Does the reciever mather, sound quality question. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-11-2013, 01:39 PM - Thread Starter
schmidter's Avatar
My computer is playing the videofile with the sound included. It passes through my reciever. Does the reciever in any way have an effect of the sound quality, or is it only the sound card on my computer (that is playing the sound) and of course the speakers?
My theory is, that it doesnt really have an effect, since it is only used as a gateway, but im not sure.
My reciever is this: Sony CMT CP33MD
Picture:
schmidter is offline
post #2 of 2 Old 05-12-2013, 02:25 PM
sitlet's Avatar
Quoted: 14 Post(s)
Umm, it absolutely has an effect. Starting with the sound card, if you are using an analog output, then yes, the sound card will have an effect on quality, since it has to convert the digital sound into analog.
The receiver has the most effect on sound, since it is what's processing and amplifying the sound. A 15 dollar boombox will not have the same sound as a thousand dollar receiver.
The speakers also will obviously have an effect, especially with shelf systems like you have. Most manufacturers ship very cheap speakers with those systems. And most home theatres in a box (all in one) will have the same problem.
sitlet is offline
Reply Home Theater Computers
