Cable STB to Ceton InfiniTV - AVS Forum | Home Theater Discussions And Reviews
Old 04-21-2013, 07:31 AM - Thread Starter
stusic's Avatar
Good morning all!
After using my htpc for years without cable, I recently had it installed. The problem I immediately ran into was the new STB has only an hdmi out (no coaxial output) and my tv card has only coaxial input (well, s-video as well, but I'm not going to use that). I was looking at upgrading my card to a Ceton InfiniTV, but it only seems to have an input for a cable card. Is there some sort of hdmi-cable card adapter available? How would I connect the STB to my tv tuner?
Thanks for any help!
stusic is offline
Old 04-21-2013, 07:42 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
The tuner, Ceton card or Silicon Dust prime take the place of your cable box. The stand alone tuner is only worthwhile if it is Qam capable and your cable provider has unencrypted channels. If not you will need the Ceton or Prime with a cable card.
oman321 is offline
Old 04-21-2013, 08:34 AM - Thread Starter
stusic's Avatar
I'm not sure I understand. Maybe I just don't understand cable cards. If the tuner takes the place of my cable box, how is it attached? There's a coax cable coming from the wall, but no coax input on the card. So where do I get a cable card?
As an aside, Ceton advertises being able to watch premium, encrypted HD channels.
stusic is offline
Old 04-21-2013, 09:04 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
If you are dead set on connecting your STB to your HTPC use a Hauppauge! HD-PVR otherwise use a QAM cable tuner but to get more than just the locals you probably need a CableCARD tuner in most service areas.
The InfinTV4 is a PCIe card that resides in your computer and the HDHR Prime is an external device that connects to your network to get the signal to your PC via ethernet. Both of these have coax input for the cable signal from the CableCo. The CableCo will provide you with a CableCARD for a monthly rent that is less than the rent on STB's or DVR's.
You also need to be running Windows Media Center on the PC connected to your TV.
Sammy2 is offline
Old 04-21-2013, 09:08 AM
drtdiver's Avatar
the ceton infinitv has a mini coax adaptor that plugs in. you get a cable card from your cable provider. the cable card is what allows you to get the channels in your subscription.
drtdiver is offline
Old 04-21-2013, 09:12 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Like this:
Sammy2 is offline
Old 04-21-2013, 09:34 AM - Thread Starter
stusic's Avatar
Thank you, that helps a lot. As does reading up on cable cards. I appreciate the help, didn't want to drop $165 on an incompatible tuner.
stusic is offline
Old 04-21-2013, 09:35 AM - Thread Starter
stusic's Avatar
Just one more thing: can you buy one, or do you have to rent it?
stusic is offline
Old 04-21-2013, 09:39 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 402
You must rent cablecards as they hold unique decryption mechanism that only works for your local cable co.. The same reason that you must rent cable stbs.
Sent from my RM-820_nam_canada_246 using Board Express
Foxbat121 is online now
Old 04-21-2013, 09:58 AM
mdavej's Avatar
Quoted: 2132 Post(s)
Liked: 942
Technically you can buy cards, but it's highly unlikely your cable company will activate them.
mdavej is online now
Old 04-21-2013, 03:13 PM - Thread Starter
stusic's Avatar
That's what I was thinking. I appreciate all of the help guys!
stusic is offline
Old 04-21-2013, 06:55 PM
likelinus's Avatar
Quoted: 121 Post(s)
Liked: 51
Who is your Cable provider? Comcast provides one free Cable Card. I think it's $5 for each additional one. So there is no rental fee involved.
likelinus is offline
Old 04-21-2013, 07:43 PM
drtdiver's Avatar
in my area Comcast has started charging 2 bucks for the cable card but lowered the franchise fee by 2 bucks
drtdiver is offline
Old 04-21-2013, 09:52 PM
olyteddy's Avatar
Quoted: 524 Post(s)
Liked: 915
I've got 2 for $1.10 total a month here.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Old 04-22-2013, 09:09 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 402
Cox in my area is charging $2/mo cablecard rental fee. When I had two cable STB/DVRs serving two HDTVs, they charge not only the STB rental fee and DVR fee per box, they also charge additional digital gateway fee and programming fee per box. When I dumped all the boxes and go with a single cablecard tuner (HDHomeRun Prime) serving 3 HDTVs, I only need to pay 1 digital Gateway fee and 1 programming fee. Basically, it saved me $40/mo.
Old 04-22-2013, 04:57 PM - Thread Starter
stusic's Avatar
I haven't gotten it yet, but from what I undersstand, MediaCom charges $2.
stusic is offline
