Randomly lost surround in windows 7, anybody ever seen this happen before? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-28-2013, 10:04 AM - Thread Starter
nebrunner's Avatar
Quoted: 62 Post(s)
Liked: 55
I've tried searching both on this site as well as other tech forums and have found a lot of people with various surround issues but nobody that has this one, and frankly I'm at a bit of a loss here.
I noticed that I didn't seem to have surround sound, although I haven't touched anything on my HTPC and it was working fine (I think) up to last week. So I went to the windows audio setup panel:
And I do see my 7.1 speakers, but when I click "TEST" it will send the front right, left, center and sub all to the correct speakers, then when it gets to all of the surrounds, it is mapping them to the fronts!
I did a bunch of pretty standard troubleshooting -
rebooted
checked to make sure the nvidia audio device is set by default, it is
updated the nvidia hd audio driver to latest version
checked to make sure all of the surrounds are working fine in the onkyo receiver setup menu, they are
nebrunner is offline
post #2 of 6 Old 04-28-2013, 01:31 PM
goros's Avatar
Liked: 35
Sounds like an issue with a codec. Haali, ffdshow and lav can have these types of effects if they aren't configured correctly.
goros is offline
post #3 of 6 Old 04-28-2013, 02:23 PM - Thread Starter
nebrunner's Avatar
Quoted: 62 Post(s)
Liked: 55
Looking at windows update I see that it automatically installed some new nvidia drivers on 4/13. No idea what those were but its possible that is what messed me up. Looks like I can try an earlier restore point if there is one and see if that fixes things.
post #4 of 6 Old 04-28-2013, 06:36 PM - Thread Starter
nebrunner's Avatar
Quoted: 62 Post(s)
Liked: 55
I tried changing out the HDMI cable and also rolling back to an old restore point, neither fixed the issue.
If someone else is using an nvidia card in their HTPC and it is connected to their receiver via HDMI, can you take a look in your audio properties and see if you have this same setting?
post #5 of 6 Old 04-29-2013, 09:29 AM - Thread Starter
nebrunner's Avatar
Quoted: 62 Post(s)
Liked: 55
Additional troubleshooting steps attempted -
installed shark codec pack, had no affect
tried a very old nvidia hd audio driver, had no affect
next thing I can try is swapping out the card for another nvidia card
post #6 of 6 Old 04-29-2013, 05:04 PM
goros's Avatar
Liked: 35
Remove all your nvidia drivers and codecs from the system.
Uninstall them all in programs, then use ccleaner and driversweeper (whatever it's called now) and verify it's gone. Reboot, run driversweeper and ccleaner again, reboot.
Install nvidia 314.22 whql drivers (advanced install, clean install), install codecs. Set up speakers.
S
Hopefully, win.
goros is offline
Reply Home Theater Computers
