not standard and no TV or receiver will understand there is audio.
http://m.cnet.com.au/does-dvi-carry-audio-signals-as-well-as-video-339270821.htm?redir=1
My guess is, you may be mistaken.
AnthonyB is offline
post #22 of 29 Old 04-23-2013, 01:12 AM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
He is correct, there are video cards that can output HD audio through dvi using the supplied DVI/HDMI adapter. Any TV or receiver will get audio perfectly fine using this adapter.
Only specific video cards can do this so don't expect audio from a 10 year old GPU.
post #23 of 29 Old 04-23-2013, 01:17 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
DVI port may or may not carry audio. It's up to the mb manufacturer. It looks like it does not in the present case. (Or hollatbk just didn't try to send audio over DVI?)
renethx is offline
post #24 of 29 Old 04-23-2013, 05:30 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
DVI-D (means digital) and HDMI have the exact same wires. Whether or not it carries the audio or not is up to the source as long as the other end is HDMI port. In fact, IIRC, audio is carried on the same wires that video goes. So, it is purely a protocol difference. There is nothing non-standard about it.
post #25 of 29 Old 05-14-2013, 05:52 PM
AnthonyB's Avatar
There are no TV or receiver models that use dvi audio, so it's just a waste.
I read that ATi has a proprietary dvi which includes an hdmi dongle for audio.
Again, it's proprietary, not a standard.
AnthonyB is offline
post #26 of 29 Old 05-14-2013, 06:04 PM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
you need a cable that is dvi on the source end and hdmi on the tv end. i learned this by accident a few years back but it does work.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #27 of 29 Old 05-14-2013, 06:06 PM
AnthonyB's Avatar
With what setup?
AnthonyB is offline
post #28 of 29 Old 05-14-2013, 10:33 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
I tested literally dozens of dGPU / iGPU and found that
- AMD dGPU: DVI supports audio with this proprietary DVI-HDMI adapter.
- AMD iGPU: DVI supports audio with any DVI-HDMI adapter.
- NVIDIA dGPU / iGPU: DVI supports audio with any DVI-HDMI adapter.
There was no exception with the models I tested.
- Intel iGPU: Up to the motherboard. For example,
-- Intel mb: No audio over DVI.
-- ASRock mb: DVI supports audio with any DVI-HDMI adapter.
renethx is offline
post #29 of 29 Old 05-15-2013, 07:15 AM
Quoted: 648 Post(s)
Liked: 426
With what setup?
It was a Gigabyte GA-73PVM-S2H motherboard and a dvi to hdmi cord I bought at Walmart. Onboard Geforce 7100 graphics. Worked with a few different tvs.
Reply Home Theater Computers
