Media centre pop up - AVS Forum | Home Theater Discussions And Reviews
Old 04-22-2013, 02:11 AM - Thread Starter
josh_parker123's Avatar
For some reason when I use the volume buttons on my remote if media centre is minimised it pops up full screen, this can be very annoying if watching a video online. Does anyone have any ideas on how to change my volume without media centre coming full screen?
josh_parker123 is offline
Old 04-22-2013, 02:28 AM
Nethawk's Avatar
Liked: 118
I'm guessing that your remote is coded for media center volume rather than your AVR or display. Are you using a programmable universal remote?
Nethawk is offline
Old 04-22-2013, 03:36 AM - Thread Starter
I'm using the remote which came with my origenae m10 I believe its called an imon pad
Old 04-22-2013, 06:30 AM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
There's an imon setting in the set up wizard about exclusive control of a program. I can't remember 100% what you need to check/uncheck but I used that setting to solve a similar problem with arcsoft minimizing and re opening wmc
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
Old 04-22-2013, 11:17 AM - Thread Starter
Okay ill give it a look when I get home thanks for the advice
