Drive making knocking noise but SMART says it's ok? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-21-2013, 11:05 AM - Thread Starter
AnthonyB's Avatar
Is there is problem with the drive or what?
This is concerning me. It has one of my Domain controllers on it. It's backed up, but I'd rather not see it fail before I have a replacement.
AnthonyB is offline
post #2 of 5 Old 05-21-2013, 11:52 AM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
I just had a drive fail on me this week with no warning. In the past, I've only had one that Smart notified me before it died. I also have one that SMART gave me a warning of over 2000 bad sectors and climbing daily. I moved that one to a different system and have been using it for over 6 months.
If I were you, I would be shopping for a replacement.
Andy_Steb is offline
post #3 of 5 Old 05-21-2013, 03:07 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Yup. Replace ASAP. Then laugh when you use it in another system for less critical purpose and it lasts for years more.
Mfusick is offline
post #4 of 5 Old 05-21-2013, 09:23 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
I can't believe the thing is still running. I should install some monitoring software on that system and see what it is up to now.
post #5 of 5 Old 05-22-2013, 07:00 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I have a Samsung 750gb that should have died years ago ... rocking on hard. Makes horrible noise but works fine... Lol
Mfusick is offline
Reply Home Theater Computers
