W8 Ceton InfiniTV Experience? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-20-2013, 11:28 PM - Thread Starter
hlkc's Avatar
I've been using my W7 Ultimate X64 HTPC with Ceton InfiniTV watching/recording Cable TV for years. It is once rock solid HTPC to me.
I do not have any tablet except iPad. Is it a good idea to move up to W8? Any W8 Ceton user here that can share with me their W8 Ceton InfiniTV experience?
hlkc is offline
post #2 of 8 Old 04-21-2013, 09:04 AM
mdavej's Avatar
Quoted: 2275 Post(s)
Liked: 992
Worked exactly like win 7 for the hour I was able to tolerate win 8.
mdavej is online now
post #3 of 8 Old 04-21-2013, 09:13 AM
bryansj's Avatar
Quoted: 1419 Post(s)
Liked: 645
Works fine for me. Only limitation is that the Win 8 driver doesn't allow for network tuner sharing. Just add StartIsBack if you don't like using Win 8.
bryansj is offline
post #4 of 8 Old 04-21-2013, 02:11 PM
mdavej's Avatar
Liked: 992
Unfortunately the missing start button is only the tip of the iceberg. For me, the damage they have done to every facet of windows is insurmountable, no matter how many add-ons and hacks you use. Just my opinion. Don't mean to turn this into a Win 8 vs. Win 7 thread.
While I agree than Ceton works fine in Win 8, I'm a strong believer in the old adage, if it ain't broke, don't fix it. Also realize that if you have any extenders that aren't xboxes, they won't work anymore. So I have to say, no, it is not a good idea to "upgrade" your HTPC to Win 8.
post #5 of 8 Old 04-21-2013, 05:07 PM - Thread Starter
hlkc's Avatar
Thanks for the advice.
hlkc is offline
post #6 of 8 Old 04-21-2013, 05:52 PM
likelinus's Avatar
Quoted: 140 Post(s)
Liked: 52
Win 8 is just fine with a Ceton InfiniTV installed. I really have no problem with Metro as far as a start screen for an HTPC. I have mine setup with only a few tiles and my HTPC loads to the tiles and I can select XBMC, WMC, IE or Desktop. It's really fairly simple.
My other HTPC is running Win 7 and I won't be upgrading it to Win 8 simply because of the Networking Tuner issue.
likelinus is offline
post #7 of 8 Old 04-22-2013, 11:20 AM
erickotz's Avatar
Liked: 30
We test on both Windows 7 and 8 and the InfiniTV works fine on both. My personal HTPC is on Windows 7 still simply because there is no reason to upgrade. However other machines in my house with InfiniTVs, like my desktop PC, do run Windows 8
Quality Assurance Manager, Ceton Corporation
erickotz is offline
post #8 of 8 Old 04-23-2013, 06:33 PM
mo0sic's Avatar
Windows 8 works great with the ceton. If you use netflix, the windows 8 netflix app is really nice, with the exception of no keyboard shortcuts/remote capabilities.
mo0sic is offline
Reply Home Theater Computers
