Guide for Adding Back in Subtitles to BluRay MKVs that Have Been Through Handbrake? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 05-07-2013, 02:26 PM - Thread Starter
Gronnie's Avatar
Quoted: 32 Post(s)
Liked: 30
As the title states, I am looking for a guide to adding back in the subtitle tracks to MakeMKV BluRay rips that I have compressed in HandBrake. I can't seem to find a decent guide. I am a paid member of AssassinHTPCBlog, but I don't see a guide there either. Thanks for any help!
Gronnie is offline
post #2 of 17 Old 05-07-2013, 02:46 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Add both the original file and the encoded file into Mkvmerge GUI (MKVToolnix), select only the tracks you want to keep, then merge them into a single file.
renethx is offline
post #3 of 17 Old 05-07-2013, 04:39 PM
Dark_Slayer's Avatar
Quoted: 658 Post(s)
Liked: 434
What is the best method for burning in subtitles?
I realize several players honor the "forced" subtitle setting, but I'd rather just have them burned into the video for the few rips that need it (John Carter, District 9, Avatar, Iron Man, etc)
I've heard that handbrake will and will not work (assume it does?)
I've also heard mencoder, avc, and avidemux all have the capability, but I've yet to use any of them.
Thoughts?
Dark_Slayer is offline
post #4 of 17 Old 05-07-2013, 05:45 PM - Thread Starter
Gronnie's Avatar
Quoted: 32 Post(s)
Liked: 30
So I did this for one of my rips, and I know it added in the subtitle track because it works in VLC but I can't get it to work in WMC with DirectVobSub?
Gronnie is offline
post #5 of 17 Old 05-07-2013, 09:06 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
DirectVobSub supports PGS (i.e. Blu-ray) subtitles in MKV just fine. Do you see DirectVobSub icon in the system tray? LAV Video Decoder won't work with DirectVobSub inside WMC (i.e. if LAV Video Decoder is used in WMC, DirectVobSub won't be loaded even when it should be), unless you use Shark's codec pack.
renethx is offline
post #6 of 17 Old 05-07-2013, 09:56 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Thoughts?
HandBrake can handle Blu-ray PGS subtitles (and output as "Burned In" or a subtitle stream) since v0.9.9 (v0.9.8 or earlier does not support it). Burned in quality looks the same as the original one. Try it.
renethx is offline
post #7 of 17 Old 05-07-2013, 10:14 PM - Thread Starter
Gronnie's Avatar
Quoted: 32 Post(s)
Liked: 30
DirectVobSub supports PGS (i.e. Blu-ray) subtitles in MKV just fine. Do you see DirectVobSub icon in the system tray? LAV Video Decoder won't work with DirectVobSub inside WMC, unless you use the version of Shark's codec pack.
I am using Shark's codecs, and DirectVobSub icon shows the subtitles are enabled yet they do not show on the video. Not sure what could be wrong?
Gronnie is offline
post #8 of 17 Old 05-07-2013, 10:37 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Is the subtitle stream flagged as "Default"? (You can check this with MediaInfo or Mkvmerge GUI.) Otherwise you have to select the subtitle stream manually. A workaround would be:
1. Make it default, obviously. To do so, you can use Mkvmerge GUI > File > Header Editor.
2. In LAV Splitter properties, choose "Advanced" subtitle selection mode and add the tag "*:*" (without quotes) in the Subtitles field. (This tag will force the splitter to always load the first subtitle stream of the file.)
Details of Advanced subtitle selection mode
renethx is offline
post #9 of 17 Old 05-07-2013, 11:22 PM - Thread Starter
Gronnie's Avatar
Quoted: 32 Post(s)
Liked: 30
Ugh did exactly as you said still can't get the subs to display when played in WMC or WMP, but they work find in VLC. Tried remuxing a different movie just in case it was something weird with the first one, but same result.
Gronnie is offline
post #10 of 17 Old 05-08-2013, 12:14 AM - Thread Starter
Gronnie's Avatar
Quoted: 32 Post(s)
Liked: 30
Got it to work.
I had to uninstall Shark's codecs, enable UAC, restart my system, reinstall Shark's codecs with administrator privileges, then change the H264 tab to Use FFDshow's codec.
Something must have been wrong with privileges before, because I had Shark's codecs setup correctly before the reinstall and they weren't working.
Gronnie is offline
post #11 of 17 Old 05-08-2013, 05:21 AM
gewbert's Avatar
Liked: 27
I've found subtitles to be weird in WMC. On some movies I can get them to work just fine (forced or default) but on others they just won't work, even when I turn them on manually in DirectSub. Always work in MPC-HC/XBMC.
gewbert is offline
post #12 of 17 Old 05-08-2013, 08:12 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Got it to work.
There really is no reason to not have UAC enabled and you must have it enabled and run Shark007 at an elevated (administrative) level to make the changes to your registry and register the splitters and codecs.
Sammy2 is offline
post #13 of 17 Old 05-08-2013, 08:16 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I've found this to be mostly true although I didn't try with WMC much because I did not like VOBSub much and it wasn't too remote friendly. Toggling through subs in MPC-HC is a breeze with proper settings in the Keys tab of MPC-HC.
Sammy2 is offline
post #14 of 17 Old 05-13-2013, 02:25 PM
Quoted: 658 Post(s)
Liked: 434
You've verified this in their release preview? Are you running this in Windows?
Also, it would be mighty nice if they added a video "passthrough" option to support burning in subtitles. I'd rather not "guess" as to which quality to choose for video output, also what does lossless do in order to make the file grow??
post #15 of 17 Old 05-13-2013, 02:38 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Yes. Yes.
Video passthrough+subtitle burning is impossible, re-encoding is always necessary to burn in subtitles.
renethx is offline
post #16 of 17 Old 05-13-2013, 03:36 PM
Quoted: 658 Post(s)
Liked: 434
Thanks. I guess I don't know the right terminology, but I was referring more to a "Quality-passthrough" setting where I'm not guessing if the quality I pick is the same as source. I realize it will be re-encoded by nature of layering text over source frames
What video settings would you recommend for that intention?
post #17 of 17 Old 05-13-2013, 11:50 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
In Handbrake > Video tab, there are two places to control quality:
Qualtiy
The most important, of course. CRF (Constant Rate Factor ["constant" means that the quality or rate is constant throughout the video file]) = 0 means "lossless" (i.e. compress the decoded video in a lossless way), that will usually result in larger file size than the original. CRF = 18-20 is a good choice, usually you won't see any quality degradation compared with the original. File size of a 2 min clip (ripped from a BD movie):
- Original: 457MB
- CRF=0 : 1787MB
- CRF=20: 94MB
You can't predict the final file size with CRF. If you want to set the file size, choose "Avg Bitrate" with "2-Pass Encoding".
Optimize Video > x264 Preset
This is literally a preset of important x264 parameters (x264 MeWiki). I think Handbrake's default is "Very Fast". x264's default is "Medium" (and I usually use it, a good compromise of quality and encoding time). A faster preset implies faster encoding time, larger file size and generally lower quality. For example,
- Ultrafast: Baseline@L4.0, no CABAC, 1 ReFrame etc.
- Veryfast: High@4.0, CABAC, 4 ReFrame etc.
- Medium: High@4.0, CABAC, 4 ReFrame etc.
Try to encode a short clip and you can check the differences.
You can leave "Profile" and "Level" to "Auto" because the preset automatically determines them.
renethx is offline
Reply Home Theater Computers
