need advice for blue screen - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 37 Old 05-18-2013, 12:53 PM
drtdiver's Avatar
go into device manager click on display adapters and what does it say?
drtdiver is offline
post #32 of 37 Old 05-18-2013, 01:39 PM - Thread Starter
stevethebrain's Avatar
Quoted: 104 Post(s)
Liked: 25
intel (R)HD Graphics
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
post #33 of 37 Old 05-18-2013, 02:51 PM
drtdiver's Avatar
did u install the Intel graphics drivers yet? by any chance are you able to reproduce the blue screen at will? if not run with the new drivers for a while and see if it has solved your problems. please do report back I'd like to know how this turns out for you
drtdiver is offline
post #34 of 37 Old 05-18-2013, 03:07 PM
lagittaja's Avatar
Mmyeah those bsod's looked to be caused by the Intel graphics driver.
After you have cleaned the old drivers off of the system and installed the newest put Driver Verifier running for a day or two.
http://www.sevenforums.com/crash-lockup-debug-how/65331-using-driver-verifier-identify-issues-drivers.html
If no issues arise consider it solved.
lagittaja@Overclock.net | Lagittaja@MuroBBS | Also Anandtech AVForums DIYAudio Head-Fi XDA-Developers e-Savuke ECF VFF VaporWall VapePit & etceteros
Main rig
lagittaja is offline
post #35 of 37 Old 05-18-2013, 03:49 PM - Thread Starter
Quoted: 104 Post(s)
Liked: 25
here's what I updated
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22521&lang=eng&OSVersion=Windows%207%20(64-bit)*&DownloadType=Drivers
can't reproduce BS.
I will diffinitly report back w/ results.
actualley I'm not sure if I cleaned old drivers off.
I did'nt logicalley remove them.
I just did the above update.
STB
post #36 of 37 Old 05-18-2013, 06:54 PM
bryansj's Avatar
Quoted: 1130 Post(s)
Liked: 560
Your graphics are built into your Intel i3 550 CPU (has an integrated GPU). You have the basic Intel Core HD Graphics.
bryansj is offline
post #37 of 37 Old 06-24-2013, 08:13 AM - Thread Starter
Quoted: 104 Post(s)
Liked: 25
I haven't used the HTPC for about 5 weeks now just started using again for about 5 days w/out the BCOD.
here's a image the the BSOF
if compared to the example in post # 1
notice there is'nt a top code.
maybe the #ed codes will revelve exactly whats happening?
I just want to be prepared if the new graphics driver did'nt resolve this issuse.
STB
Reply Home Theater Computers
