Metadata applications for servers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-11-2013, 01:43 PM - Thread Starter
ajkrishock's Avatar
Quoted: 76 Post(s)
Liked: 33
All,
Is there an application that I can use that will download metadata for my movie folder on my windows home server? I have been looking at media center master, but so far it doesn't seem to be working (I'm still experimenting with it though). My goal is to provide synopsis data for all my movies. I have Yammm running in the background for cover art, but that's all it does.
If media center master is the right application, is there a guide available for it? Do I have to remove Yammm?
ajkrishock is offline
post #2 of 7 Old 05-11-2013, 02:35 PM
NNate's Avatar
Quoted: 54 Post(s)
I could never get Media Center Master working the way I wanted it. I started using Metabrowser instead and it's been getting the job done for me as a service on my WHS2011 box. Only downside is that it's not free.
NNate is offline
post #3 of 7 Old 05-11-2013, 02:43 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Originally Posted by ajkrishock View Post
All,
I use mediacentermaster with good success for this.
What do you use for a front end? XMBC? mediabrowser.
You need the paid version of MCM to do everything, but make sure you have it set to create the metatdata for the front end you use.
Mfusick is offline
post #4 of 7 Old 05-11-2013, 04:31 PM - Thread Starter
ajkrishock's Avatar
Quoted: 76 Post(s)
Liked: 33
I would like to use the standard Windows 7 media center interface as my front end. Is that possible?
post #5 of 7 Old 05-11-2013, 04:54 PM
bryansj's Avatar
Quoted: 1136 Post(s)
Liked: 560
My Movies has a WHS 2011 (and Windows Server 2012 Essentials) database component that runs on your server that the WMC application connects to.
bryansj is offline
post #6 of 7 Old 05-11-2013, 07:56 PM - Thread Starter
ajkrishock's Avatar
Quoted: 76 Post(s)
Liked: 33
Well, I've been experimenting with media center master for about an hour now, and I've figured out how to download metadata and place it in the correct folder. The problem now is that my HTPC's still show the old (Yammm generated) xml data (which is essentially nothing). Do I need to clear out all the old Yammm xml stuff for the new stuff to work?
post #7 of 7 Old 05-12-2013, 09:34 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Mediabrowser plugin for WMC is better choice IMO
Mfusick is offline
Reply Home Theater Computers
