HTPC 1080p mkv audio & video stuttering - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 04-20-2013, 12:52 AM - Thread Starter
megrog2's Avatar
I have a G540 cpu based htpc with 4gb of ram built from assassin's guide. I have my media server on a Gigabit LAN switch with my htpc. I am using shark's latest codec pack configured using assassin's guide playing through wmc and mb. I'm only getting stuttering for my 1080p mkv's and it happens as soon as I play the file and will continue through out the movie. The stuttering does not happen happen when I play DVD quality mkv's. I'm at my wits end with trying figure out what's causing the stuttering, please help.
megrog2 is offline
post #2 of 16 Old 04-20-2013, 05:14 AM
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
Could be a network issue. Try to store one directly on the htpc and play it back to rule that out.
assassin is online now
post #3 of 16 Old 04-20-2013, 12:32 PM - Thread Starter
megrog2's Avatar
Yea def a network issue 1080p MKV played perfectly on locally on the htpc. Any suggestions on what to take a look at? I have flow control enabled, jumbo frames disabled, 1.Gbps full duplex on both the HTPC and the Media server. I did notice that Energy efficient ethernet is enabled on the media server along with green ethernet.
megrog2 is offline
post #4 of 16 Old 04-20-2013, 01:49 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
renethx is offline
post #5 of 16 Old 04-20-2013, 03:32 PM - Thread Starter
megrog2's Avatar
Originally Posted by renethx View Post
Try to disable Interrupt Moderation.
Should I disable on the htpc or the media server?
megrog2 is offline
post #6 of 16 Old 04-20-2013, 03:39 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
What kind of speeds do you get when you transfer a file from the server to the htpc?
Mrkazador is offline
post #7 of 16 Old 04-20-2013, 05:23 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Usually both.
renethx is offline
post #8 of 16 Old 04-20-2013, 06:29 PM - Thread Starter
megrog2's Avatar
Usually both.
That was it! Disabling interrupt moderation stopped the stuttering. Thank you kindly.
Server to the htpc I got 38Mb/s, htpc back to the server I'm only getting 11.6Mb/s for some reason.
megrog2 is offline
post #9 of 16 Old 04-20-2013, 06:34 PM
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
I would make sure that all of your cables are Cat5e or Cat6. I would also make sure that all your network switches, routers, etc are indeed gigabit.
post #10 of 16 Old 04-20-2013, 09:22 PM - Thread Starter
megrog2's Avatar
Spoke to soon its still stuttering. I'll check the cables, I know my LAN switch is indeed Gigabit as I just purchased it to troubleshoot the stuttering.
megrog2 is offline
post #11 of 16 Old 04-20-2013, 09:36 PM
bulls's Avatar
Quoted: 76 Post(s)
Liked: 34
30 Mb/s on wired LAN ?? or MB/s ?
bulls is offline
post #12 of 16 Old 04-21-2013, 12:46 AM - Thread Starter
megrog2's Avatar
Yes wired 30Mb/s
megrog2 is offline
post #13 of 16 Old 04-21-2013, 01:45 AM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Somethings not right with your network connection, you should at least be getting 100 megabits. Is it possible to connect the htpc and server directly to the router for testing?
post #14 of 16 Old 04-21-2013, 12:01 PM - Thread Starter
megrog2's Avatar
My media server and my htpc are in the basement and I have this monoprice Gigabit LAN switch on my rack with all of my components on it. My DSL router is only 100Mb/s and it is two floors up, so I have a powerline adapter providing internet from the second floor to my rack in the basement.
I'm going to check all of my cables but I'm sure they are all cat 6 UTP as I just bought them, except for one I think. Also going to take everything else off the LAN switch expect the HTPC and the media server then test again.
megrog2 is offline
post #15 of 16 Old 04-21-2013, 01:30 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
I have a feeling that the powerline adapter is affecting the switch somehow. Can you remove it from the switch? You may need to manually set a IP address for the server and HTPC to connect to each other.
post #16 of 16 Old 04-21-2013, 04:23 PM - Thread Starter
megrog2's Avatar
So moved the htpc and the media server off the gb LAN switch and put them both on the four port gb switch that's on the powerline adapter. The stuttering stopped!
megrog2 is offline
Reply Home Theater Computers
