HTPC Connected to Pioneer VSX-42 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-13-2013, 07:16 PM - Thread Starter
rsaxman's Avatar
I have a HTPC that I am trying to run through my Pioneer Elite VSX-42 receiver, and then to my TV. (Via HDMI). 9 times out of 10, I cannot get any video. I do occasionally get sound though. When I connect the HTPC straight to the plasma, everything works perfectly. I have tried multiple cables, inputs, and even another computer with the same results. At this point I am about to go crazy, so any help would be greatly appreciated.
rsaxman is offline
post #2 of 3 Old 05-16-2013, 08:26 AM
myoda's Avatar
Liked: 57
Have you tried your pc on another receiver?
myoda is offline
post #3 of 3 Old 05-17-2013, 03:11 PM
JJHTPC's Avatar
Do you have the ability to dual screen? If so I have found this the best option with my setup.
First if you try to passthrough to the tv often you cannot pickup the correct resolutions/frame rates that the tv/projector has.
For example I have a Pioneer 1021 and a Panasonic projector. The pioneer only provided 1080 60i as output for video.
This was not acceptable in my book so I did dual screen, pushing HDMI audio to the receiver, and then dvi out for video.
This allowed me to bit-stream audio, and also allowed me to be able to output bd at 24p and television at 1080 60p.
JJHTPC is offline
Reply Home Theater Computers
