Good main display monitor for gaming/workstation? Anyone used Monoprice 27" or 30" IPS ??? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 68 Old 02-21-2014, 03:31 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
$299 New YAMAKASI CATLEAP Q270 LED SE 27"2560X1440 WQHD DVI-D Dual Computer Monitor +FS at Green-sum via Ebay http://saviry.com/deal/482592 via Saviry app
Thoughts on that ^
Mfusick is offline
post #62 of 68 Old 02-21-2014, 04:34 PM
Postmoderndesign's Avatar
Quoted: 221 Post(s)
Liked: 85
My experience with an auria eq27w was that I needed to exchange the monitor because of severe backlight bleed. The replacement monitor I got is excellent. If the technology on the YamasKasi is the same there is a second level market for panels that were rejected. Don't buy it if an exchange is not simple and cheap. If you buy test it right away.
Mfusick likes this.
Anál nathrach, orth’ bháis’s bethad, do chél dénmha
Postmoderndesign is offline
post #63 of 68 Old 02-23-2014, 11:04 AM
durack's Avatar
Quoted: 12 Post(s)
Liked: 29
I really think it depends on what you use your monitor for and what your priorities are.
I have a dual setup and for gaming I use a 27 inch 120Hz BenQ 1080p monitor with lightboost. (BenQ XL2720T) The smooth blur-free image you get trumps any other deficiencies that TN panels may have.
For everything else I use my Dell U2713HM - IPS is great for photos, etc, but the amount of smearing you get makes it very unpleasant for gaming.
I am very tempted by the new Asus ROG
http://rog.asus.com/296652014/news/rog-announces-the-pg278q-swift-27-inch-wqhd-g-sync-gaming-monitor/
The only problem is I don't really need it, I am quite happy with gaming at 1080p - going to 1440p means that I may have frame rate dips under 60 fps in the more demanding games, which means possibly upgrading my video card to whatever high-end Maxwell Nvidia will release later this year. Seems like upgrading for the sake of upgrading.
The only plus is that both of my monitors will now be the same resolution since right now one is 1080p and the other is 1440p which is not really a big deal.
If you want IPS and plan to game, I suggest you look here for ideas.
http://www.blurbusters.com/overclockable-ips-120hz-monitors-buying-guide/
I would probably get an Overlord since they offer US warranty.
durack is offline
post #64 of 68 Old 02-23-2014, 03:04 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
I have a 27" 1080p and 26" 1200p I can game on.
Mfusick is offline
post #65 of 68 Old 02-23-2014, 04:33 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
Originally Posted by Mfusick View Post
I am definitely looking for large screen. 27" minimum.
I'd like more than 1200p too.
I'm very happy with my LG 27EA33V Black 27" 5ms HDMI Widescreen LED Backlight LCD Monitor, IPS-Panel 1080.
Mfusick likes this.
arnyk is offline
post #66 of 68 Old 02-23-2014, 09:55 PM
JackDiesel14's Avatar
Quoted: 12 Post(s)
Liked: 31
I just bought a Planar PXL2790MW IPS 1440p. Tomshardware gave it a great review, can't wait to get it. I was about to get an Overlord monitor (not the 120hz) kind but they are always sold out and for only $100 more I could get the one I ordered.
I was hoping to set up 2 of them running at 1440p but that's not looking like it's going to happen. My motherboard has a DVI-I, DisplayPort, and HDMI 1.4 (I think, ASRock doesn't give the exact version in it's specs). The monitor has DVI-D (Dual Link), Display Port and HDMI but the HDMI only supports to 1080p.
Mfusick likes this.
JackDiesel14 is offline
post #67 of 68 Old 06-13-2014, 10:41 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
Anyone seen the new 4k 28" gaming monitor from monoprice yet ?
Mfusick is offline
post #68 of 68 Old 07-30-2014, 09:24 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
Looks like it is delayed until October now...
Mfusick is offline
Reply Home Theater Computers
