Confused - Yamaha receiver shows PCM when playing Dolby Digital Plus / TrueHD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-29-2013, 08:51 PM - Thread Starter
andyd2k's Avatar
Regardless of whether I use MPC-HD or TMT 5 / 6, my receiver will show PCM as the audio output. If I play Dolby Digital or DTS movies, those are shown correctly. I thought if I have bitstreaming capable hardware that it would show up as TrueHD when playing a movie with TrueHD. Or wrong to think that? My main parts...
AMD 7850 connected to a Yamaha RX-V673 via HDMI
Sound properties in Windows is below.
properties.jpg 49k .jpg file
andyd2k is offline
post #2 of 10 Old 04-29-2013, 10:22 PM
vladd's Avatar
Liked: 39
You need to use an audio decoder that is capable of bitstreaming HD audio and make sure that it is configured to do so. LAV decoders are the most common choice for MPC-HC. TMT 5/6 should to be configured within the application.
vladd is offline
post #3 of 10 Old 04-29-2013, 10:32 PM - Thread Starter
andyd2k's Avatar
I'll check on MPC-HC but I see no options in TMT 5 or 6 that would help with bitstreaming. The options are very limited actually.
andyd2k is offline
post #4 of 10 Old 04-29-2013, 10:59 PM - Thread Starter
andyd2k's Avatar
I followed the guide here...
http://www.mediasmartserver.net/2011/06/30/guide-setting-up-lav-filters-mpc-hc-for-all-your-splitter-and-audio-needs/
To set up MPC-HC with LAV decoders - still getting PCM
andyd2k is offline
post #5 of 10 Old 04-30-2013, 09:48 AM
vladd's Avatar
Liked: 39
You need to select "Use original format" on the audio output or something like that. It's been a long time since I used TMT.
Make sure that your receiver is not set to pass HDMI audio to the TV.
vladd is offline
post #6 of 10 Old 04-30-2013, 10:39 AM
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 79
see what filters are in use while your playing the video with truehd.
(right click in the window>filters)
MlNDBOMB is offline
post #7 of 10 Old 04-30-2013, 03:33 PM
haubrija's Avatar
Recently, my install of LAV was turning on the downmixing options present on the second tab of the LAV audio decoder upon re install. It took me awhile to figure out what was wrong as I normally would just adjust the options on the main tab of the audio decoder properties. Make sure that downmixing is not enabled.
haubrija is online now
post #8 of 10 Old 04-30-2013, 10:53 PM - Thread Starter
andyd2k's Avatar
vladd - You're right that there was a drop down box that allowed me to switch from mix pcm to original audio. DTS is now bitstreaming in TMT but not True HD. That keeps showing up as PCM
The HDMI audio to TV is off
Mindbomb - I'll give that a look in the morning. Both formats show up as PCM while playing in MPC
Haubrija - Not sure what option you're referring to I don't see it
As it is right now, the only player that actually works properly is Windows Media Player with Shark007 codecs. I used his suggested settings and this is the first time that I see my receiver actually bitstream TrueHD and Dolby Digital Plus. I checked the information window in my recevier.
I was already thinking that I would have to get my receiver replaced but I now see that it's not the receiver but software. I don't understand why TMT is not working properly. As for MPC, I need to check the settings.
andyd2k is offline
post #9 of 10 Old 05-01-2013, 06:50 AM - Thread Starter
andyd2k's Avatar
Looks like there is a bug in XBMC that won't allow bitstreaming of DD+ files. Everything else seems to be working now. I don't have MPC set up for bitstreaming but the end game was to get XBMC to work properly and I wanted to make sure that my receiver was also working properly.
I still have to figure out why TMT is not bitstreaming some formats but I'll have talk to their support about that
Thanks for all the help guys
andyd2k is offline
post #10 of 10 Old 05-01-2013, 11:24 AM
haubrija's Avatar
The mixing option in LAV is found in the setting in the attached picture. If it is enabled, LAV will downmix everything to stereo and you will not get bitstreaming. Double check that it is not enabled.
As for DD+ sources, LAV is the only decoder I've ever found that can properly bitstream it. TMT does not, nor any other third party software.
Reply Home Theater Computers
