DTS MA and TrueHD downsample, totalmedia theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-24-2013, 03:56 PM - Thread Starter
Alex Rad's Avatar
Hi guys!
Having a bit of trouble with totalmedia theater 5 downsampling the audio.
Now, I don't have a card that supports bit streaming, but I have heard that I am able to get uncompressed pmc. When I play a movie in totalmedia theater 5, I only got downsampled 48kHz, 16-bit dts and dolby?
What would I have to do to get uncompressed pmc in totalmediatheater? I am running a laptop with an hdmi to my onkyo ht- r558 receiver with a 5.1 setup.
Also, is there really a big difference between downsampled dts/dolby and dts ma/true hd?
Alex Rad is offline
post #2 of 6 Old 04-24-2013, 05:51 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
What is the model number of the laptop you're using?
Mrkazador is offline
post #3 of 6 Old 04-24-2013, 05:58 PM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
Without a protected audio path, PowerDVD and TMT will send out lossy audio or downsampled multichannel pcm.
The model of your laptop is very important in order to determine if you can send out hi-res audio.
Depending on the quality of your HT system and the source material, there can be a noticeable improvement with DTS-HD MA and Dolby TrueHD over DD/DTS.
audit13 is offline
post #4 of 6 Old 04-24-2013, 06:30 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
No support for HD audio bitstreaming = no protected audio path = all decoded LPCM will be downsampled to 48kHz 16bit.
A workaround is use a non-AACS player such as MPC-HC, along with LAV Audio Decoder + dtsdecoderdll.dll (a DTS decoder included in TMT). (LAV Audio Decoder can decode TrueHD, but can decode DTS-HD only with dtsdecoderdll.dll.)
renethx is offline
post #5 of 6 Old 04-25-2013, 12:39 AM - Thread Starter
Alex Rad's Avatar
My laptop is a HP Pavilion dv7-3190EM .
Intel Core i5 430M 2,27Ghz, 3MB L2
4096MB DDRIII 1067MHZ
640GB (2x320) SMART SATA 5400rpm
nVidia GeForce GT320M 1GB DDR3
Strange thing is, when I played a file on VLC, I checked the info and it said pmc, but it said 2 chanel pmc and next to it, it said 5.1 ch stereo?
So I was getting some weird sound on that, I figured it was due to player configuration, so I switched to totalmedia theate 5 and the sound is amazing, but, like I said, it downsamples the to 16bit and stuff.
Alex Rad is offline
post #6 of 6 Old 04-25-2013, 05:57 PM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
The nVidia doesn't support bitstreaming HD audio so you'll be limited to downsampled audio.
audit13 is offline
Reply Home Theater Computers
