Latest Ceton InfiniTV 6 Info Thread - Page 37 - AVS Forum | Home Theater Discussions And Reviews
 21Likes
post #1081 of 1188 Old 05-03-2015, 01:22 PM
rc05's Avatar
Quoted: 152 Post(s)
Liked: 87
WMC will keep working, it just probably won't be in Windows 10. Some of us are stuck on Windows 7 anyway if we use non-Xbox 360 extenders, and it will keep working as long as there's guide data (and possibly even further since we can get guide data elsewhere and into WMC). I think WMC will effectively work until CableCARDs are phased out, and possibly even after that for OTA. Something better will probably come along before then though.
When Microsoft pulls the plug for guide data, whenever that may be, there may be an adequate replacement for WMC, or we can get guide data from another source. It's not like WMC is going to suddenly stop working when Windows 10 comes out.
rc05 is online now
post #1082 of 1188 Old 05-03-2015, 01:38 PM
Ken.F's Avatar
Quoted: 1471 Post(s)
Liked: 1255
It will suddenly stop working if you upgrade to Windows 10. They announced Win 10 won't have WMC a few days ago.
Ken.F is offline
post #1083 of 1188 Old 05-03-2015, 01:42 PM
rc05's Avatar
Quoted: 152 Post(s)
Liked: 87
Then don't upgrade. As I said before, some people can't upgrade past Windows 7 since they use Extenders. End of the road there. If not upgrading isn't an option, sure, it's dead. One possible option until the HDHR DVR or something else comes out is to load Windows 7/8 on another computer and WMC will keep chugging along happily. Having a computer dedicated to WMC duties is generally recommended anyway.
rc05 is online now
post #1084 of 1188 Old 05-03-2015, 02:10 PM
Ken.F's Avatar
Liked: 1255
I've been frozen at Win7 due to my Echo extenders.
Ken.F is offline
post #1085 of 1188 Old 05-03-2015, 02:33 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
Or maybe they can plead with and PAY silicondust to support their tuners in SD's DVR kickstarter! haha
Maybe SD would entertain the notion just to keep another company in the CC business?
It gets lonely when you look around and you dont have any peers-wait companies love being to only game in town-aka monoply power in the marketplace.
qz3fwd is offline
post #1086 of 1188 Old 05-28-2015, 08:09 PM
ieko's Avatar
I know some of you have had some trouble with the eth6 rebooting and then ending up with a bad pairing which causes WMC to become useless. I've put together this simple batch script to ping the eth6 and then restart the EHRECVR service when the eth6 is seen going offline, this forces a repairing once the eth6 is online again.
I've only been using this for a week but so far it's saved me a few headaches already. Keep in mind it may not be full-proof. However, I expect this will be much better than the babysitting we've all experienced.
Some things to know before you do this
- set a static IP for my eth6 so that the script always has the correct IP address.
- Download & install https://www.microsoft.com/en-us/down....aspx?id=17657 so that the sleep command will work for you.
- the script creates a log file on c:\ to show when it found eth6 to be unresponsive.
- to really have this work you'll want to set the script up to launch before login. I haven't done this yet because I haven't had time to play with this, but I know it isn't hard, just google starting a batch file before login.
- I'm using Windows 7
- replace "10.0.1.230" with your eth6 ip
Just copy/paste this into notepad and save it as a .bat and launch it. Google creating batch files if you are lost here. The script is below!
@echo off
:start
cls
sleep 3
ping -n 1 10.0.1.230 | find "TTL"
if not errorlevel 1 goto start
if errorlevel 1 goto fix
:fix
NET STOP EHRECVR
sleep 10
net start EHRECVR
sleep 10
echo %date% %time% >> c:\ehrecvr_log.txt
goto start
ieko is offline
post #1087 of 1188 Old 05-29-2015, 06:48 AM
g0dM@n's Avatar
Quoted: 38 Post(s)
Originally Posted by mdavej View Post
I've done exactly that already. Works fine. Problem is memory leak isn't my only issue. Random reboots are another issue. Mine might spontaneously reboot after 2 days or 2 months, no way to predict. When it does, a reboot of my PC is also necessary. I don't know I need to do it until I notice a recording got missed. Has only happened twice in 3 months. So it's not a big issue, but an issue nonetheless. If they would just fix both bugs, then I wouldn't have to do any workarounds.
Does anyone know a way to restart the Ceton ETH through CLI, either SSH, telnet or the like?
Mine has been randomly rebooted, and then I have to restart my HTPC. I'd rather do all of this weekly myself. I can easily schedule and script it if there's a way to send commands to the Ceton tuner over the network.
g0dM@n is offline
post #1088 of 1188 Old 05-29-2015, 09:28 AM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Yes, I have scripted this as follows:
http://www.thegreenbutton.tv/forums/...p=85681#p85681
While this seems to work fine at first, it was not 100% reliable. If the timing wasn't perfect, I'd have to do a second reboot anyway. I never could get it quite right, so I gave up on it.
I'm really looking forward to trying ieko's solution. Sounds like it will do a much better job.
htpcforever likes this.
mdavej is online now
post #1089 of 1188 Old 05-29-2015, 09:35 AM
g0dM@n's Avatar
Quoted: 38 Post(s)
He essentially created a service... that's awesome.
Does the batch file run silent, though? If not, there is a way to run the batch file silent by launching it via vbscript.
g0dM@n is offline
post #1090 of 1188 Old 05-29-2015, 09:56 AM
mdavej's Avatar
Liked: 940
I'm sure you could. I just put mine in a scheduled task, no batch file. I think the window still popped up. But since I rebooted anyway, it didn't matter.
post #1091 of 1188 Old 05-30-2015, 01:49 AM
ieko's Avatar
I did manage to get it running as a service with no window. I don't have the time to post in detail right now, but if you downloaded the resource kit I posted about previously then you're basically set..
Just watch http://youtu.be/X6o1AvZ06zc and you'll probably get it.
You need to locate srvany.exe for this to work (included in resource kit).
ieko is offline
post #1092 of 1188 Old 06-03-2015, 11:36 AM
mdavej's Avatar
Liked: 940
Thanks ieko. Worked like a charm. You could also follow this procedure instead of watching the video:
http://wiki.scn.sap.com/wiki/display...indows+Service
I bumped the sleep time up from 3 seconds to 5 minutes on mine.
post #1093 of 1188 Old 06-06-2015, 03:40 PM
ieko's Avatar
Let me know how the 5 minute interval works, I made it 3 seconds because in testing I realized that the eth6 returns online very quickly from a crash.
ieko is offline
post #1094 of 1188 Old 06-06-2015, 06:36 PM
mdavej's Avatar
Liked: 940
Good point. 3 seconds it is then.
post #1095 of 1188 Old 07-10-2015, 12:20 PM
Karl Beem's Avatar
Quoted: 16 Post(s)
Comcast x1 compatibility
Just called comcast about replacing my old DVR with X1. According to them the cable card in my Ceton 6 is not compatible with X1. Could this be true? Has anyone switched to X1 and their Cetons quit working?
Karl Beem is offline
post #1096 of 1188 Old 07-10-2015, 12:28 PM
mdavej's Avatar
Liked: 940
It is not true. There's a recent thread at TheGreenButton by someone who just had X1 installed. It had no impact whatsoever on his cable card devices. This is either ignorance or BS from Comcast to squeeze more money out of you.
What you've literally stated may be true, that you can't remove the cable card from your Ceton and put it in your new X1 DVR. Not sure why anyone would ever consider doing that though as it wouldn't accomplish anything.
May I ask why you have a Ceton AND and cable company DVR? Most of use cable card tuners to avoid having to pay cable company DVR fees. If it's for the On Demand content, can't you just get that from the web?
post #1097 of 1188 Old 07-10-2015, 01:02 PM
Karl Beem's Avatar
Quoted: 16 Post(s)
I'd been planning on getting rid of it. I left it for my daughter.
post #1098 of 1188 Old 07-23-2015, 09:32 PM
Liked: 7
I've been in the early stages of planning out a HTPC setup centered around a DVR using the Ceton Infinitv 6 ETH, but after reading this thread, I must admit I'm a bit hesitant now. At $300 per, that's not pocket change to experiment with. Given the fact that Cox in my area (OKC) requires a tuning adapter that requires a USB interface to the tuner hosting its CableCard, the PCIe version is eliminated for me.
Is the consensus here that the Ceton 6 and its USB interface is best avoided? My hope was to completely discard my Cox DVR's and use the Ceton with MythBackEnd, but if the devices are this finicky I'm concerned it might not be a good idea; but going to something like the Hauppage 2650 only gives me two tuners, which won't get the job done if I want to connect more than my existing two TV's to a future distributed cable setup. Was originally excited for the Ceton 6; but now am really cautious.
Has anyone tried running the Ceton 6 USB through a VM?? USB passthrough to a VM seems a more likely route to work than routing an entire PCIe device...
Intrigued by all the PVR possibilities, but a little tempered now with info about the Ceton 6 being problematic...
VideoSooner is offline
post #1099 of 1188 Old 07-24-2015, 06:32 AM
Ken.F's Avatar
Liked: 1255
There is no such thing as a Ceton 6 USB tuner. The InfiiniTV4 is available as PCIe or USB. The InfiniTV6 is available as PCIe or ETH.
The InfiniTV6 ETH is a network device. It connects to your home network with an ethernet cable. The computer uses the tuner across the home network similar to how it would use a network printer. If your cable company requires the use of a tuning adapter, the USB cable goes between the TA and the tuner box. The TA's USB cable does not connect to the PC so I don't think a VM will make any difference.
InfiniTV6 ETH Quick Install Guide:
http://www.cetoncorp.com/documents/I...tion_Guide.pdf
Ken.F is offline
post #1100 of 1188 Old 07-24-2015, 06:58 AM
dbailey75's Avatar
Quoted: 62 Post(s)
Liked: 47
I guess everyone by now should have noticed that your guide data is being updated from a different sources. MS is no longer using zaptoit, or what ever it was called. I noticed that some of my channels went missing last week, re ran the setup, and there more more/different options than there had been previously. There's a thread over at the green button about it.
For the most part I don't have any issues, but the channel images for the various shows that MCE gives you in the bottom left, Id' say are 50% wrong. LOL
PSN: CAPTDANMAN
dbailey75 is offline
post #1101 of 1188 Old 07-24-2015, 07:09 AM
rontalley's Avatar
Quoted: 684 Post(s)
Liked: 329
I've been a follower of Ceton from the start and although the ride was bumpy but satisfying, I can tell you this, since buying a Roku my life has been much easier. Now as far as live TV goes, well the whole point of the Ceton was to record it so I can watch my favorite shows when I wanted to. I can pretty much well do that with Roku and my subscription to either Netflix or Amazon Prime. It's really a simple solution and only $70 for the Roku 2 (2015).
Ultimately, there was just too many issues that I had to address over the course of 5 years that really made me drop the whole cable card thingy idea and now again, life is simple.
If, I had to do it today, I would build a dedicated box to run W7 and get the ethernet Ceton 6. To me W7 is still a great OS but W8 has its benefits as well.
My setup involves a W7 Pro dedicated Box with WHS2011 running through VM Ware. I have WHS2011 doing all of the batch processing and serves as central storage and backups for all PCs but still have the ability to watch live TV via W7 (no longer subscribe to cable) . I use WHS2011 to manage my network and installed the lightsouts add-in, my movies add-in and works great accessing all of my stored files anywhere around the globe.
As cool as this all is, the rest of my family switches the input on the AVR, picks up the Roku remote and are just as happy as they can be that they don't have to go through all the hoops and loops just to watch TV....
rontalley is offline
post #1102 of 1188 Old 07-24-2015, 08:49 AM
sgbroimp's Avatar
Quoted: 276 Post(s)
Liked: 35
I have had a Ceton InfTV PCie6 for over a year now, after bad experience with the Inftv4 USB. The PCie6 has been terrific, never missing a beat. I must state, however, that we do not use TA's on our cable system, so that as caveat. I do believe the InfTVPcie6 is set up to handle that, however.
sgbroimp is offline
post #1103 of 1188 Old 07-24-2015, 09:53 AM
StephenRC's Avatar
Quoted: 23 Post(s)
I'm on Brighthouse and they also use a tuning adapter. The HTPC setup I have works great with the InfiniTV6 PCIe. The tuning adapter connects to the HTPC, not the Ceton. The Ceton software includes the TA drivers.
StephenRC is offline
post #1104 of 1188 Old 08-31-2015, 01:37 PM
crf19's Avatar
I have one of the Ceton InfiniTV 6 that is was never able to get to work, It would show cable card inserted, then a few min later would show invalid cable card. Never was able to get help from Ceton. I had used the Ceton InfiniTV 4 and it worked ok.
crf19 is offline
post #1105 of 1188 Old 08-31-2015, 01:50 PM
miles267's Avatar
I started with their InfiniTV 4. Both the first and second generation versions of the Pci-e card. The latter ran cooler. Regardless it was still hot and required too much cooling. Then moved to their InfiniTV 6 ETH external tuner that ran hotter despite being external. The constant communication issues between the HTPC and Tuning Adapter became exhausting.
Since moved to a TiVo Roamio with 6 internal tuners that runs silent, ice cold and zero TA issues.
I must admit, I thought I'd never favor a device over my HTPC but that's no longer true.
mdavej likes this.
miles267 is online now
post #1106 of 1188 Old 09-28-2015, 08:50 PM
g0dM@n's Avatar
Quoted: 38 Post(s)
My ETH6 has been acting up a lot lately. WMC will say there are no tuners available and for me to choose one of 4 to cancel. That doesn't work. Basically, when I log into the Ceton tuner via the web interface, it'll often show 5 of the 6 tuners on the same channel!! Lately, we haven't used ANY satellite setups. We use WMC on one (the main) TV in the house, which is configured to use either 4 of 6 of the tuners.
Since the ETH version runs dynamically, I think that's the problem. Is there any way I can go back to the static model of using tuners? This dynamic setup sucks... plain and simple. It's never been stable and just a HORRIBLE design overall. I'm so sick of being dissatisfied and just trying hard to get this to work. I can list 1000 different things I've done to make my experience better, but having attenuators, a fan on the tuner, using only one HTPC, and having a wired Cat6 gigabit network (on an enterprise-class switch, nonetheless) is more than plenty to give myself the best type of setup.
Any advice, without making fun of my horrible experience?
g0dM@n is offline
post #1107 of 1188 Old 10-02-2015, 10:22 AM
dbailey75's Avatar
Quoted: 62 Post(s)
Liked: 47
[Is there any way I can go back to the static model of using tuners[/QUOTE]
I reloaded the OS, on one of my HTPC's using the latest drivers, during the setup I never came across the tuner assignment screen. while the tuner pooling was always considered beta, I choose to stay with tuner assignments, at this point I can only assume tuner pooling is no longer beta, as my other two PC's are running the older drivers, setup still takes me through the tuner assignment configuration, so with that said maybe rolling back to an older driver may help you.
So far I haven't run into any issues with the other PC's. I did receive the no tuner available message while two show's were being recorded while I was watching a 3rd on the PC I reimaged, I hit cancel on the error message, and confirmed the other show's were recording without issue.
PSN: CAPTDANMAN
post #1108 of 1188 Old 10-02-2015, 11:02 AM
g0dM@n's Avatar
Quoted: 38 Post(s)
So far I haven't run into any issues with the other PC's. I did receive the no tuner available message while two show's were being recorded while I was watching a 3rd on the PC I reimaged, I hit cancel on the error message, and confirmed the other show's were recording without issue.[/QUOTE]
It has been a horrible experience for me. My wife hates the setup (she doesn't say so, but I know it), and I don't blame her. I, too, choose the tuners during setup, but it's still dynamic. I can choose all 6 on my HTPC, and the other machines on the network can choose any of them also. Maybe I won't choose all 6 so that it doesn't share a tuner with the other machines on the network. That may make more sense. Regardless, the product is quite unstable. It wasn't a good investment overall, not after you factor in the serious amounts of time I've had to diagnose and fix problems. I didn't have a great experience with the original 4-tuner PCIe either years ago. I've always had bad luck with them.
I'll admit, after the first 1-2 weeks of horror with the ETH 6, it was good for a few months, but for the past year it gradually got worse. It was bearable until this past summer.
g0dM@n is offline
post #1109 of 1188 Old 10-02-2015, 01:13 PM
dbailey75's Avatar
Quoted: 62 Post(s)
Liked: 47
I've had my ETH running almost two years, and I'm fairly happy with it, I had my PCIe tuner going for over 3 years before replacing in with the ETH. Figure $50/ months in savings over comcast's DVR system, $3000, cha ching I already had the PC's running XBMC before going with tuners, so for me it's been great, I've gotten so lazy with my setup, even the annoying prompt to upgrade My movies no longer bothers me, lol. I'll admit I did power cycle the tuner the other day, but I can't remember the last time I did that.
make sure your running the latest firmware/drivers, not the beta's.
PSN: CAPTDANMAN
post #1110 of 1188 Old 10-02-2015, 05:07 PM
g0dM@n's Avatar
Quoted: 38 Post(s)
I don't recall any drivers needing to be installed, just the setup for the software (diagnostic software and plugin to WMC). FW I can check, as well as the software version (I'm sure it's the latest).
g0dM@n is offline
Reply Home Theater Computers
Ceton , Ceton Infinitv 6 Pcie 5205 Dct06in Pcie Six Tuner Card For Watching Digital Cable Tv On The Pc Pci E
