looking for a low power full 3d HTPC, will work 24/7 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-12-2013, 12:17 AM - Thread Starter
roymesi's Avatar
Hi,
I want to build an HTPC system which will also fuction as a download server, will work 24/7 (don't care if linux or windows).
As such, I need it to be power efficient, and quiet, and avcourse, cost effective...
I thought about the i3-3225 processor (with the graphic process Intel® HD Graphics 4000), and a low voltage ram. I want it to support full 3d bluray (not HSBS).
Which case should I use?
All the HTPC cases I've seen has a 300-400W Power supply. too much for a 24/7 server. I'm looking for a 30-60W system.
Which MB should I get? I want a micro ATX which will support low voltage ram for a low power consumption.
Can you recommend?
roymesi is offline
post #2 of 5 Old 05-12-2013, 12:41 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
A6-5400K is the most cost effective solution for BR 3D (only $62) and as power efficient as IVB (if you use an AV receiver, it must be HDMI 1.4a, otherwise you have to add a HDMI sound card [A6-5400K to the 3D display and a HDMI sound card to a HDMI 1.3 AVR]). CPU is weaker than i3, of course, it's equivalent to IVB Celeron. ASRock FM2A75 Pro4-M or FM2A85X Extreme4-M. You can save 0-1W at idle, 1-2W at video playback by going with low-voltage RAM.
The system with a SSD and a HDD will consume ~30W DC at idle, and -80W DC at full CPU+GPU load (that rarely happens). So you can use a pico-PSU. The efficiency of a typical 300-400W 80 PLUS Bronze PSU in this range is 75%-85%, and that of a pico-PSU is ~90%. You can save (30W)/(0.8)-(30W)/(0.9) = 4W = ~$4 per year (or more depending on your location) by going with a pico-PSU.
HTPC case depends on the number of HDDs you want to have. Many microATX cases can hold 2-4 HDDs, while some ATX cases (you can use a mircroATX mb in an ATX case of course) can hold 8 HDDs (or even 11 HDDs without an optical drive, e.g. SilverStone GD07/GD08). Add ~6W for each HDD.
renethx is offline
post #3 of 5 Old 05-12-2013, 07:01 AM
C17chief's Avatar
Quoted: 12 Post(s)
Liked: 24
Generally speaking, AMD CPU's are not as efficient as far as performance per watt goes.
As far as trying to search out the lowest rated power for each part at any cost goes...that is wasted effort/lost cause IMO. Pretty much any configuration for a modest HTPC using integrated graphics, whether it be Intel with it's IGP or AMD with it's APU should run in that 30-60w range these days as it is with current parts, with no particular attention paid to efficiency.
The only 3 areas that would really be significant are the CPU, Video, and Power Supply.
CPU....pretty much common sense here. Keep in mind the purpose and stay away from the overkill. You don't need a power hungry A10, or a juiced up overclocked i7 for a HTPC. Stick with a lower end modest processor which by nature consume less power. A general HTPC isn't processer intensive, so anything currently out there short of an Atom level processor will do everything you need just fine.
Video...same idea as CPU, but there can be benefit to a powerfull card. You don't need some powerfull HD7970 or something for an HTPC. Out of the current choices out there, even the lowest integrated video has enough hardware support for a basic HTPC. In your case however, you do want to pay attention to the 3D capability since you intend on using that. Some of the lowest models do not have that functionality, which appears you already know. Where better video cards come in is if you want to do significant postprocessing/scaling/etc with codecs like MadVR....which can use significant GPU resources. If you don't intend on using something like that, you don't need a fancy vid card and the power that goes with it.
Power supply...the overall wattage doesn't matter much as long as it is sufficient. It's all about efficiency as renethx started explaining. That said, there is more to it then simply 80+, bronze, gold, etc. Peak efficiency occurs at a certain load particular to the actual PSU and can vary from one model to the other. For example one particular power supply could be listed as 80+ and is in fact 80+ efficient at say the 70-90% load range, but only be like 70% efficient at the 10% load range. You might have another that is not 80+ or anything that is actually like 85% with a low load but much less with a higher load in relation to it's rated output...that sort of thing. You can find efficiency charts for some higher end higher wattage PSU's that show it's efficiency across the whole load range, but isn't all that common and you probably wouldn't on lower wattage more modest ones, so there is no real way to know for a modest power supply for a low power system. I would simply go for the highest quality 300w you run across that isn't outrageously more expensive then the low priced ones with similar wattage as far as ATX goes...and as far as the ITX types, get a seasonic since there is them and cheap no name with no other option pretty much. Basicly what I am getting at is there is no reason to spend $100 on a super duper best most efficient 300w that money can buy vs a decent $30 one just to save literally a few dollars per year on efficiency.
C17chief is offline
post #4 of 5 Old 05-12-2013, 07:31 AM
jhoff80's Avatar
Quoted: 394 Post(s)
Liked: 361
If you want the best power efficiency, it would really make sense to wait for Haswell in June.
jeffkro likes this.
XBL/Steam: JHoff80
jhoff80 is offline
post #5 of 5 Old 05-13-2013, 11:39 AM
jeffkro's Avatar
Yup, the whole design focus of Haswell seems to be focused on low power. I'm even thinking about replacing my llano setup with it for this reason. You think they will have the dual core version at release?
jeffkro is offline
Reply Home Theater Computers
