BlackGold BGT 3620 vs TBS 6280 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-31-2013, 01:31 PM - Thread Starter
josh_parker123's Avatar
I'm after a dual half height HD tuner and these seem two be the only options so could anyone give me some views and Comparison's between the two to make my decision easier please
josh_parker123 is offline
post #2 of 7 Old 06-01-2013, 06:07 AM
Heuer's Avatar
I gave up waiting for the Blackgold - all delivery promises were not met due to 'production problems'. So I bought a TBS and it has worked flawlessly for two years. No constant f/w updates to fix problems and, when I bought mine, it was considerably cheaper than the BG.
Heuer is offline
post #3 of 7 Old 06-01-2013, 07:39 AM
lagittaja's Avatar
So the TBS tuners are quite stable? Work great with WMC probably?
I'm looking at the 6280 as well, might even go crazy and get the 6284.
Sent from my GNote
lagittaja@Overclock.net | Lagittaja@MuroBBS | Also Anandtech AVForums DIYAudio Head-Fi XDA-Developers e-Savuke ECF VFF VaporWall VapePit & etceteros
Main rig
lagittaja is offline
post #4 of 7 Old 06-01-2013, 09:30 AM
tman247's Avatar
Quoted: 51 Post(s)
Liked: 47
Using a 6280 in my 7MC. Best tuner I've ever had. Rock solid, and drivers are updated regularly. They do a quad tuner as well.
tman247 is offline
post #5 of 7 Old 06-02-2013, 12:39 AM
politby's Avatar
Quoted: 63 Post(s)
Liked: 76
I have a 3620 and it performs perfectly.
OTOH I had many issues with my TBS DVB-S2 cards.
I am using DVBlink, though.
politby is offline
post #6 of 7 Old 06-02-2013, 02:16 AM
Heuer's Avatar
Sorry I should have said I am using the TBS DVB-S2 card with WMC. Never had a problem with stability - it just works!
Do a search on Blackgold and you will see there are some issues e.g. http://shop.blackgold.tv/Support/Product-Hot-Topics/Media-Center/Media-Center-7-Issue-PC-locking-high-memory-usage-loss-of-tuners
Heuer is offline
post #7 of 7 Old 06-02-2013, 02:47 AM
lagittaja's Avatar
That's great to hear. I just haven't heard of TurboSight brand ever before so I was a tad skeptical.
I was looking at the quad tuner, the 6284 like I said in my post. Not sure if I'd be comfortable shelling that much for a DVB tuner though.
And don't really know whether or not my signal would be good enough for four simultaneous recordings.
Right now with my signal being split to my Terratec H7 and my TV and watching same channel packet on both of them I don't see a drop in strength. The quality is at 100% of course. So recording max two channels from one packet would probably be okay while watching a third from other packet.
I might just get the 6280, not like I'd need to have four tuners. Watching one and recording another is good enough. And if it happens that there's three programs coming at the same time I could just record two and switch over to my telly.
Main rig
Reply Home Theater Computers
