AMD / CCC outputting only 60p - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-30-2013, 02:10 AM - Thread Starter
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
I just connected the HTPC to a new HDTV and the TV indicates it is receiving a 1920x1080, 60p signal. The picture looks good but I had thought the HTPC would be outputting a 60i signal. I have an HD6450 video card & don't see anything in the CCC control panel that lets me change this. Maybe the 60p is the best but I'm surprised there is no way to change this. Am I missing something or is there a hidden setting?
Mike99 is offline
post #2 of 7 Old 04-30-2013, 06:51 AM
cybrsage's Avatar
Liked: 154
60p is better than 30i and 59p is even better. Open the CCC and go to Desktop Management - Desktop Properties. Change 60 to 59 and press Accept. CCC will continue to report 60Hz, but it is actually at 59 (well, 59.xx) - it is a bug they have not bothered to fix.
cybrsage is offline
post #3 of 7 Old 04-30-2013, 07:04 AM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
There is no 60i.
If you wanted interlaced you need to choose 29 Hz or 30 Hz, interlaced.
Andy_Steb is offline
post #4 of 7 Old 04-30-2013, 08:24 AM
mdavej's Avatar
Quoted: 2213 Post(s)
Liked: 969
Why would 60i (if it existed), or any interlaced signal for that matter, be preferable to 60p or other progressive signal?
mdavej is online now
post #5 of 7 Old 04-30-2013, 09:24 AM - Thread Starter
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
I don't know why I mentioned 60i, I guess I was tired & didn't realize what I wrote. Sorry about that. But I did mean interlaced.
I didn't think about looking in the Desktop Management section since I was concerned about video.
The HTPC is primarily used as an OTA DVR & I figured if 1080i was being recorded then that's what would be passed along to the TV. I'm not preferring 60i or 30i, I was just surprised the HTPC was doing the de-interlacing instead of having the TV do it like it does with an OTA signal.
gonzo90017 likes this.
Mike99 is offline
post #6 of 7 Old 04-30-2013, 02:20 PM
Andrew Hornfeck's Avatar
Quoted: 31 Post(s)
You've got a HTPC connected and you're still using the TV's internal tuner to watch OTA?  Reason I ask is now that you've added tuners to your setup (for DVR functionality) you probably will never use the TV's again - just WMC, MP, or some front-end s/w as your baseline via HDMI to the display!  The technology is amazing today -- $20~30 for that HD6450 and it does all the deinterlacing, decoding and such to send full resolution 1920x1080p to your display!  Think about analog TV from 5 years ago - 330 lines of resolution, analog sound and crappy tuning -- now we have ATSC with full HD resolution (720p & 1080i), digital transmission, full AC3 5.1 Dolby Digital audio tracks and it's all for FREE with your old fashioned bow-tie antenna!
Andrew Hornfeck is offline
post #7 of 7 Old 04-30-2013, 03:04 PM - Thread Starter
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
I am using HDMI from HTPC to HDTV.
My old HDTV was a 720p set and the HTPC sent out that signal & I never questioned it because the TV used "p". So it kind of threw me seeing the 1080 - 60p.
As a side note, I know from past experience that sometimes one component does a better job than others at processing a signal. I did not plan on experimenting but the thought had crossed my mind if the HD6450 does a better job deinterlacing than the HDTV's internal circuitry.
Mike99 is offline
Reply Home Theater Computers
