Static "clicks" when I open folders - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-11-2013, 09:10 AM - Thread Starter
jimray's Avatar
When I open a folder, or do similar functions on the computer. I hear a static sound from the speakers.
I use HDMI out from Nvidia 650 to my Yamaha receiver.
Any ideas what might be causing this?
jimray is offline
post #2 of 6 Old 06-11-2013, 04:56 PM
erickotz's Avatar
Liked: 30
Are you hearing a click, or static? Windows does make a clicking noise when navigating folders
Quality Assurance Manager, Ceton Corporation
erickotz is offline
post #3 of 6 Old 06-11-2013, 04:59 PM - Thread Starter
jimray's Avatar
It's static for sure
jimray is offline
post #4 of 6 Old 06-11-2013, 05:12 PM
erickotz's Avatar
Liked: 30
Update your receiver firmware, TV firmware and video card drivers
erickotz is offline
post #5 of 6 Old 06-11-2013, 05:49 PM
sawfish's Avatar
Quoted: 137 Post(s)
Liked: 144
Combination of silent stream bug and Windows navigation sounds. Can't do anything about the former except stop using Nvidia HDMI for audio, but you can eliminate the cause in this particular case by going to Sound/Sounds/Windows Explorer and setting "Start Navigation" to None.
sawfish is offline
post #6 of 6 Old 06-17-2013, 12:03 PM - Thread Starter
jimray's Avatar
Thanks for the help everyone. It lead me to find out that the problem is in fact the "Silent Stream Bug" However, the best solution is in this thread. It fixed my problem.
http://www.avsforum.com/t/1317491/silent-stream-bug
jimray is offline
Reply Home Theater Computers
