6Gb/s cable better than SATA 3Gb/s cable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-25-2013, 10:18 AM - Thread Starter
Elpee's Avatar
Quoted: 61 Post(s)
When I built my server with mobo Asus P8Z77 -V, I recognized there were 2 sata cable bags. One was for SATA 3Gb/s and other SATA 6Gb/s cables.
So, I wonder if 6Gb/s cable is better than (faster) SATA 3Gb/s cable?
Did a research thru Google, some reviews said there is still no performance difference between SATA 3Gb/s and SATA 6Gb/s cables. If so, why does Asus try to seperate those calbes?
Any of you tested it yet?
Elpee is offline
post #2 of 8 Old 04-25-2013, 10:23 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
No.
If you ever need more, get the cheapest one in the length needed from monoprice.
Sammy2 is offline
post #3 of 8 Old 04-25-2013, 10:33 AM
lagittaja's Avatar
No difference.
lagittaja@Overclock.net | Lagittaja@MuroBBS | Also Anandtech AVForums DIYAudio Head-Fi XDA-Developers e-Savuke ECF VFF VaporWall VapePit & etceteros
Main rig
lagittaja is offline
post #4 of 8 Old 04-25-2013, 01:34 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
There is no difference between cables, just marketing.
Mrkazador is offline
post #5 of 8 Old 04-25-2013, 02:24 PM
bryansj's Avatar
Quoted: 1130 Post(s)
Liked: 559
I just did a build using the same Asus mobo and it comes with two bags of cables. It is true that the cables are different, but it will probably make no difference since the SATA2 cables will work at SATA3 speeds. I did use the SATA3 cables for the primary SSD and HDD and the SATA2 for the Blu-ray RW just because I could. The included SATA3 cables are beefier than the SATA2, which look like other SATA3 cables I've used before.
bryansj is offline
post #6 of 8 Old 04-26-2013, 02:21 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
While there is no real difference between SATA2 or SATA3 cables, it is very well possible that extremely cheap cables may not function properly at SATA3 speeds, because their design is not up to spec.
Not saying you need to buy gold-plated cables or anything, the ones that come with your board are just fine for any speed. smile.gif
Nevcairiel is offline
post #7 of 8 Old 04-26-2013, 11:18 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
Spinning hard drives can barely saturate SATA1 bandwidth. So, SATA2 and SATA3 speeds only come to play if you are running SSD's exclusively.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #8 of 8 Old 04-26-2013, 01:40 PM
Vlad Theimpaler's Avatar
Liked: 33
Not only is it "just marketing", it's deceptive marketing to boot. It's the same type of snake-oil promotion that is used to sell Monster cables at exhorbitant prices to uninformed A/V customers.
Here's an article by Maximum PC on the subject of SATA cable performance:
http://www.maximumpc.com/article/features/your_sata_cable_slowing_down_your_data_transfers_max_pc_investigates
Vlad Theimpaler is offline
Reply Home Theater Computers
