feedback on htpc parts list - AVS Forum | Home Theater Discussions And Reviews
Old 05-09-2013, 02:12 PM - Thread Starter
simp1yamazn's Avatar
Quoted: 109 Post(s)
Liked: 77
I'm looking to build my first HTPC but I've never built my own computer before so I would like some feedback on the parts list i've put together. I need help making sure the parts are all compatible and that they will capable of doing what I need. so here's a list of capabilities I would like:
1. output lossless audio via HDMI
2. properly output 1080p24
3. play my blu-ray .iso files without any stuttering (will be running via XBMC on windows 8)
3a. run xbmc smoothly
So here is what I've put together so far:
Case: Cooler Master CMP-350 and included power supply
Motherboard: Asus P8B75-M/CSM
Processor: Intel i3-3220
Ram: Kingston 4 GB DDR3 KHX1333C9D3B1/4G
OS Harddrive: Existing 250GB
Media Harddrive: Existing 1.5TB
Windows 8
Also, since this is my first computer build, what else will I need in terms of small accessories like connecting cables and the like? Thanks in advance!
simp1yamazn is offline
Old 05-09-2013, 04:10 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
SSD for OS = yes.
Otherwise I wouldn't be happy. I can't use a non SSD HTPC and be satisfied.
Mfusick is offline
Old 05-09-2013, 05:09 PM
Nethawk's Avatar
Liked: 118
Do you also have a storage server or NAS? Depending on the size of your collection (and upcoming addiction to the convenience of a HTPC) that HDD is going to fill up relatively fast.
Nethawk is offline
Old 05-09-2013, 05:25 PM - Thread Starter
Quoted: 109 Post(s)
Liked: 77
Originally Posted by Mfusick View Post
SSD for OS = yes.
what will the SSD for the OS drive do for me in a practical sense? I realize it has much faster read and write times, but if all i use it for is running XBMC and all of the media is stored on other drives, will I really get much out of it?
Old 05-09-2013, 05:27 PM - Thread Starter
Quoted: 109 Post(s)
Liked: 77
not yet. I have a few drives laying around that are unused, including the 1.5 TB drive. The idea was to just start with this so I can get used to everything and gauge how much storage I will really need to buy.
In a related question, do any of you guys use raid storage to ensure your media is protected from drive failure?
Old 05-09-2013, 05:54 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
SSD for OS = yes.
Those faster read/write times translate into a more "snappy" interface which provides a much nicer user experience.
Sammy2 is offline
Old 05-09-2013, 05:57 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
After looking at your list, use Win7 over Win8. M$ hs all but admited Win8 is a failure and has indicated that it will be fixed with a Code Blue update.
Sammy2 is offline
Old 05-09-2013, 06:04 PM - Thread Starter
Quoted: 109 Post(s)
Liked: 77
Is 7 still available? for some reason I thought only 8 was in stores now.
Also, does anyone see any compatibility issues with the parts i listed?
Old 05-09-2013, 06:19 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Win7 is available every single day of the week. I think assassin has a limited number of discounted keys for sale and you simply d/l the OS to ISO on a USB drive and install it.
I suggest using Pro for its RDP capabilities.
Sammy2 is offline
Old 05-09-2013, 07:32 PM - Thread Starter
Quoted: 109 Post(s)
Liked: 77
Alright, windows 7 it is. Do you guys think the hardware is up to the tasks I put in the original post?
Old 05-09-2013, 07:58 PM
PobjoySpecial's Avatar
PobjoySpecial is offline
Old 05-09-2013, 08:06 PM
Dark_Slayer's Avatar
Quoted: 655 Post(s)
Liked: 434
The tasks are a little confusing
Assuming you refer to blu ray audio at this point? - plenty of ways to accomplish and what you chose will suffice
What does the *proper* term reference? How will you compare? I'd avoid getting overly caught up in the 23.976 chase at first until you view some content first-hand
This is your first build and you've not got a server/nas, so when you say "play my blu-ray .iso files" are your referring to the "future" files you will be creating from your blu rays after building your HTPC? Or do you have several already stored on some external hdds? How and what you use to rip dvds/blurays is an important part of your HTPC storage requirements, playback requirements (inside and outside your LAN), and overall cost (not all are free). I've tried to playback a few isos in XBMC, and it typically works for the main title. There is a speedmenu, and sometimes an option to "View Blu-Ray Menus" however none of my attempts at viewing "Blu-Ray Menus" in XBMC have yielded anything.
Nearly every current amd/intel *desktop* processor will accomplish this in addition to most mobile versions and quite a few ARM SoCs. i3 is a good middle ground, especially to be repurposed as your server later (assuming you might want your server to have a little extra grunt for transcoding)
OpenELEC is a good way to run XBMC w/o Windows. My server is just a W8 pro machine that runs XBMC 24/7 as well. Windows gives a lot of additional flexibility if you want to add games, emulators, DVR, or some "PC-by-day-HTPC-by-night" type setup, but for the 2nd room where I just wanted an HTPC I use OpenELEC.
Dark_Slayer is offline
Old 05-09-2013, 08:11 PM
Nethawk's Avatar
Liked: 118
Originally Posted by PobjoySpecial View Post
Playing back Blu Ray .iso files is going to be an endless headache with XBMC. Ripping them to a .mkv file is much more elegant.
Funny, all I have to do is click on it in the library, it plays just fine. No need for virtual drive, no need for external player. If you need menu support, it's also very easy to set xbmc to launch an external player.
Ahh, now I see. Yep, with the specs you listed, it's probably going to be an endless headache getting anything but an mp3 to play. biggrin.gif
Nethawk is offline
Old 05-09-2013, 08:12 PM
Old 05-09-2013, 08:28 PM
Quoted: 655 Post(s)
Liked: 434
OP, in case it isn't clear Nethawk was taking a jab at the specs Pobjoy listed not yours
Nethawk likes this.
Old 05-09-2013, 08:53 PM - Thread Starter
Quoted: 109 Post(s)
Liked: 77
It should cost only about $350, maybe less...
I already have some blu ray isos that I made using anytoiso. I have an external LG blu ray drive that Ill put to work with this htpc.
Old 05-09-2013, 08:54 PM - Thread Starter
Quoted: 109 Post(s)
Liked: 77
Old 05-09-2013, 09:01 PM
Old 05-09-2013, 09:22 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I'm not sure what you are talking about. My Windows HTPC is an appliance. For the OP's purpose I think that XBMC with a celeron may be the cheapest way to go but what about when the OP decides to playback CableTV he may find it isn't going to do it in all cases and he needs WMC. If the OP wants to have hardware accelerated decoding the hardware isn't up to snuff.
Sammy2 is offline
Old 05-09-2013, 09:24 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
I think the i3-3225 for about $15 more is a better graphics option.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is online now
Old 05-09-2013, 10:12 PM
Old 05-10-2013, 06:41 AM - Thread Starter
Quoted: 109 Post(s)
Liked: 77
EDIT: To be fair, most instances of XBMC do handle Blu Ray .iso files as you've described. That doesn't change the fact that .iso is less portable and much larger than necessary. Try playing an .iso on a Raspberry Pi or Android device, then try playing a .mkv file. Launching an external player isn't elegant. Since it requires Windows and specialized software, it also isn't cheap.
A gutless ARM 11 processor could handle the OP's requirements. The Celeron 847 is more than enough.
You want a hobby and that's great. I'm interested in an affordable solution.
I like to have the .iso files for 2 reasons: 1. If my disc gets damaged or gets lost I still have all the content that I paid for and 2. I like having access to various special features, deleted scenes, etc. that would make using a tool like makemkv too tedious, in my opinion. It would also, i'm guessing, make the xbmc movie database crawler much less useful if I were to have tons of mkv files for deleted scenes, interviews, behind the scenes all with different file names
Like I mentioned, this is my first foray into pc building so help me out with this. Would spending a little more for the i3-3225 give me better/worse performance than staying with the i3-3220 and adding a cheap video card like this one here In a related question, is there any reason to NOT at some point add a video card to an HTPC that has integrated video?
The OP would be wise to determine his goals and buy accordingly.
Pretty much what I was going for with this thread.... just need a little help for a first time builder.
Old 05-10-2013, 07:57 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Call it a hobby if you must but my solution saves me $28 each and every month on Cable STB fees and DVR "taxes", requires no maintanence and is quite stable. Many others here do the same. Your way may not neccesarily be the best way in all situations and neither is mine.
Sammy2 is offline
Old 05-10-2013, 08:54 AM
macks's Avatar
Liked: 31
If you are considering a cheap dedicated gpu, your money would be better spent on an AMD APU.
A SSD will mainly have an affect when you are browsing your media. Thumbnails/fanart can load slowly with a HDD, with a SSD it's instant. What SSD you get doesn't make any difference.
macks is offline
Old 05-10-2013, 09:08 AM
macks's Avatar
Liked: 31
Good advice.
The only thing I'd say is that trying to make a computer do everything turns it into a "jack of all trades, master of none."
If you want an appliance, install OpenELEC. If you want a hobby, install Windows.
A Windows HTPC can be built to be very appliance like. People have been doing this for longer than there have been easy Linux solutions for a htpc. You can also do more with a Windows HTPC than a Linux one.
Openelec is very good for what it can do.
Celeron 847, when an atom is too fast and uses too little energy, buy me.
macks is offline
Old 05-10-2013, 09:19 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
One advantage of the Intel graphics is Quick Sync which is their encoding and decoding 'engine'. Handy if you need to transcode video on the fly (feeding an X-Box an MKV file for instance). They've made it fairly open sourced which means a lot of programmers have used it. The 3225 has more of these Quick Sync processing units than the 3220. The top image is Intel HD-2000 graphics, the second HD-4000 (nearly twice as fast). This link compares the speed difference: http://club.myce.com/f184/3770k-vs-3770s-327174/#post2633974
Old 05-10-2013, 09:54 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Which application supports Quick Sync encoder to transcode videos "on the fly"?
renethx is offline
Old 05-10-2013, 10:21 AM - Thread Starter
Quoted: 109 Post(s)
Liked: 77
Not that I doubt how much faster it can transcode video, but if I'm live streaming from my HTPC to a PS3, does it really matter if it can transcode a 2 hour movie in 6 vs 12 minutes as long as it can keep a healthy speed above real time? Or would this mostly come in handy if I'm sending different video streams to different displays? And would this somehow be advantageous over using a low cost video card?
Old 05-10-2013, 10:28 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Apparently none, so far. But not because it isn't doable or available: http://software.intel.com/en-us/articles/integrating-intel-media-sdk-with-ffmpeg-for-muxdemuxing-and-audio-encodedecode-usages
There are numerous 'static' transcoders though, especially from Mirillis: http://mirillis.com/en/products/splashexport.html
EDIT: And apparently HandBrake will have it soon: http://www.anandtech.com/show/6864/handbrake-to-get-quicksync-support
Old 05-10-2013, 10:55 AM - Thread Starter
Quoted: 109 Post(s)
Liked: 77
Anyone have thoughts on a little bit better processor vs add a sub $50 video card?
