Latest Ceton InfiniTV 6 Info Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 21Likes
post #91 of 1188 Old 05-16-2013, 09:33 AM
Kadath's Avatar
Quoted: 329 Post(s)
Liked: 203
Originally Posted by Sammy2 View Post
@Kadith..
Is this the first time using a CableCARD tuner for PC?
Have you checked the signal levels and strength for the cable feed itself?
In addition, typical wireless connections cause problems for video signals not due to speed but due to packet loss and insufficient time to resend lost packets before the next frame needs to display.
Yep, first Cable Card experience.
I am not sure how to check cable feed strength as a consumer, how do I measure that?
Yep expect that moving from wireless to wired will help. Will know for sure tonight.
Originally Posted by gsr View Post
Ceton's drivers are supposed to fix this, but I've found that I still need to use Tuner Salad to get past the 4 CableCard tuner restriction. Note that I last checked this the last time I rebuilt the PC, so it's possible they've resolved the problem since then, but it sounds like that's most likely the problem here.
Yep, sounds like I need to install Tuner Salad:
http://www.mychannellogos.com/Pages/TunserSalad.aspx
Buncha savages in this town....
Sam Posten
Kadath is offline
post #92 of 1188 Old 05-16-2013, 09:43 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I don't have the InfinTV product but have the HDHR Prime. You should be able to check the signal strength either in the set up program or in the WebGUI for the tuner itself which is where it is found in the HDHR Prime.
Sammy2 is offline
post #93 of 1188 Old 05-16-2013, 11:06 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1060 Post(s)
Liked: 990
^ Yes, Ceton's diagnostic tools will display signal strength and S/N ratio among other information.
gsr is online now
post #94 of 1188 Old 05-16-2013, 11:37 AM
cybrsage's Avatar
Liked: 154
Originally Posted by Kadath View Post
Outstanding issues:
- It did tell me that it thought the Ceton could only use 4 tuners. Will have to figure that out eventually but I don't see me using more than 3 at a time for the foreseeable future anyway.
-Need to figure a way to lock keyboard input while watching. Cats walk over the keyboard!
-Definitely going to have to calibrate this screen. Too bright for sure.
-Definitely see all of the flaws of the compressed cable image, I guess I will get used to it but for some reason it looked way worse than it does coming off the Fios set top box going to my 120" screen. Again, taking it to wired will probably help that.
I am not sure if it still applies to the Eth 6 tuner, but I had to install a Low Pass Filter (LPF) on the coax line running into the PCIe 4 tuner version in order to fix the corruption issues you are talking about. If you request a tech come out to fix the problem, he will have one in his truck he can install for free. I would wait until after the physical network is setup, just in case that is the issue.
cybrsage is offline
post #95 of 1188 Old 05-16-2013, 12:13 PM
Kadath's Avatar
Quoted: 329 Post(s)
Liked: 203
OK, will wait on that. Not something i can order via Amazon and install myself?
Sam Posten
Kadath is offline
post #96 of 1188 Old 05-16-2013, 12:48 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
You can but if you can get it installed for free..
Sammy2 is offline
post #97 of 1188 Old 05-16-2013, 02:09 PM
jimwhite's Avatar
You need better trained cats like mine.... watching them walk around the coffee table without stepping on anything, you'd think they were on a minefield !biggrin.gif
Jim White
St. Petersburg, FL
jimwhite is offline
post #98 of 1188 Old 05-16-2013, 02:13 PM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
Send a message via Skype™ to mariob33
Originally Posted by mariob33 View Post
Is it normal that FW would take for a non-intended piece of HW? Wondering why when you selected the drop down for the ETH it doesn't just show versions intended for that specific device.
Either I wasn't clear, or you didn't understand what I was writing (I was rather tired when I posted last night, so it's likely that I wasn't clear), so I'll try again smile.gif. The updater presented 4 items as being available:
- Stable Hardware Version Update (7359)
- Stable Firmware Version Update (I don't recall the exact version number, but lower than the beta version)
- Beta Hardware Version Update (7287)
- Beta Firmware Version Update (13.5.6.133)
These are all intended for the InfiniTV 6 ETH. The instructions very clearly stated to select the stable versions of pooling wasn't desired or the beta versions if pooling was desired. I blithely forget about that while I was making my choices and decided to go with the highest version number on each, so I've got a mix of a stable hardware version and beta firmware version installed in the device. I'm not sure if having a mix of stable and beta installed is the source of my problem or if something else is causing the it.
The hardware and firmware versions the device shipped with were REALLY ancient, so I'd definitely recommend that anyone getting one of these follow the instructions and upgrade to either the stable (no pooling) or beta (pooling) set.
Once the problem gets resolved, I'll post an update so (hopefully) nobody else will run into the same problem. I'll have a limited window of opportunity to do anything with it tonight as I've got an important hockey game to watch (Go Bruins!) smile.gif.
Ah got it! You were probably clear and I just read too early in the morning. You know that AVS fix first thing in the morning is tough. But yes go B's. I know you won't admit it but you def went to bed game 7 at 4-1 lol. I have been pleading the 5th when asked by my non-mass counterparts. smile.gif
In search of video bliss...
mariob33 is online now
post #99 of 1188 Old 05-16-2013, 04:46 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 990
When I got home earlier, I gave the PC a good-old-fashioned shutdown, unplugged the InfiniTV 6 ETH for 30 seconds or so, plugged the InfiniTV 6 ETH back in, and powered the PC back up. I then setup 10 recordings from consecutive channels in the guide and headed off to the gym. When I returned, all 10 had completed without any apparent issues. I also had a reply from Ceton support - they suggested installing several updates / hotfixes, etc. (a few of which the PC already has), but didn't suggest the simple solution of power cycling everything... The updates and hotfixes might have some benefits, but I've been running 2 InfiniTV 4 PCIe's for many months without ANY issues, so I'm not exactly confident that a PCI driver update would have helped solve the problem I ran into rolleyes.gif.
I have absolutely no idea what you're talking about biggrin.gif.
I considered shutting it off, but my normal bed time is later than that so I decided to stick with it (and I've got the phone records to prove it biggrin.gif). Boy am I glad I did - that was one heck of a comeback smile.gif. If it had been a regular season game, I probably would have shut it off, but not a game 7 in the playoffs. I hope the B's play more consistently in this next series as they've been driving me nuts...
gsr is online now
post #100 of 1188 Old 05-16-2013, 05:24 PM
Kadath's Avatar
Quoted: 329 Post(s)
Liked: 203
Yeah when I'm in the room it's no sweat, but expect that this box will run in background without me around to shoo them off....
Sam Posten
Kadath is offline
post #101 of 1188 Old 05-16-2013, 05:27 PM
Kadath's Avatar
Quoted: 329 Post(s)
Liked: 203
I'm not seeing those, where in the panel is it?
OK, I updated the software and moved to wires and its a lot more stable, but now the display is flashing white on all encrypted channels.... Ideas on that?
On the plus side, when I re-ran Media Center setup it recognized that I had 6 tuners! So no tuner sandwich.
Sam Posten
Kadath is offline
post #102 of 1188 Old 05-16-2013, 05:49 PM
Haba's Avatar
Take a look at both of these links.
SNR and Signal Level explained
Stuttering, Jittery or Flickering video
Haba is offline
post #103 of 1188 Old 05-16-2013, 06:28 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 990
Go to the Devices tab, then click on the Go to InfiniTV Device Webpage button. On that page, there are tabs for each tuner as well as a few other tabs. You should find what you're looking for there.
gsr is online now
post #104 of 1188 Old 05-16-2013, 08:39 PM
Kadath's Avatar
Quoted: 329 Post(s)
Liked: 203
OK, that page seems to be saying the same thing as these posts, it sounds like a stupid registry issue and not the low pass filter:
http://www.evga.com/forums/tm.aspx?m=1543142&mpage=1&print=true
http://experts.windows.com/frms/windows_entertainment_and_connected_home/f/114/t/102998.aspx?PageIndex=1
Screwed if I can follow the dopey instructions on those pages on what they want me to muck with in the registry tho. Will try the full screen video thing your page suggest tho!
Edit nope, full screen setting didn't help anything.
Will check that thanks!
Edit: Tuner #4 has carrier lock, digital lock and singal level -3.5 dBmV signal, 38.6 dB SNR, 54.6c degrees, One copy allowed 0x02
Any idea why it set it to tuner 4 when none of the others in use?
Sam Posten
Kadath is offline
post #105 of 1188 Old 05-16-2013, 08:55 PM
Kadath's Avatar
Quoted: 329 Post(s)
Liked: 203
Here's what the flashes look like:
http://www.youtube.com/watch?v=WrX7o7C-wGA
Sam Posten
Kadath is offline
post #106 of 1188 Old 05-16-2013, 09:05 PM
drtdiver's Avatar
looks like you have dynamic contrast enabled. should be a setting in your graphics utility to turn it off.
drtdiver is offline
post #107 of 1188 Old 05-16-2013, 09:33 PM
Kadath's Avatar
Quoted: 329 Post(s)
Liked: 203
I have tried it both on and off using the Nvidia control panel and changing it has no effect.
Sam Posten
Kadath is offline
post #108 of 1188 Old 05-17-2013, 12:42 AM
motz2k1's Avatar
Originally Posted by L54 View Post
Can somebody explain the differences between using network tuners versus PCI?
Tuner pooling is supported on both Windows 7 and Windows 8 Pro w/MC on infiniTV 6 ETH. This is dynamic allocation of tuners.
Tuner pooling is not a feature of the PCIe or USB products.
Network tuners is a PCIe/USB feature where you can assign tuners to specific PCs which is Windows 7 supported only.
Software Developer on My Media Center -> Ceton Corp.
motz2k1 is offline
post #109 of 1188 Old 05-17-2013, 10:17 AM
smcmillan2's Avatar
Quoted: 379 Post(s)
Liked: 223
I had the same when I was using an nVidia card - See http://www.thegreenbutton.tv/forums/viewtopic.php?f=7&p=19828
I remember setting "Digital Color Format" to "YCbCr444" and "Content Type Reported to Display" to "Full Screen Videos", and the flickering went away. Don't know if those settings still apply/fix anything in the latest nVidia drivers or not.
smcmillan2 is offline
post #110 of 1188 Old 05-17-2013, 10:34 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
Memorial Day? Fourth of July? Labor Day?
Just sayin'!
Whichever holiday Ceton decides to throw $50 to $100 to bring the price down.
Not that I regret paying $430 for the InfiniTV4 and waiting 6 months for it, but I was in a bind then, ATI dropped support for their DCT, and Verizon switched to Symulcrypt. This time, I can wait for the price to come down to match the current InifniTV4 pricing on per tuner basis (approx $40/tuner).
At $199 I would buy without hesitation, at $250, I would have to mull it over, and perhaps get permission from the "boss" and then buy it.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #111 of 1188 Old 05-17-2013, 11:25 AM
Kadath's Avatar
Quoted: 329 Post(s)
Liked: 203
OK, will try both of those. Are they in the Nvidia control panel or do I have to go directly much with registry entries? (bleh!)
Sam Posten
Kadath is offline
post #112 of 1188 Old 05-17-2013, 12:00 PM
cybrsage's Avatar
Liked: 154
When I downloaded the beta drivers for Win8, it did not give me the option to select driver pooling. I did get the option in the Windows 7 beta drivers.
Also, should I go ahead and update the card to the newest Stable Hardware Version Update (7359)? Right now I am on the older, beta ones.
cybrsage is offline
post #113 of 1188 Old 05-17-2013, 01:30 PM
erickotz's Avatar
Liked: 30
It sounds to me like you're confusing Tuner Pooling and Network Tuners.
Tuner Pooling requires as InfiniTV 6 ETH + beta firmware and is supported on Windows 7 and Windows 8. It does not need a client add-in.
Network Tuners works with all InfiniTV tunes, but is only supported for tuners hosted on Windows 7. This requires a 1-1 tuner assignment.
Quality Assurance Manager, Ceton Corporation
erickotz is offline
post #114 of 1188 Old 05-17-2013, 03:29 PM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
I just got my 6 installed and connected. I see it in the diagnostic tool but its not available in my wmc setup. I only see my PCI tuners. Did anyone who has gotten it working run in to this situation? I have installed the FW updates/rebooted several times no dice. The tuner appears to be ok from the diagnostic perspective just not available as an option inside of WMC. As a note I have never used TunerSalad. Always just relied on the Ceton tool to unlock more than 4 tuners inside of WMC.
edit:
Never mind user error. I never cleared and re-detected my tuners. As soon as I did that I saw the PCIe and the Network Tuner.
post #115 of 1188 Old 05-17-2013, 05:11 PM
cybrsage's Avatar
Liked: 154
OH! I probably am! Sorry about that!. In order to remove that piece from WIn7, do I need to uninstall and reinstall the drivers?
cybrsage is offline
post #116 of 1188 Old 05-17-2013, 05:32 PM
erickotz's Avatar
Liked: 30
I believe you can go to add/remove programs and hit change.
erickotz is offline
post #117 of 1188 Old 05-17-2013, 07:10 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 990
InfiniTV 6 ETH #2 arrived today. Unfortunately, the CableCard swap from the InfiniTV 4 PCIe that it's replacing didn't go as smoothly as the first one did (actually, I think I got a less helpful CSR this time - the first one spent close to an hour with me while this one was clearly in a hurry to move on to the next call or to go home), so Verizon is sending me another CableCard. I left a message on Ceton's CableCard assistance line - with a little luck they'll be able to help Verizon get me up and running without having to wait for the new card to arrive (fingers crossed).
gsr is online now
post #118 of 1188 Old 05-17-2013, 07:41 PM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
Got mine and same experience. She wanted to send me a replacement for one that was working.
post #119 of 1188 Old 05-17-2013, 07:47 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 990
I suspect it's a combination of how knowledgeable the CSR is and how determined the CSR is to get it working. Obviously some CableCards are defective and won't respond to a new activation signal, but I suspect most of the time it just comes down to luck of the draw in which CSR you end up with.
On another note, I don't remember seeing any option to turn tuner pooling on when I installed the new driver package the other night. Should I have seen an option for that somewhere or does it just happen by default with the beta drivers? Ideally, it would be nice to be able to assign some tuners to a specific PC and then throw the remaining tuners into the pool.
gsr is online now
post #120 of 1188 Old 05-17-2013, 07:52 PM
Kadath's Avatar
Quoted: 329 Post(s)
Liked: 203
White flashes were due to 1/2 me being a total dumbass and 1/2 half due to Dell. Trusted that when I used the dell tool to update my drivers that it actually updated drivers, it didn't. I updated to latest Nvidia WHQL drivers and flashes are gone. Sorry for getting folks wrapped around axel on a dumb issue!
Sam Posten
Kadath is offline
Reply Home Theater Computers
Ceton , Ceton Infinitv 6 Pcie 5205 Dct06in Pcie Six Tuner Card For Watching Digital Cable Tv On The Pc Pci E
