Windows Media Center - Breakup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-27-2013, 05:15 AM - Thread Starter
Contsi's Avatar
I have 2 Win 7 PC's; I'm running HDHomerun Prime (3 tuners). WMC center breaks up or does not run smooth when on HD channels. CPU and memory are below 50%, tuner signals are at 100%. I have all latest updates for my devices, yet I can open HDHomeRun Quick TV and it will run very smooth with the highest picture and sound quality and will not skip a beat for as long as its running. What can I do to get WMC to run the same way? What am I missing?
Contsi is offline
post #2 of 2 Old 04-27-2013, 05:21 AM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
Sounds like a network issue. Are you using a wired or wireless connection to the HTPC's running the Prime?
You may want to also post this on the Silicon Dust forums too.
Sammy2 is offline
Reply Home Theater Computers
