Make a dumb tv smart. Make a smart tv smarter. - AVS Forum | Home Theater Discussions And Reviews
Old 06-09-2013, 10:46 AM - Thread Starter
scoobywrx99's Avatar
I've searched the forums and haven't found any info from av guys about this little divice.
http://m.youtube.com/watch?v=_B7ALe7qTSQ
It's an android micro PC and uses 4.2.2 jelly bean. The PC plugs into the hdmi slot w/video and audio. It has a quad core 1.8ghz processor with 2gb ddr3 ram and 8gb rom. It outputs 1080p with quad core Mali-400 gpu. It about 3"x1/2"x1 1/2".
I just ordered one and should get it an a week. Just curious if anyone here has had experience with these little guys.
scoobywrx99 is offline
Old 06-09-2013, 10:53 AM
almostinsane's Avatar
Quoted: 47 Post(s)
Liked: 42
There's plenty of reviews all over the web that these are pretty much total garbage at this point.
Hardware specs aside that you reported, its all about the software.
almostinsane is offline
Old 06-09-2013, 11:00 AM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
I dont know where you get your information, but it is false.
I own a dual core MK802IIIS (android 4.1.1) and it plays my 1:1 rip to MKV of Avatar Extended (36GB) without issue with no extra software installed at all.
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
Old 06-09-2013, 11:01 AM - Thread Starter
^^almostinsane^^
Wow. Strange, I've checked the android geek forums and they are very popular. I was curious the opinion of av guys that integrated these into their theaters.
Old 06-09-2013, 11:21 AM - Thread Starter
How is the video and audio quality? Are you using wifi or Ethernet to USB?
Old 06-09-2013, 11:31 AM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
The video quality is excellent. I do not use it on my Home Theatre because the audio is only 2 channel.
I have tested through WiFi and Ethernet via a USB adapter. WiFi stutters. The USB Ethernet was OK (I think, cannot remember).
Best playback results (and what I currently use) come from a USB connected External Harddrive.
BTW, I do not connect it directly to my TV; I connect it to my Onkyo AVR Also know, these do not come with a power source (supply) and poor power is often the cause of issues for many people. I connect mine to an external source; 5v 2amp
Shark007 is offline
Old 06-09-2013, 11:42 AM - Thread Starter
^ thanks you answered a few more of my questions. My tv's USB puts out five volts so I was thinking of plugging it in there. The setup I have uses a soundbar, so I'm not concerned about 2channel as long as the quality is good.
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
2 channel is okay for a bedroom TV or something like that.
How do you connect the power supply to it when you have a USB HDD connected?
Sammy2 is offline
Old 06-09-2013, 11:43 AM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
Your TV USB will not have enough Amps. They are typically <500 milliamps or .5 of an amp.
All USB are 5v
The manufacturer of my unit recommends a 2 amp source (keep in mind, mine is dual core)
you probably should find a usb source that is greater than 2 amps.
Shark007 is offline
Old 06-09-2013, 11:45 AM - Thread Starter
^ From what I've read People use a powered USB hub for USB connections. The unit has a micro USB port for power.
Old 06-09-2013, 11:48 AM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
These typically have 3 usb ports with one marked 'DC'
Shark007 is offline
Old 06-09-2013, 11:49 AM - Thread Starter
All USB are 5v
Cool I will not plug it directly into my tv. Thanks
Old 06-09-2013, 11:59 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Ah.. I see.
All USB are 5v
This is the same with the echo. It cannot be powered from a TV USB port because it is only 500 milliamps.
Sammy2 is offline
Old 06-09-2013, 12:00 PM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
I realize this next statement is off topic but Sammy is here, so . . .
Compare a $180 Echo (that may get android working) to one of these.
My unit (MK802IIIS) can be had for as little as $53 with free shipping on Ebay.
It doesnt do Media Center but then neither does the echo on Windows 8.
Shark007 is offline
Old 06-09-2013, 12:08 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
The echo barely does Media Center on Win7 but I do like the whole home DVR that it provides with my CableCARD tuner. Hopefully one day soon it will be transformed from the unobtanium it seems to be now to the all-inclusive device it should be.
That said, is yours running Open ELEC or XBMC?
Sammy2 is offline
Old 06-09-2013, 12:10 PM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
Neither. I am using the default player provided by the Android OS.
Shark007 is offline
Old 06-19-2013, 01:08 PM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
The video quality is excellent. I do not use it on my Home Theatre because the audio is only 2 channel....
BTW, I do not connect it directly to my TV; I connect it to my Onkyo AVR...
A new firmware was recently released for my MK802IIIS which upgaded the Android OS to 4.2.2 and also supports 5.1 Multichannel audio.
I tested my 36GB Avatar rip and it now outputs 5.1 audio. (decoded, not bitstreamed)
Shark007 is offline
Old 06-19-2013, 03:15 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
dts hd support
Sammy2 is offline
Old 06-19-2013, 03:22 PM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
Sammy, you do realize we are discussing a $53 android device, not a $180 Echo.
Oh wait, That $180 Echo cant even play the file to begin with!
Well at least this device can decode the dts core and give you 5.1 multichannel output.
Sammy2 likes this.
Shark007 is offline
Old 06-19-2013, 03:43 PM
4th-horseman's Avatar
Interesting, I've been following along with these for a while now and while they aren't *total* garbage they are not there yet. Also, the default video player in android doesn't do any hw acceleration, so they must have pre installed MXPlayer or some variant. Can you confirm this was really the default android video player, or just some 3rd party that came preinstalled?
According to everything I've seen as of the current date the only option for smooth playback with any of the available android sticks is to copy all your content to a portable drive and attach it to the stick via usb. I'll just keep waiting to see how well libstagefright works in XBMC on any of these chinese stick/boxes with A9 mali-400, because I can't fathom copying stuff around anymore. Different preferences/needs I suppose biggrin.gif
Some bloated references from within this forum, but decent content to be extracted from people who've used/tested these on network connections
http://www.avsforum.com/t/1472753/fanless-xbmc-box-still-holding-out
http://www.avsforum.com/t/1389407/my-next-htpc-will-be-raspberry-pi
http://www.avsforum.com/t/1450653/yet-another-death-to-htpc-thread
4th-horseman is offline
Old 06-19-2013, 03:48 PM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
I can confirm that the default android player is what I am using.
I don't care about hardware acceleration, I care about playback ability.
It means nothing to me whether the cpu or the gpu does the work. I just want to watch the content.
According to everything I've seen as of the current date the only option for smooth playback with any of the available android sticks is to copy all your content to a portable drive and attach it to the stick via usb.]
The above statement is correct for 1:1 BD rips.
Network playback of SD material is fine.
Shark007 is offline
Old 06-19-2013, 04:45 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
That is pretty cool to get 5.1 channel PCM from the core track on a $53 device though!
Sammy2 is offline
Old 06-19-2013, 04:47 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
True. So long as it looks and sounds good and does not stutter (guess that doesn't look or sound good) I really don't care how it is processed.
One day the network playback of 1:1 BD rips will be good on sub-$100 devices..
Sammy2 is offline
Old 06-19-2013, 11:08 PM
robnix's Avatar
Quoted: 664 Post(s)
Liked: 495
Question - I've been looking for something easy to carry when I travel that I can:
Plug into the hotel room TV,
Plug my USB drive with movies into the player
Watch Movies
Throw in my laptop bag when I'm done.
How do you think this would workout?
Looky here!
robnix is offline
Old 06-20-2013, 05:35 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
It would if the TV in the hotel room had an HDMI input which will probably depend on the age of the hotel or time since it had been refurbished.
Sammy2 is offline
Old 06-20-2013, 07:32 AM
robnix's Avatar
Quoted: 664 Post(s)
Liked: 495
Excellent, thanks!
Looky here!
robnix is offline
Old 06-20-2013, 11:24 AM
Watch Movies
The laptop coudn't handle this for you?
Old 06-20-2013, 01:30 PM
robnix's Avatar
Quoted: 664 Post(s)
Liked: 495
I travel for business, there are times that I'm working late and like to put a movie on in the background while I do so. It's more convenient to just have a dedicated device with a remote.
Looky here!
robnix is offline
