Setting up a plex server - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-03-2013, 08:27 PM - Thread Starter
yaomizzle's Avatar
Liked: 26
I own ~1600 DVDs/ blu rays and have long considered converting everything and setting up a plex server. But I have a few questions.
1. How long should I expect the ripping/conversion process to take?
2. If I wanna serve it up via an HTPC or Oppo, but also own an IPad and Galaxy Note 2 what format would be best?
3. About how much space should I expect each DVD to take up once converted?
4. Should I have a video card in the tower that's going to serve it all up? I current have an i5 2550k with 16gb of ram in it
Thank you in advance!! :-)
Sent from my iPad using Tapatalk HD
yaomizzle is offline
post #2 of 9 Old 05-03-2013, 10:17 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
1. It takes about 15 to 20 minutes to rip a Blu-ray.
2. mkv
3. DVD's are less than 9Gb but Blu-ray can be up to 30Gb.
4. You don't need a video card in the server. Put it in the HTPC used for playback.
A couple things. mkv's don't have menus and extras. They are typically movies only and you don't have to watch stupid warnings or trailers. Also, it is not neccesary to run PLEX to do this.
Sammy2 is online now
post #3 of 9 Old 05-03-2013, 10:52 PM
amarshonarbangla's Avatar
Quoted: 28 Post(s)
Liked: 43
It does? What software are you using? What Bluray drive are you using? Specs of your PC?
amarshonarbangla is offline
post #4 of 9 Old 05-03-2013, 11:00 PM - Thread Starter
yaomizzle's Avatar
Liked: 26
Ok how far can I compress without noticeable loss? Cause 9gb per movie X ~1400 is 12.6 TB not really about that
post #5 of 9 Old 05-04-2013, 03:34 AM
Nethawk's Avatar
Liked: 118
You're going to have to dedicate a lot of time and use up a lot of storage (which is cheap) no matter how far you compress. Prepare yourself wink.gif
You don't need Plex, but if you're planning to use a mix of static and mobile endpoints you will need to transcode, and Plex does this well.
Nethawk is offline
post #6 of 9 Old 05-04-2013, 07:28 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I'm talking about the total time it takes from opening the package until you have an mkv in the right directory ready to play. That said I have an older Samsung drive that is only 4x and am using MakeMKV with an i5-650.
post #7 of 9 Old 05-04-2013, 08:06 AM
Quoted: 28 Post(s)
Liked: 43
Hmm, I am running an i7 920 at 3.7Ghz with a Lite-On drive. I get 3-4x speed as welll. Takes 30-60 mins in my case. I only have 6GB of RAM in my rig. I suppose that's the issue?
post #8 of 9 Old 05-04-2013, 09:22 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
It has been a while. I under-estimated the time. I just ripped a 34Gb disc to mkv and the total time for MakeMKV was 32 minutes.. So it took a total time of about 35 minutes. Not all discs are this big though.
post #9 of 9 Old 05-06-2013, 01:38 AM
leebo's Avatar
Quoted: 527 Post(s)
Liked: 295
What was the size of the MKV?
Sent from my Nexus 7
leebo is offline
Reply Home Theater Computers
