Anybody get the Ceton/HDHomerun to work remotely through a VPN? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 05-21-2013, 08:28 PM - Thread Starter
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
kapone is online now
post #2 of 26 Old 05-21-2013, 09:55 PM
amarshonarbangla's Avatar
Quoted: 28 Post(s)
Liked: 43
Very interesting idea. Someone send me their tuners so that I can test this out biggrin.gif
amarshonarbangla is offline
post #3 of 26 Old 05-21-2013, 09:57 PM - Thread Starter
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
I did that testing. The Ceton AND HDHomerun BOTH work through a VPN.
post #4 of 26 Old 05-21-2013, 10:02 PM
Quoted: 28 Post(s)
Liked: 43
Wow this is brilliant in that I can potentially watch live TV anywhere as long as I have my laptop and a Wifi connection.
post #5 of 26 Old 05-21-2013, 10:26 PM - Thread Starter
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
Uhh....hang on cowboy...not that simple.
post #6 of 26 Old 05-21-2013, 10:34 PM
Quoted: 28 Post(s)
Liked: 43
post #7 of 26 Old 05-21-2013, 10:39 PM - Thread Starter
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
True.
Well, a PfSense router (or something similar), with OpenVPN configured for TAP with bridging to your local LAN (and a few firewall rules) will get you there.
The other constraints are typical. You better have good "upload" speeds on your home connection. I was testing with mine, which is relatively fast (150/65mbps), but I suspect anything under 35mbps upload (given network overheads), would be troublesome.
The fun part comes, where I'm testing the client, VPNed into my house over a 4G wifi tether...tongue.gif
post #8 of 26 Old 05-21-2013, 10:47 PM
Quoted: 28 Post(s)
Liked: 43
True.
So no stuttering issues? Are you viewing HD channels? Have you tried connecting with multiple clients?
post #9 of 26 Old 05-21-2013, 10:53 PM - Thread Starter
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
At our other house, no. Works flawlessly. But that has a 75/35 connection as well.
I tried both. SD obviously is much easier on bandwidth. HD is "mostly" ok with the occasional stutter in our other house. On 4G, SD just barely scrapes by. HD is almost unwatchable.
Sammy2 likes this.
post #10 of 26 Old 05-22-2013, 10:21 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
Does that mean if I have a pair of DD-WRT routers set up as a tunnel, I can bring an extender with us, connect to a TV where ever we are, and basically access out "DVR" at home?
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #11 of 26 Old 05-22-2013, 10:32 AM
Quoted: 28 Post(s)
Liked: 43
With a fast enough connection, I don't see why that won't be possible smile.gif
post #12 of 26 Old 05-22-2013, 10:40 AM - Thread Starter
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
You'd need to carry the second router and the extender with you, but yes, that should work.
Note: Make sure your DD-WRT routers can do "tap" device modes as well allow bridging the OpenVPN interface to the LAN interface, otherwise, this won't work. pfSense allows this, but I haven't played with DD-WRT enough yet.
post #13 of 26 Old 05-22-2013, 11:00 AM
signcarver's Avatar
If you mean WMC extender, it may not work... as WMDRM has latency detection to ensure devices are near... one of my old papers on this suggests 7 ms.
signcarver is offline
post #14 of 26 Old 05-22-2013, 11:19 AM - Thread Starter
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
True. The network conditions will determine that.
As an aside, we have FIOS and everything that we watch is copy freely. We don't have HBO/STARZ etc (Personally, I don't see why, but that's just me) so, it works in our scenario.
My motivation for setting up/testing this, wasn't so much our other house, but when me or my wife are travelling and/or my car (it has a Car PC hooked into the car, running XBMC/Media Center). The CarPC connects to my 4G phone via wifi tether and then VPNs into the house. (Works great btw smile.gif )
post #15 of 26 Old 09-06-2013, 08:16 AM
dannyboooy's Avatar
kapone - I've been searching for a way to do this and have set up a VPN using the Windows 7 vpn wizard. I can access my recorded programs remotely now and play them on WMC through the VPN but am not sure of the steps necessary to access my Ceton 6 tuner. Is there any way, if you have time, to respond with the steps to do this? I have Fios at both locations with 25/25 speed. Do I need to get a pfsense/openvpn setup as you mentioned above or is it possible to do using the windows vpn/fios router set up i have? Thank you!
dannyboooy is offline
post #16 of 26 Old 09-06-2013, 07:05 PM - Thread Starter
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
Yes, you need a an industrial grade router like pfSense or something similar. Windows VPN is very very rudimentary. It allows you access to the VPN machine, but not your whole home network.
post #17 of 26 Old 09-07-2013, 12:18 PM
Quoted: 28 Post(s)
Liked: 43
What are some alternatives to pfSense?
post #18 of 26 Old 09-07-2013, 02:32 PM - Thread Starter
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
M0n0wall, Smoothwall, ClearOS, IPCop etc. Some have firewall and routing functionality and more, others have less.
post #19 of 26 Old 09-09-2013, 03:14 PM
dannyboooy's Avatar
Thanks for the info Kapone. If I have an old PC with XP is that OK to run pfsense/open vpn or do you recommend a different OS?
post #20 of 26 Old 09-09-2013, 03:37 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
PfSense contains its own OS (freeBSD). Your hardware is most likely OK to use, but you need 2 network cards. One for WAN and one for LAN
Andy_Steb is offline
post #21 of 26 Old 09-10-2013, 07:26 AM
dannyboooy's Avatar
Ok, thanks for clearing that up for me. Really appreciate your help!
post #22 of 26 Old 09-10-2013, 07:30 AM - Thread Starter
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
btw, my pfSense runs as a VM under ESXi and the VPN still runs great. Yes, a minimum of two network ports are needed.
post #23 of 26 Old 09-10-2013, 07:41 AM
bryansj's Avatar
Quoted: 1123 Post(s)
Liked: 555
This needs to be on my to do list. I've got pfSense as a VM under my ESXi and four network ports to choose from. Just need to get around to setting up (and learning) the VPN.
bryansj is offline
post #24 of 26 Old 09-10-2013, 08:54 AM
dannyboooy's Avatar
Sorry but I am the definition of noob when it comes to a lot of these concepts. So most of my questions will probably be stupid but are you saying that I do not need to use another PC as my router but I can run pfSense virtually on my Win7 HTPC if I have 2 network ports?
post #25 of 26 Old 09-10-2013, 09:31 AM
Quoted: 28 Post(s)
Liked: 43
I believe VMWare supports PCI forwarding. So yes, it should be possible.
post #26 of 26 Old 10-31-2016, 10:50 AM
greg*o's Avatar
Looking to use a hdhomerun through a vpn and wanted to see if there are any updates to this very old thread
I would think that technology has changed in the last couple of years and that there might be better ways of accessing a hdhomerun in a remote site
thanks
greg*o is offline
Reply Home Theater Computers
