USB to spdif digital audio converter for budget HTPC? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-29-2013, 12:10 PM - Thread Starter
Harrypt's Avatar
I'm totally new to HTPC's. I've been using a WDTV for years, and just bought a second but the new one seems to have some glitches and doesn't seem to serve data to the second fast enough for glitch free play.
So I was thinking of picking up a used small form factor PC to dedicate to a HTPC. Seems there's plenty of inexpensive options out there but then I noticed some, such as a Dell Optiplex 760, don't have digital audio output.
So question: is there a recommended inexpensive USB>spdif converter? I don't need a full sound card, just a converter. Are they all multi-channel dolby compatible or is that something I have to be careful about?
Harrypt is offline
post #2 of 7 Old 04-29-2013, 12:16 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Is HDMI out of the question?
Sammy2 is offline
post #3 of 7 Old 04-29-2013, 01:37 PM - Thread Starter
Harrypt's Avatar
Yes, out of the question.
Many of the most cost effective options to try this have have plenty of horsepower for a HTPC but have DVI video out.
Harrypt is offline
post #4 of 7 Old 04-29-2013, 01:46 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
This can pass-through Dolby Digital, DTS, and 2ch PCM using the optical output. I was using one on my laptop and it works great.
http://www.amazon.com/Turtle-Beach-Advantage-Digital-Adapter/dp/B0036VO4X4
For about $7 more you can get a GPU with HDMI that support HD audio.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161367
Mrkazador is offline
post #5 of 7 Old 04-29-2013, 03:02 PM - Thread Starter
Harrypt's Avatar
Yeah, I saw that one while searching myself but the site I spotted it didn't show the optical digital attachment so I thought it would only output analog. Can you confirm it will at least do DTS? I suppose I was looking for someone to tell me they've used one and that it works well.
Although I've used a USB to spdif converter for my audio only system and it worked great, dunno why this shouldn't.
[EDIT]
I see for myself on their website it does DTS so that's good enough for me. Thanks.
Harrypt is offline
post #6 of 7 Old 04-29-2013, 03:24 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Make sure you get the correct one, I think there are others with a similar name. It will most certainly output Dolby Digital and DTS through the optical adapter.
post #7 of 7 Old 05-05-2013, 01:53 AM
Eiffel's Avatar
Quoted: 13 Post(s)
I have a Behringer UCA202 (http://www.behringer.com/EN/Products/UCA202.aspx) which is good for the price... It has a good analog output and can output DTS/DD on its toslink output. The only caveat is that it sampling frequency is limited to 44.1/48 kHz.
Eiffel is offline
Reply Home Theater Computers
