Sata Controller Card - Please advise. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 24 Old 05-10-2013, 12:42 PM - Thread Starter
Elpee's Avatar
Quoted: 61 Post(s)
Hey guys, I need 4 more sata ports for available hdds but unfortunately on-board sata ports are now full and 3 PCI-e x 4 and 16 slots are filled up by 3 supermicro sata controller cards.
Two PCI-e x 1 slots are the only ones I have now. Can you please recommend any reliable controller card that caries 4 sata channels (or 2 sata channels so I can buy 2) and can sit on PCI-e x 1 slot? Also, check if it has windows server 2012 driver.
Much appreciate it.
Elpee is offline
post #2 of 24 Old 05-10-2013, 12:55 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
How many hard drives do you have? And what controllers are you using?
Andy_Steb is offline
post #3 of 24 Old 05-10-2013, 01:06 PM - Thread Starter
Elpee's Avatar
Quoted: 61 Post(s)
36 hdds and 3 supermicro aoc-saslp-mv8 cards. Just JBOD to be set up by Flexraid in windows 2012 environment. Mobo Asus P8Z77 -V with 8 sata ports on-board. Thanks.
Elpee is offline
post #4 of 24 Old 05-10-2013, 10:30 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
SYBA SI-PEX40064 (SATA 6Gbps 4-port PCIe 2.0 x1, Marvell 88SE9215 chip)
SYBA says the interface is PCI Express 1.0, but the chip is PCI Express 2.0.
renethx is offline
post #5 of 24 Old 05-11-2013, 07:42 AM - Thread Starter
Elpee's Avatar
Quoted: 61 Post(s)
Thanks for the advice. Do you know if it's compatible with Windows server 2012?
Elpee is offline
post #6 of 24 Old 05-11-2013, 08:00 AM
AnthonyB's Avatar
I am starting to plan one of these. why are you using this many hard drives?
How many drives can you stack in an array before you need one for parity?
What is the size on each of them, what case are you using?
AnthonyB is offline
post #7 of 24 Old 05-11-2013, 09:02 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
I am not sure. Software requirement:
http://sybausa.com/productInfo.php?iid=1376
Server 2012 is not in the list, but Windows 8 is supported, so why not Server 2012. You can ask a question there.
Edit: I found this. The user asked about "Windows Home Server 2011", that is based on "Windows Server 2008 R2", while the tech support replied about "Windows Server 2012". eek.gif Anyway modifying .inf should be easy.
Edit 2: I checked mvs91xx.inf in the driver. It should work with Server 2012 (= NTamd64.6.2; "NTamd64" should work) without any modification.
renethx is offline
post #8 of 24 Old 05-11-2013, 04:19 PM - Thread Starter
Elpee's Avatar
Quoted: 61 Post(s)
Here is the project I'm working on.
Thank you, renethx. I'll buy it soon and let you know if it works with server 2012.
BTW, I can confirm the driver that you posted at avs forum for supermicro aoc-saslp-mv8 controller card works well with Server 2012 and the card recognizes 4TB drives.
Elpee is offline
post #9 of 24 Old 05-11-2013, 11:38 PM
highzone's Avatar
I've used the Syba SY-PEX40039 (http://www.newegg.com/Product/Product.aspx?Item=N82E16816124045). It only has 2 SATA ports so you will need 2 of them. It uses the ASMedia 1061 SATA chip instead of a Marvell chip. Marvell SATA chips have been known to have problems.
highzone is offline
post #10 of 24 Old 05-12-2013, 06:49 AM - Thread Starter
Elpee's Avatar
Quoted: 61 Post(s)
Thank you. I don't care if it's 2 or 4 sata ports as long as it has driver that works with server 2012. Can you confirm it?
Elpee is offline
post #11 of 24 Old 05-12-2013, 08:07 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
ASM1061 is a very popular SATA / PCIe controller chip with good reputation and used in almost every Intel 7-Series chipset mb if it has more than 6 SATA ports (GIGABYTE is the only exception, it uses Marvell 88SE92xx). And it looks like it works with Server 2012 (a user's experience).
renethx is offline
post #12 of 24 Old 05-12-2013, 01:42 PM
AnthonyB's Avatar
My original question wasn't answered. Why so many drives?
AnthonyB is offline
post #13 of 24 Old 05-12-2013, 02:49 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I thought same question. With minimum size being 3TB ... So many drives not needed.
Mfusick is offline
post #14 of 24 Old 05-12-2013, 09:04 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
I tested 88SE9125 (not 9215 but close) and AMS1061. Both worked right out of the box (i.e. worked with Microsoft Standard SATA AHCI Controller driver) under Windows Server 2012. AMS1061 also worked with its own driver (1.3.9). (I couldn't find Marvell's own driver for 9125.) CrystalDiskMark (WD 3TB Green):
Code:
88SE9125 with Standard SATA AHCI Controller
CrystalDiskMark 3.0.2 x64 (C) 2007-2013 hiyohiyo
                           Crystal Dew World : http://crystalmark.info/
* MB/s = 1,000,000 byte/s [SATA/300 = 300,000,000 byte/s]
           Sequential Read :   104.513 MB/s
          Sequential Write :    99.552 MB/s
         Random Read 512KB :    28.165 MB/s
        Random Write 512KB :    48.985 MB/s
    Random Read 4KB (QD=1) :     0.291 MB/s [    70.9 IOPS]
   Random Write 4KB (QD=1) :     0.838 MB/s [   204.5 IOPS]
   Random Read 4KB (QD=32) :     0.702 MB/s [   171.5 IOPS]
  Random Write 4KB (QD=32) :     0.674 MB/s [   164.5 IOPS]
  Test : 1000 MB [H: 59.3% (1658.4/2794.5 GB)] (x5)
  Date : 2013/05/13 10:32:34
    OS : Windows Server 2012 Server Standard Edition (full installation) [6.2 Build 9200] (x64)
ASM1061 with Standard SATA AHCI Controller
           Sequential Read :   104.523 MB/s
          Sequential Write :    99.979 MB/s
         Random Read 512KB :    27.869 MB/s
        Random Write 512KB :    52.005 MB/s
    Random Read 4KB (QD=1) :     0.286 MB/s [    69.8 IOPS]
   Random Write 4KB (QD=1) :     0.812 MB/s [   198.3 IOPS]
   Random Read 4KB (QD=32) :     0.709 MB/s [   173.2 IOPS]
  Random Write 4KB (QD=32) :     0.684 MB/s [   167.0 IOPS]
  Date : 2013/05/13 10:21:22
ASM1061 with ASM driver
           Sequential Read :   104.502 MB/s
          Sequential Write :   100.612 MB/s
         Random Read 512KB :    27.805 MB/s
        Random Write 512KB :    49.150 MB/s
    Random Read 4KB (QD=1) :     0.289 MB/s [    70.5 IOPS]
   Random Write 4KB (QD=1) :     0.785 MB/s [   191.7 IOPS]
   Random Read 4KB (QD=32) :     0.781 MB/s [   190.8 IOPS]
  Random Write 4KB (QD=32) :     0.726 MB/s [   177.2 IOPS]
  Date : 2013/05/13 10:08:57
renethx is offline
post #15 of 24 Old 05-13-2013, 09:19 AM - Thread Starter
Elpee's Avatar
Quoted: 61 Post(s)
Very simple. As many people here, my home media server is running out of space and I want to move drives from Norco-4020 to a new box (Lian Li D8000) and add more drives there. Hope I can stay with it in 3 - 4 years biggrin.gif
Elpee is offline
post #16 of 24 Old 05-14-2013, 08:19 AM - Thread Starter
Elpee's Avatar
Quoted: 61 Post(s)
Thank you, Renethx.
I just bought a SYBA SI-PEX40064 (Marvell 88SE9215 chip) card and a Syba SY-PEX40039 (ASMedia 1061 chip) card.
I'll test those cards in the next few days when I get them in hand.
Elpee is offline
post #17 of 24 Old 05-14-2013, 09:21 AM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
I just saw this posted today:
http://slickdeals.net/f/6026850-SYBA-SY-PEX40039-PCI-Express-2-0-SATA-III-6-0Gb-s-Controller-Card-4-99-AC-AR-Shipped-Newegg-com
Newegg has the Syba SY-PEX40039 PCI-e controller for $4.99 after rebate and coupon code DIYSMMR38 with free shipping.
captain_video is online now
post #18 of 24 Old 05-14-2013, 10:00 AM - Thread Starter
Elpee's Avatar
Quoted: 61 Post(s)
Elpee is offline
post #19 of 24 Old 05-15-2013, 06:48 AM
AnthonyB's Avatar
33 drives would be 132TB for 4 TB drives and 99TB for 3 TB drives.
Even if you planned to do RAID-1 this is still 66TB or 49.5TB
Do you plan on crawling the web for half it's media content? Or, do you plan to back up about 600-1200 Blu-Ray discs? (RAID-1 with half the amount of usable space)..
That's the reason mfusick and I were wondering.
AnthonyB is offline
post #20 of 24 Old 05-15-2013, 07:15 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I'm closing in on 30TB and I've nearly completely ripped every DVD and Bluray I've owned or collected since the 1990's - and I've got tons of complete organized TV shows/recordings.
I also have programs, pictures, backups, music all stored in my server. And I have 4TB free space.
It's taken me a long time to get this big and I fully understand how much I have and how beyond normal it is to have this much or a server like mine.
100TB just blows my mind
Mfusick is offline
post #21 of 24 Old 05-15-2013, 07:37 AM
AnthonyB's Avatar
Isn't that about 110TB in RAID-5?
Mfusick, that's called digital hoarding... lol
AnthonyB is offline
post #22 of 24 Old 05-22-2013, 12:28 PM - Thread Starter
Elpee's Avatar
Quoted: 61 Post(s)
Code:
Renethx, I can confirm both raid cards work jus fine on my window 2012 server (no drivers needed).
Elpee is offline
post #23 of 24 Old 05-23-2013, 12:25 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
They should. Most mainstream products work on Microsoft server OSes without much fuss
Mfusick is offline
post #24 of 24 Old 01-23-2014, 08:59 AM
rtrg's Avatar
I have a 4 port SATA controller card for PCI slot. Number SIL3114. Came with cables and driver cd.
The cd is detected the drive is not. Both SATA and IDE are connected in order for the cd to be read. All is well until I open the INSTALL folder. I get an error, "BAD SYNTAX". at every attempt. My intention is to try this drive in this ide desktop to see if there are any usable benefits to it. If yes than I would clone more drives as spares for other desktops both sata and ide. Any solutions? I have a one piece cable adapter that is supposed to be plug and play and clips onto the sata drive to accomplish the same thing. The last one I had had a broken plastic missing that covered the pins. I think that is why it did not work. If the new one does not work I will give up and stay with ide. I do not have any spare ide drives. Any help welcome. Is it possible I got stuck with a bad controller card?. Would a usb powered card be better? Plug and play? Can I add a usb hub or add a usb card? Also plug and play? No ports available.
rtrg is offline
Reply Home Theater Computers
